2 weeks ago my heater stoped working - tech that came out said it was a fuse $ igniter problem, there was a single stage fuse that was incorrect, he replaced the fuse with a 2 stage fuse, and also replaced the igniter, then he proceeded to program the system to shut off all heat between the hours of 10pm-5am, telling me this as he finished. I wasn't bothered too much considering the thermostat has a manual setting & hold temp setting. Although now 2 weeks later I can't get the temp I manualy set it for, the fan kicks on, heat blos but befor it reaches the set temp the system shuts off. % don't have a user manual, % don't know if I need a whole new thermostat again or a better tech or if there is some way to over ride / reset the system. I really prefer to manualy set my thermostat & have nothing automatically set to run & shut off. Please help....
    Problem Solver:
  • 10 Answers
I would try replacing the t-stat with a good quality non-programmable t-stat and start there
Posted on Dec 28, 2010
Testimonial: "I AGREE COMPLETLY, & may be what I end up doing, just frustrates me considering this T-Stat is 2 months old... Thank you for your time :)"
Why doesn't the second stage cooling work
If you have a two stage cooling system, you are probably unaware of its turning the second stage on and off unless you are right there listening to it or have the proper tools with which to tell. Most of the times, it is just a higher speed that the compressor runs on with a change to stage two.
Many times, a two stage cooling stat is installed in a single stage system because that is what was on the service truck. If so, it will operate the same on first stage as a single stage will. Usually the tech gets into the setup and changes the configuration to make the stat believe it is only has one stage. Many people may think they have an option that's not there.
Just a possibility.
Nov 30, 2014 | Heating & Cooling
HAYWOOD POOL HEATER
if voltage ok coming in check transformer if ok bad display or fuses
Apr 22, 2013 | Hayward H Series Pool & Spa Heater 200k...
New Hayward Heater H series 400 BTU won`t light error IF
check gas pressure again meter could be too small if furnace goes on while heater is on it will run out of gas and turn off giving you that error
May 13, 2012 | Hayward H Series Pool & Spa Heater 400k...
My GE oven takes a long time to lite. When it finally does there is a small explosion sound. I already replaced the ignitor 2 weeks ago. It worked fine for about 1 week and now I have the same problem...
If the gas valve is opening in a reasonable amount of time then the problem isn't with the igniter and you don't need to bother testing amp draw... Could be a number of things, clogged burner ports near the igniter, incorrect air/ gas ratio, incorrect igniter position (too far away from the burner), incorrect gas pressure. If you can, watch the burner when it lights from a safe distance and see if both sides are igniting at the same time or if it just builds up gas until BOOM! Ha ha, hope you figure it out, be careful.
Oct 04, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Fuse for ignition
There is no single fuse for ignition. If if is a major fault with heavy duty circuits ie Glow plugs, Alternator, A/C etc , there are H/D fuse links at the battery positive connection (or close to ) If you mean the ignition on the dash it's most likely a connector problem as wipers / heater / radio / lights/ are protected by multipal fuses and not a single ignition fuse .
Apr 05, 2010 | 2000 Chrysler Grand Voyager
Hunter 44360 problem
You probably have one of the wires reversed or have the options set incorrectly as to what type of heater you have.  Check your instructions here: http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/42710.pdf
Oct 29, 2008 | Hunter Fan Company 5/1/1 Programmable...
1998 328i
well you need more detail to know, start by check your fuses
May 26, 2008 | 1999 BMW 328 Series
Citizen wrist watch stops working
A lamp may be to hot while the light may not be sufficient. Put it in a window sil for a week or so.  Look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
May 25, 2008 | Citizen 8700 BL8000-54L Wrist Watch
Heating & Cooling Logo
62 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
