Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Is there any way to add video files larger than 4 gigs? Do I have to buy another hard drive?
  • 53 Answers
You should upgrade your file system from FAT to NTFS.  Then you should be able to copy files larger than 4gb.  Please refer to link below.
http://technet.microsoft.com/en-us/library/bb456984.aspx
Posted on Dec 29, 2010
Testimonial: "I had no idea what FAT and FAT32 was. After finding out their meanings and the differences between them, I was able to find the converting method. "
Formated 4 gig harddrive and loaded xp, now no space left
You need a larger drive, or less programs. windows uses 2.88 GB and likes 1 GB to swap in.
Try going into control pannel and add/remove programs and on the left side of the screen there will be add remove windows components - to delete things you don't need. Games, MSN explorer, fax services, desktop wall paper, mouse pointers, paint etc. All of these will free up 50- 60 MB. Which isn't a lot, but its something. There are also ways to delete all the help files, and empty folders, duplicate files etc. The bottom line is a larger drive is required.
Jun 17, 2010 | Compaq Presario 1275 Notebook
I cant move large video file from my laptop to my 1TB WD Drive
Reformat the drive from Fat32 to NTFS.
Largest file size on Fat32 is 4 gig
Oct 14, 2009 | Western Digital My Book Essential Edition...
Want to add 2nd hard drive to vista64bit hombuilt.
In one system that I have seen this one, we had loaded optimized defaults. One item you could look at are the jumpers and the SATA ports if the connections are correct.
Jun 02, 2009 | Microsoft Windows Vista Home Premium with...
Can't copy files to drive. Says disk is full and it is not.
what filing systems do the passport drives use and how large are each of the files ?
If they are fat 32 and the files are each larger then 4gb then that is why it will not work as fat32 does not support or allow more then 4gb per file due to the filing system so you would need to format it as NTFS if you want to store files larger then 4 gigs
Apr 14, 2009 | Computers & Internet
Syntax SV266A Motherboard Hard Drive update
i,d suggest an 80-120 gig hard drive should be sufficent.
if you require larger drive storage. you can add an external hard-drive via USB upto 500 gig usually without restriction.
You can also purchase An PCI Card, with sata connectors. should you wish to take that option. all the above is dependant on how modern your computer system/systems bios Is.
Mike @ Compurepair.
Mar 25, 2009 | Computers & Internet
I have a 250 Gig WD hard drive originally hooked up to Mac OSX 10.5.6.  I put files on it and then a co-worker looks at those files on a PC. Now, she's given the drive back to me to add more files. These...
Greetings.
files bigger than 4 gigs cannot be save on fat32 drives. NTFS file system is capable of saving files bigger than 4 gigs.
The MAC - to PC did nothing to change it. It did not change while she look it at her pc.
If u want to be able to copy files bigger than 4 gigs to your drive, change the format to ntfs.
  • It is easy to convert partitions to NTFS. The Setup program makes conversion easy, whether your partitions used FAT, FAT32, or the older version of NTFS. This kind of conversion keeps your files intact (unlike formatting a partition). If you do not need to keep your files intact and you have a FAT or FAT32 partition, it is recommended that you format the partition with NTFS rather than convert from FAT or FAT32. Formatting a partition erases all data on the partition and allows you to start with a clean drive. Whether a partition is formatted with NTFS or converted using the convert command, NTFS is the better choice of file system. For more information about Convert.exe, after completing Setup, click Start, click Run, type cmd, and then press ENTER. In the command window, type help convert and then press ENTER.
Link to steps and other info
Hope that helps.
Jan 10, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Iomega 500 gb hard drive: large file transfers
The default format for the IOMega drive is FAT32. This format will work on all versions of Windows, as well as Mac OS9 and above. Unfortunately, FAT32 can't handle files larger than 4gigs. If you want to use larger files, you're going to have to remove all the files from your IOMega drive and use your computer to format it to NTFS (Windows 2000/XP/Vista) or HFS+ (Mac OS9/X).
Consult your owner's manual for specific details.
Sep 12, 2008 | Iomega (33654) Limited Edition 500 GB USB...
External hard drive disk space
Hi
Is it showing the 300gig in the properties? if yes then try to copy with command mode,If again its given problem then u need to backup your data and format the drive, then try copying.I think it will work.
T.Boopathy
Aug 17, 2008 | Western Digital My Book Essential Edition...
Backup hard drive to an external hard drive
"what the error actually says is, you have either run out of space, or the backup file (.bkf) is too large for this disk. note: if the disk is formatted with FAT32, the maximum possible size for the backup file is limited to 4 gigs."
That error means that the FAT32 file system only allows 4GB files or smaller to be transfered. The chance that the backup file (.bkf) is larger than 4GB suggests that this file is causing your problems. You could try manually copying around that file (selecting all files from that folder except the large one) and see if that works.
Usually you will get many errors copying a drive directly as system files will be inaccessible and whatnot. Your best bet is to limit your copying to "C:\Program Files\" and "C:\Documents and Settings\", assuming you have Windows.
Dec 13, 2007 | IO Magic Corporation GigaBank (I250HD35)...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
153 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
