Model clc501 has been working for 8 months or more attached to a cable tv hookup. About 2 wks ago, it just stopped working. When I tried to rescan for channels, it scans very briefly and then displays the following msg: "auto channel search has been stopped due to an error." It has the same result when scanning on "air" as well/
tonyw514
  • 66 Answers
SOURCE: Channel Scan on my Philips 26" TV only finds the local channels.
Hi.
you should go into your tv's setup menu and go to the tuner settings and make sure it is set to CATV (cable tv) and not Antenna/Air also splitting a cable to many times can cause the signal to weaken and gain a lot of noise/distortion that could be an issue that can only be solved by having the company come to the house and do a test ALSO when your in the tuner menu in under your tv's setup menu try adding a non local channel manualy and then see if the tv will tune to it, if so then you might have to add them manually at the worst... my guess is that it is not set to CATV/cable tv hope this helps and if not i hope someone else can.
Posted on May 24, 2009
SOURCE: LCD 32 inch Auto Scan issue
I have experienced exactly the same issue on two Westinghouse sets. Try turning the set off when it reaches 83%. When I turn mine off and back on, it has saved the channels -- at least the ones it had found before it got hung up.
Posted on Jun 21, 2009
  • 45 Answers
SOURCE: no tv signal on my olevia 232-s12
cable or Ant.. ? after the scan if there is no channels found (0 digital, 0 analog) then try with cable or Ant to see if any of them work.. if they still don't pick up any channels and the whole yellow progress line goes across.. then it sounds like the tuner on the tv is bad.. and the tuner is part of the main-board so the whole main-board will have to be exchange or repair.. contact Amergence technology they are a 3rd party repair center that service Olevia TV's and they will be able to give you an idea on the repair cost..
<<< Amergence Technology number is 866-965-3842 >>
Posted on Jul 28, 2009
emissionwiz
  • 75814 Answers
SOURCE: How do i manually add a digital channel to my tv? model: ILO-26HD
do u have the user manual for the TV? if you do the solution will be in there, if not (I suspect you don't) please give the make an model so I can try to look this up, but off the top of head there is no way to "assign channels" to a paticular remote setting.
  • 9 Answers
SOURCE: After I reset my Olevia 542-B11 with
unplug televison for about 1 minute.
Go into menu picture>mode> powerup> and switch to home mode
Posted on Sep 05, 2009
Need to know what cable to attach to my laptop pc
The HDMI Cable will work best for using the TV as a computer monitor
Dec 14, 2012 | Craig CLC501 15 in. TV
No signal, bought an antenna still no signal
i have a craig tv bought it six months ago it was working fine until i put it on today now it saying no signal i tired everything.it goes on but i cant get any pictur or sound
Sep 20, 2012 | Craig CLC501 15 in. TV
DirecTV hookup to tv
If your TV is cable ready or HD tv ready you can hook up if not you can't hook up..
Thanks
Chester.
Jan 22, 2012 | Toshiba MV13M3 / MV13M3W 13 in. TV/VCR...
Craig 15" lcd tv Model
YES.
THE-MANUALS.COM/CRAIG- CLC501 -TV- MANUAL
ITS A FREE DOWNLOAD...
Jun 06, 2011 | Televison & Video
Walter and Barbara Bradford calling back with additional info. The cable box is explorer 4250HDC.It is hooked to the TV with 5 cable hookup.Also there is the power wire and the cable that goes to the box...
what are you trying to do? to hook up the tv you can use the cable output from the charter box into cable input into the tv (meaning cable as in coax cable) otherwise you can use the colored ones. red white an yellow are rca jacks but the 5 wire you talking about are prob compondent cables which are red green and blue. connect those to the tv and the other red and white ones are for audio to the tv you may have to set the charter box to select which output you are using and the tv to the right input for the rca it will prob be input 1 for the component it will be component 1
let me know if thats what you needed
Mar 17, 2011 | Craig CLC501 15 in. TV
My Guide Plus stopped working 2 months ago. Time
Also on Time Warner Cable and two TVs have stopped receiving Guide Plus in the last month.
Does anyone have suggestions?
Jun 09, 2010 | RCA F36650 36" TV
High number scan and hookup to dish network as 2nd tv
that tv most likely only has a tuner that goes up to 120 channels. Try rescanning but if it stops at 120 then that's all you can get..
Jul 01, 2009 | GE 13GP344 13" TV
TV & DVD HookUp (No Box) Can't get picture
As far as I know, my Go Video machine when there was no box involved...
The cable came from the wall to the IN of the Go Video box. Then another cable coming from the OUT of the video box and to the IN to the TV. TV should be on channel 3. As far as I can remember, I don't need to push the TV/VCR button, but instead, have to channel down to below channel 2 on the TV to the LINE/INPUT selection. Once you go there, and the Go-Video machine is on, you should be able to see a clear picture.
You'll push the TV/VCR button if you want to toggle back and forth from the VCR picture to the TV picture (which will be technically blank since it's on the 'line input selection.)
Hope that helps.
Mar 08, 2009 | GoVideo VR3845 DVD Recorder/VCR
Remote not working
Sometimes dust is accumulated in tv remote receiver sensor. This will give you the malfunction. Because your statement says TV is about 8 yrs old. Better solution is make one general service. If you have remote checker check the TV original remote working or not. We say universal remote, sometimes even technical person does not know how to use. Because in each and every brand and model there is a secret code to initiate the version. So better make one general service and check in your original remote it is working.
Aug 24, 2007 | Emerson ET-20F7 19" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
