Question about Canon EOS-20D Body only Digital Camera
Error 99 in body
Dear sir,
this morning i am shooting few pics and after taking few shots camera did not work and i try it again and again did not work . i check cf card in another canon camera and it is work and in my camera it did not work. and i change the battery and when i put battery in the camera suddenly it click the shutter whithout click myself. it did automaticially even i on and off the camera only in once. and there is no power in LCD menue and see error 99 in the uppor LCD. i used that time my normal 18-55 lens and it is not fault of lens becouse i try in another camera.
How it happens and wht is the way to solve pls. tell me.
what is the reason of that problem. i have this not only one camera but in my both 20 D.
Bimal Sharma
Nepal
    Scholar:
  • 51 Answers
Hi
If you have tried different cards, batteries etc. try cleaning the contacts.
1. Get a pencil with a rubber on it.
2. Take of the lens of the camera and clean the little connectors buy using the rubber on the end of the pencil, brush of with a camera brush. Be gentle and try not to brush dust etc into the camera body.
3. Do the same with all the connectors on all the lenses you have. Do the same to the connectors on your battery.
If this has not helped and you have indeed tried new cards and different batteries you will need to take it into a Canon dealer.
Hope that helps.
Posted on Jul 15, 2008
Shooting is not possible, turn the power switch to off and on or reinstall the battery
Hi there :the Error 99 is a comunication error between camera body and lens .are you using Canon lens?Try the camera body with a/another Canon lens in Camera body and try the lens on another Canon camera.With this troubleshoting you can know if the camera body is failing or lens is failing.I hope this information will help you.
Nov 29, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
Error .press shutter release button again
did a shoot on friday and came home and downloaded all the pics and then I went to do a shoot today and my camera wouldnt work. When you go to take a shot the shutter closes and then and error comes up and says press shutter button again to release. This opens the shutter back up. The picture it takes is only the bottom half of the object you are shooting....any ideas of what I can do to fix this? I have only had my camera 30 days so I have no clue what it could be.
Jul 29, 2010 | Cameras
Describe your canon rebel hinge door error 99 Problem I get error 99 every time I try to shoot. Although, if I turn on the camera and open the door and close it while the camera is on I can shoot. So,...
'Error 99' indicates some problem with the AF contacts. This is a common error in Canon lenses. It could indicate a very simple problem like dirty contacts or a much serious one like the breakage of USM cable. Alternately, it can also be a card error or camera error.
First remove the lens, battery and card and leave the camera like that for about 30 min. After that, insert a fully charged battery and switch on the camera. If the error still shows up, it is a fault with the camera and has to be serviced.
If not, turn the camera off and insert the card. Format the card in the camera and depress the shutter button. If it shows an error, the card is faulty.
If not,
try cleaning the lens and body contacts (the metal contacts between the lens and body) using a pencil eraser. Be careful to hold the body facing down so that no dust falls inside. After cleaning both the lens and the body contacts, re-attach the lens and try shooting.
If the error still shows up, you need to take the lens to an authorized service center.
Jan 02, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Error code 99. Please tellme what this means.
This is what the people at the canon tech support say to do for error 99
read this!! :)
The guy at tech support listened and then told me that the lens contacts were dirty and to get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them.
Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
I did this to each of my three lenses just to be sure. Lo and behold, it worked
hope this works for you!!!! have a nice day!! :) :)
Dec 03, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Err 99 followed by the "Busy" issue in the viewfinder
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Jul 26, 2009 | Canon Digital Rebel / EOS-300D Digital...
Canon rebel XS error 99
Instead of taking out the battery, just open and close the battery compartment to reset the camera.
SVRGuy02 is right, set the slep time longer to avoid the issue so much and just open and close the battery compartment before beginning each shooting exercise
May 17, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Error 99
the lens contacts are dirty - get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them. Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I've used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
Works well for me....let me know how you fair!
Mar 16, 2009 | Canon EOS 40D Digital Camera with 17-85mm...
Error in body
Remove lens, CF card, and battery. Leave in a dry and slightly warm place for 24 hours. Clean lens contacts with a cloth or cue tip and eclipse/alcohol.
If the camera doesn't turn on after this, even without CF card and lens attached, then it needs to go to a Canon service centre. Don't tell them you got it wet, and maybe it will get repaired FOC.
Jul 07, 2008 | Canon EOS-20D Body only Digital Camera
Error 99 in body
Jul 07, 2008 | Canon EOS-20D Digital Camera with 17-85mm...
Sloooooowww speed
Try cleaning your camera.
Jun 15, 2008 | Canon EOS 20Da Digital Camera
Canon EOS-20D Body only Digital Camera Logo
107 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
