Is there a place in the world where they sell brand new televisions of square screen 4:3 aspect ratio of 43". or is there a place in the world where they custom make a television for you ebay and google did not help.
  • angelosoccio Dec 29, 2010
    thank you eagle its solved my doubt
  • 4,889 Answers
Unfortunately no. 4:3 would not be available in sets with screens larger than 40". Only non-HD tvs of lower screen sizes would have an aspect ratio of 4:3. For example see the one at the link below
http://www.amazon.com/Go-Video-TA2050-20-LCD/dp/B000AMO784
And sorry, there is no place in the world where they make tvs with custom specs.
Posted on Dec 29, 2010
How do I change the aspect ratio?
bring up the on screen menu, find the aspect ratio and used the volume buttons to adjust to correct ratio, go ok then exit
Feb 15, 2016 | Televison & Video
DOES NOT FILL SCREEN HORIZONTALLY
You can change how your tv displays in the video setting menu under display. You will have a choice between 4:3, 16:9, 16:10, cinema or automatic. I think to fill your screen the best you should choose 16:10 but this is not going to guarantee that all channels will fill the screen. It still has to do with how it is being broadcast to you.
Jan 25, 2016 | Televison & Video
What causes my aspect to constantly change? My tv or my cable box?
It could be both.
If you set your TV to Auto, then it will try to 'best guess' the correct picture shape based on what's displayed on screen. That's okay in the lab, but in the real world where there's too much changing then it's not so good.
The other thing could be the box and the TV channel you happen to be watching. If you have the box's aspect ratio set wrong i.e. to a different picture shape to the TV, then it will squash or stretch pictures.
Set your box to match the TV shape. The two main choices are Widescreen (16:9) or the old picture shape 4:3
Set your TV on a fixed aspect ratio: Either Widescreen if it is a 16:9 set, or Normal if it is a 4:3 set.
Sep 14, 2014 | Televison & Video
HD programs work fine, however, the standard pictures are distorted. I had this once before and someone fixed it but not sure how.
You probably need to to turn your aspect ration on the TV down. Newer HD screens use a 16:9 aspect ratio for HD content which is a wide screen format. Standard definition TVs and programs use a 4:3 aspect ratio. Most flat screen TVs have an option to display in 4:3. This option is most often found in Menu/Setting>Video Options>Aspect Ratio. For standard definition programming you want 4:3, for HD you want 16:9.
May 05, 2011 | Televison & Video
On HD full mode part of the screen is cut off.
Check the aspect ratio on the TV, if there are black bars on the sides, the program you are watching is in 4:3 (Square) on a widescreen (Rectangular) tv and are meant to be there.
Feb 28, 2011 | Sony BRAVIA KDL-46W3000 Television
I connected my media center PC to my new Sanyo DP50740 50" Plasma Television using the PC input on the back of the television. The instructions say that it supports 1360X768 with a 16:9 aspect ration...
No,13060 resolutions will not support by some tv correctly,will shift whole picture about to 6 inches to the right.That why,must use the PC Control panel to adjust to 1024 for the video to center.For the wide aspect 16:9 ratio,just find another aspect ratio to for expandsion to fit the entire screen.
Feb 05, 2011 | Sanyo Televison & Video
How can I get full screen image without distortion on tv viewing? I only get 4:3, zoom, full and justified. Full looks stretched horizontally with tv, looks ok with dvd.
Hello
Most of the telivision transmissions are comes at an aspect ratio of 4:3. Wide aspect ratio is 16:9. If you try to see a picture with aspect ratio 4:3 to wide 16:9, it will look like stretched. it is not the fault of the tv. Most DVD recording have the aspect ratio of 16:9 [Wide]. This aspect ratio will be displayed correctly when your tv is also set to wide mode. If you select normal mode at this condition, the picture will be displayed elongated. Ok Your Tv has no probelm.
Oct 19, 2010 | Panasonic Televison & Video
Cannot change aspect ratio when im playing a game it cuts off part of the screen
Normal aspect ratio is 4:3, and the wide aspect ratio is 16:9. If you play a game meant for 4:3 and you change the TVs aspect ratio to 16:9; part of the picture will be cut off. It is not the fault of the TV.
Oct 15, 2010 | Sanyo DS27800 27" TV
Heads are cut off on the top of the screen
The aspect ratio on your LCD or from the source (hdtv / vcr / dvd / sat dish) is set wrong.
Wide screens are usually set to 16:9 as opposed to regular square sets at 4:3
Wikipedia has some examples of some different aspect ratios:
http://en.wikipedia.org/wiki/Aspect_ratio_(image)
<< On the very rare occasion you may receive a bad stream from your television provider >>
Dec 08, 2009 | Element ELC-HS321 32 in. LCD TV
Picture size/aspect ratio in HDTV and upconverting DVD
In the digital world, you can't have a 4:3 aspect ratio DVD title (720x480) on a 720p (1280 x 720) / 1080p (1920x1080) display without some kind of centering or stretching to some extent. (square vs rectangle) Now, on a 16:9 aspect ratio title (wide screen format) you should have any scaling issues regardless of the pixel resolution. Despite what the sales person told you, trans-coding ("upconverting") lower resolution titles to a higher resolution does not increase the quality of the image. Any attempt to do so would be only to try to reduce block noise and any kind pixelation at higher resolutions. (blurring square pixel blocks)
In the analog world, the quality of the image is based on the encoder and signal depth. If your TV excepts HD analog, you might be able to have your cake and eat it too. That would force your display to convert an analog signal into a digital resolution, letting the TV hardware do all the trans-coding. Manufactures are completely phasing out analog signal receiving, but might have the RGB RCA connectors for backwards compatibility. Eventually, it will not be supported and you will be forced to buy higher resolution content.
Mar 31, 2017 | Televison & Video
Televison & Video Logo
49 people viewed this question
Top Televison & Video Experts
Electro Med Services...
