Question about Dayton Electric Heater
Just bought a Dayton electric heater to heat a 12' X 20' greenhouse in October. When the heater comes on it now makes a loud sound as if the fan is hitting something. I have it mounted horizonally near the ceiling of the greenhouse. The unit is connected to a thermostat. 25,000 BTU Dayton heavy duty electric heater
    Master:
  • 381 Answers
If it sounds like the fan is hitting something, It is likely you will have to get a step ladder, and look closely at what is making the noise-
Likely something fell in there-- and needs to be removed.
When you shut the thermostat down, does the fan stop instantly?
Mack B
Posted on Dec 28, 2010
  • 2 more comments
  • cengelhaupt Dec 28, 2010
    Thanks and I looked in from the top of the unit. It appears that the motor housing itself is causing the rattling. Do the motors come loose on these units to rattle against the housing?
    The noise stops once the unit shuts off and starts to slow.
  • Mack Baxter Dec 28, 2010
    Good!-- So-- as you watch the fan turn, it does not seem to be bent or a blade broken or missing? (Easier to note, as the fan slows down..) There was no mud wasp nest built on it, or something to make one blade out of balance?
    As for the motor mounting- On the larger motors (over 1/4 hp) they usually have a heavy frame and mount on a flat plate..-- Those bolts can get loose-- and the whole motor will move around..
    More often the motor has some rubber vibration isolating rings, or bushings-- Usually held tight by a clamping bracket-- with a nut and bolt to tighten the clamping ring.-- They do get loose, also.
    Or sometimes the motor itself can have a winding go bad-- THEN-- it will only make the bad NOISE, when the motor is energized- I wonder if that is what you are noticing? Does the objectionable noise stop instantly, when the power is shut off?-- or does the nose gradually reduce, as the fan blade decreases?-- Instant, and steady noise only when the motor is energized-- a clue of a bad winding--- No danger-- but the noise is terribly irritating-- and the humming vibration will eventually do damage.
    Let us know what you observe now-
    You are a good observer! :-)
    Mack B
  • cengelhaupt Dec 29, 2010
    Thanks so much "Mack"...the noise stops immediately upon disengagement. As the fan winds down there is no impediment to the blade or unusual slowing or stopping, just the irritating noise. I will unplug the unit, see if I can take a panel off to access the bolts to the motor mount and attempt to tighten if needed.
  • Mack Baxter Dec 29, 2010
    Good to hear your plans--
    And-- remember-- if you find nothing loose-- but you still hear the noise-- and put your hand on the motor housing, (with the motor running)-- it may be vibrating due to an electrical winding's problems--
    If so-- Dayton Motors (Grainger) may replace it free-- if it is within a year of new?-- maybe even longer-- if you are 'not satisfied'-- for a motor should run for YEARS without this type of a failure. Likely a defect when it was made.
    Just be careful up on the ladder!-- Remember your ladder safety principles-- like NEVER on the top step, and don't lean too far from vertical.
    May you have a safe holiday/ vacation-- or few days off.
    Mack B
Need fan motor for model 2E440
Try Grainger
dayton 2e440 heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
... a Dayton Model 2YU40 electric heater Need manual for Dayton. ... looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
Dayton rheostat fan motor Heaters Questions & Answers ...
www.fixya.com > Forum > Tags > rheostat fan motor > Heaters
Dayton heaters rheostat fan motor related questions and answers. ... UP BUT FAN WONT KICK ON Could be one of several problems dependant on the model you have.... The motors are noisy in 2 Dayton 2e440 heaters. I ... I'm looking for a replacement fan and fan motor for a Dayton model 2E454B electric wall heater.
DAYTON Electric Wall Heater, Recessed or Surface ...
www.grainger.com/.../DAYTON-Electric-Wall-Heater-3...
W. W. GraingerShop DAYTON Electric Wall Heater, Recessed or Surface, Voltage 208/240, Watts ...Item # 3UG56; Mfr. Model # 3UG56; UNSPSC # 40101814; Catalog Page # 4277; Shipping Weight 20.65 lbs. ... Additional features include a built-in thermal cutout andfan delay switch for added safety ... Need Help Finding Repair Parts?
Jan 09, 2016 | Dayton Electric Heater
Electric Heaters and Accessories - Grainger
www.grainger.com/.../electric-heaters-and.../heaters/.../N...
W. W. GraingerCount on Grainger to supply high-quality electric heaters and accessories for ...Electric Wall Mount Heaters ... Electric Space Heater,Fan Forced,120V, ... SearchQ&A ... This fuse is used on driers heater elements, I'm unable to locate these in .... in Ask and Answer are not intended to replace or supplement any professional, ...
DAYTON Electric Space Heater,Fan Forced,120V, - Portable ...
www.grainger.com/.../DAYTON-Electric-Space-Heater-...
W. W. GraingerShop DAYTON Electric Space Heater,Fan Forced,120V, (3VU33) at Grainger. ... Item # 3VU33; Mfr. Model # 3VU33; NSN # ... Country of Origin China Country of Origin is subject to change. ... Alternate Search Terms ... I need a replacement fan motor .... Where can I find parts for Dayton fan forced wall heater mod.5ZK54D.
Dayton Industrial Fan: Amazon.com
Dec 21, 2015 | Dayton Heating & Cooling
My Dayton 4lz94 greenhouse thermostat doesn't activate at the set temp. But will turn on when temp is about 5 degrees below. Set temp. Is there a sensitivity adjustment to calibrate for activatio
I am having the same problem with my Dayton greenhouse thermostat, this question was posted in the wrong section...but if you find a solution I'd like to know. I am having problems with the heating thermostat as well as the cooling one.
Jan 27, 2012 | Ovens
Dayton3e368a pilot lights but burners do not come on. Heat rod was replaced last year. Heater is in a greenhouse
Most heaters has a pilot proving sensor of one type or another, it will be in direct contact with the pilot flame to prove that the pilot is lit and then will allow for the main gas to the burners to open. If the proving device has failed then it needs replaced.
Oct 12, 2011 | Dayton Gas Furnace Heater
Dayton heater Model 2E400. Does the fan draw the air in and than blow the heated air out of the botton of the unit? Does fan turn CCW or CC.
yes, you have the direction of flow correct. The rotation of the fan will be marked on the motor of the fan
Jan 07, 2010 | Dayton Electric Heater
My dayton NG heater fan will not shut off properly
Sounds like a bad fan switch. The switch is located on the heat exchanger and is 110 volt bi-metal switch. Follow the wires from the blower going back to the heatexchanger. Graingers can get you a new switch if you give them your model number. www.grainger.com.
Dec 12, 2009 | Dayton Heating & Cooling
I've got a Dayton 3E369 Unit heater. The electric
Sounds like it has a bad fan switch wich is no more than a small circular bi-metal switch that expands when heated closing a switch. Get a parts breakdown off the net. I am sure you could find the switch in your area and replace it yourself.
Oct 21, 2009 | Dayton Heating & Cooling
Dayton G73 electric heater
I just got my G73.  It comes with a new note that says "below 50 degrees the fan will cycle randomly (and might seem like its not working correctly) but once it is above 50 it will cycle normally."  it uses that to let the element re-heat quickly to bring the room up to temp faster.
Feb 13, 2008 | Dayton G73 Utility Heater
Buzzing noise - loud
check for dirt in the air gap that is formed between the electromagnet and the contact form. if there are any shading coils on the magnet check for a broken one.
Dec 30, 2007 | Dayton U33/U32 Utility Heater
Dayton Electric Heater Logo
150 people viewed this question
Top Dayton Heating & Cooling Experts
paulcarew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
