Question about Ricoh Office Equipment & Supplies
Need the part numbers for the fuser sensors causing sc428
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 183 Answers
This means that charge voltage card it's corrupted
Posted on Jan 01, 2011
What happens if you pull a paper jam from feeder, the opposite direction that your support to?
There are usually a number of paper guides and sensor arms that will tear into the paper if pulled the wrong way.
This can leave paper fragments in the fuser causing further jams, temperature sensor malfunctions, or odd marks on the print, and small pieces of paper left in the fuser usually require disassembling the unit to clean it out.
At worst case one or more sensor arms could be dislocated or broken which can be difficult or expensive to replace.
Nov 14, 2014 | Xante Ilumina 502 GS Digital Color Press...
A minolta bizhub c-6500 error code c-3804
Fuser Unit Code Sensor (TEM-4)
Get into:
1."Service Mode Menu screen"
Press [03 System Setting].
2. "System Setting Menu screen"
Press [01 Software SW Setting].
3. "Software Switch Setting Mode screen"
Press [3] In the left box. Press in the middle box [1] or numeric buttons after pressing the "DIPSW number" and "Bit number" buttons.
4. In the right box change Press [On(1)] to a [Off(0)] to specify ON/OFF of the selected bit numbers.
IF THE CODE COME BACK GET A TECH OUT TO LOOK AT THIS RESETTING OVER again CAN CAUSE A FIRE AND THAT WILL RUIN A PERFECTLY GOOD DAY!!!!!!!!!!!!!!! Sensor TEM-4 may need to be replaced or cleaned or the Fuser rollers replaced
Jan 25, 2013 | Konica Minolta bizhub Office Equipment &...
I keep getting a paper jam 201 every time I print. Then I have to open it up and take out the cartridge. What is causing the paper to jam?
A 201 paper jam error indicates the paper did not reach the fuser sensor within the proper time period. This usually indicates the fuser has a problem and needs to be replaced. The part number for the fuser is 56P1333 and it is user installable. You can get one from many places online such as Amazon.com
Aug 20, 2012 | Lexmark T630 Laser Printer
201.08 paper jam The paper continually jams - I clear it and hit the continue but it jams over and over. there is nothing stuck in there!!
201.08
Description
Exit sensor is never made.
Possible causes:
• Improper loading of manual feed slot
• Paper wrapped in fuser
• Damaged paper exit sensor or paper exit sensor flag
• Damaged fuser autoconnect
• Faulty fuser DC cable connection
• Faulty fuser
• Faulty system card
Action
• Check for anything in the paper path that might cause the paper to jam.
• Load paper in the manual feed slot.
• The fuser exit sensor may not be functioning properly.
Jul 14, 2011 | Lexmark C530dn Laser Printer
It reads low heat error....what does that mean?
This refers to a cold fuser. The Fuser Temperature Sensor may be falsely reporting, but since this is part of the fuser...either way, you will need to try another fuser first.
In rare cases, a Power Supply or other board can cause this too.
Let me know what model number and I can give you the Fuser PN.
Whit
Item, Inc.
Aug 18, 2010 | Office Equipment & Supplies
GETTING A ERROR MESSAGE DEVE HOME SENSOR ERROR. THE SENSORS WERE CLEAN AND ALSO THE FUSER ASSEMBLY WAS CHECK IT. I NEED TO KNOW THE NEXT STEP I SHOULD TAKE
That error means there is a problem in the fuser, could be lamp out, thermistor bad, overtemp sensor tripped, any number of things. You can find a new fuser at www.precisionroller.com
Jan 07, 2010 | Samsung CLX 3160fn All-In-One Printer
Sc548-00
you have to:
press the arrows "up" and "down" at the same time for five seconds
press the OK button
a new menu appears
select option 2: ENGINE
with the arrows navigate and select option number: 5 (MODE)
now press the right arrow until you see "810. SC RESET".
press ok
and later press "execute" (you will see it in the screen of the printer)
press "ESC" until you exit all menus
power off the printer for 30 seconds
and.... VOILá........
thats all
May 14, 2009 | Ricoh Aficio SP C811DN-DL Printer
Paper jam at fuser
1. Faulty/blocked fuser exit sensor or faulty/blocked POB sensor. The printer thinks paper is present at one of these sensors when there should not be paper present
Verify that the fuser exit sensor is not stuck
If both sensors are working correctly, the most likely cause is the POB sensor is being blocked by the transfer unit. This can happen if the sensor is out of position, or if the transfer unit's white plastic baffle is out of position. Try bending the POB sensor bracket outward slightly to clear the baffle and retest.
Dec 04, 2007 | Xerox Phaser 7750DN Laser Printer
Paper jam 2 fuser
1. Faulty/blocked fuser exit sensor or faulty/blocked POB sensor. The printer thinks paper is present at one of these sensors when there should not be paper present. Verify that the fuser exit sensor is not stuck Verify operation of the POB sensor If both sensors are working correctly, the most likely cause is the POB sensor is being blocked by the transfer unit. This can happen if the sensor is out of position, or if the transfer unit's white plastic baffle is out of position. Try bending the POB sensor bracket outward slightly to clear the baffle and retest
E0 message
It has a fuser error, needs new fuser, will not just reset when error is present.
The fuser is the hot bit that the paer goes threw to bond the image on the paper, yours has a blown heat lamp or a faulty temp sensor (thermister)
This area is not for playing in cause it is a electrical and fire hazard, just have new fuser fitted and error will be gone.
Oct 28, 2007 | Canon PC-921 Black and White Copier
21 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
