Question about Reddy Heating & Cooling
Reddy heater 60kbtu will run a few minutes and quit. Maybe 3, maybe 5, maybe 30. Photocell checks good, cleaned tank, replaced filters and cleaned nozzle, replaced plastic end cover. still makes bubbles around cork gasket. What's next?
    Novelist:
    Champion:
  • 224 Answers
You may want to replace the gasket to get a good seal to draw fuel with out air. You could try a gasket eliminator and seal this thing back up. A good auto parts store also sells gasket material where you can make your own new gasket, you need patience and a sharp knife and a punch for the holes.
Posted on Dec 29, 2010
Ready heater r110 I have replaced nozzle, filers all, cleaned sensor, runs some times for 30 sec shuts down
The R110 is a spark plug heater, as you know. It does not have the sophisticated electronics that the newer heaters have.
My guess: SP heater runs 30 seconds & shuts down- bypassphotocell. If it runs fine, then the photocell is defective.The test is simpleIf the photocell proves to be good follow these troubleshooting tips
Oct 13, 2011 | Reddy Heater-30-55,000 BTU Variable
Heater runs for 2-3 minutes then shuts off. unplugged to reset and it runs again for less than minute then shuts off again
Clean or replace your photo cell. Make sure your air pressure is set right,Remove your nozzle and blow air thru it . To test your photocell use a muti-meter hooked to two wire and hold flashlight over the end of boot see if ohms increase if not it junk,replace it.
Feb 08, 2011 | Reddy R60A Utility Heater
Heater keeps shutting off what could it be cant find manual to help
Use this manual to assist you in troubleshooting. http://www.bealsmotor.com/Desa%20Hot%20Surface%20Manual.pdf
The manual will help you isolate the problem.
Things than can cause your symptoms:
1. Pump pressure incorrect
2. Dirty air intake, air output
and/or lint filter
3. Dirty fuel filter
4. Obstruction in nozzle
5. Photocell assembly not properly
installed (not seeing the flame)
6. Dirty photocell lens
7. Bad electrical connection between
photocell and ignition
control assembly
8. Defective photocell
9. Defective ignition control
assembly
10.Line voltage is below 108V or
above 132v
REMEDY corrosponds with 1 - 10 above
1. Fill tank with kerosene
2. See Pump Pressure Adjustment,
page 10
3. See Fuel Filter, page 11
4. See Nozzle Assembly, page 12
5. Drain and flush fuel tank with
clean kerosene. See Storing,
Transporting or Shipping,
page 7
6. Check electrical connections.
See Wiring Diagrams, page 16
7. Replace ignitor, see page 11
8. Replace ignition control
assembly
9. Check for proper line voltage
1. See Pump Pressure Adjustment,
page 10
2. See Air Output, Air Intake and
Lint Filters, page 10
5. Make sure photocell boot is
properly seated in bracket
6. Clean photocell lens
7. Check electrical connections.
8. Replace photocell
9. Replace ignition control
assembly
10.Check for proper line voltage.
Disconnect power equipment
that may be used on same
line
Thanks for choosing FixYa,
Kelly
Jan 09, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
Heater comes on fine runs 5 to 10 minutes and quits. sometimes it doesn't run that long
Are you using old fuel from last year? If so, drain/clean tank. Check/replace fuel filter. Refuel with fresh fuel & test again.
Dec 09, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heater runs a few minutes then blows smoke and cuts off
Are you using the old fuel from last year? If so, drain and clean the tank. Replace with fresh fuel and replace the fuel filter. Check or replace the air filters. Check your ignitor for proper operation. Test again. Good luck.
Dec 01, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater 155,000 burning good then rich, any help????
Check your fuel filter,, could be running out of fuel,due to obstruction in fuel delivery system. Either crud in the tank clogging up the pickup,,or maybe even water in your fuel. Your filter might be it,,have you been running diesel?? check it out....
Dec 11, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heater shuts off unexpectedly
I would suspect that either the reset (HA3003 Safety Control) or the photocell (HA3019) is bad. For test purposes only bypass them one at a time- see if the unit ron OK.
Troubleshooting tips
hA3003
Apr 18, 2009 | Heating & Cooling
R155A Reddy Heater Help!
This is going to be a tough one. You have been thorough, done it right, and it damn sure ought to fire off every time!
There is something that is causing you a problem and don't think that because you put in new parts that you didn't get a bad part. It happens. Not often, but it does happen. I have rec'd nozzles from the factory that had the orifice installed sideways, so, I know it happens.
If the ignitor glows- (it only stays on for 5 seconds, then quits)
If the fuel fogs (not sprays)
If the fuel hits the glowing ignitor
Then it should fire off-- every time.
Now, if the photocell doesn't like what it sees, then the photocell will shut the heater down within 5 seconds, but it at least should have ignited. Right? Unless the photocell or the board are bad. Maybe.
Lift the top, and watch. What's happening. Are you having a fuel problem or an electronics problem? For instance- is the ignitor glowing every time at start up or only sometimes.
Let me know what you find.
Jan 15, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heater shuts down prematurly
If the heater runs fine for the 15 or so minutes without smoke/odor- do this
  1. check for water droplets on bottom of tank
  2. check for restricted fuel filter
  3. test photocell
  4. test safety control (reset)
You don't state whether this is a spark plug heater *or* Hot Surface Ignitor type. I made the assumption you were inquirung about a Spark Plug Heater. Disregard the list if the heater is an HSI type---- troubleshooting is different.
More troubleshooting tips for a Spark Plug Type heater
Dec 25, 2008 | Reddy R70ET Utility Heater
Gas wall heater
the R70ET is not a wall heater but a bullet style torpedo heater. it runs for a while then shuts down. first check that the photocell is clean. you'll need to unbolt the top cover. when pointing it make sure it "sees" the flame in its holder. if it still shuts down replace the photocell. the site www [dot] desatech [dot] com is the same place I get parts from for heaters.
Dec 03, 2007 | Reddy R70ET Utility Heater
Heating & Cooling Logo
29 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
