Question about Fujitsu 18C1 Air Conditioner
How do I check if a fuse has been burned and how do I obtain a replacement fuse?
    Master:
  • 383 Answers
Good question-- let me ask a couple, and see if this helps us both:
1.) Is it a glass cartridge type fuse (Small-- about an inch long, and 1/4" in dia?
Often you can see inside of these, and tell, that the tiny "filament-like wire' has blown-- Usually there is some balckened residue inside the glass.
2.) Other fuses are best removed from their holders, and checked with a continuity tester. (Be sure to remove the power cord from the wall before touching the fuse.)
3.) If you can get an Ohmmeter-- or a continuity tester (some call them multi-testers)
You take the fuse out, put it on the bench, take the 2 leads from your tester-- touch the tips together, and you will get an indication of what is a CONTINUOUS circuit..
This is the same indication you will see for a GOOD fuse..
If a fuse is blown-- it will be the same as when you hold the 2 leads apart-- Infinite ohms or OPEN.
Does that make sense?
Mack B
Posted on Dec 28, 2010
My heater dont turn on. Not even blowing
Check your heater fuse and/or relay.
Oct 05, 2015 | Cars & Trucks
HOW DOES A BLOWN FUSE LOOK?
The ideal thing is to obtain an ohms meter and check for continuity OR you can do it the old fashioned way and bypass each component. Only problem with bypassing something is you could burn the house down. OR ruin the timer OR melt the wiring harness. I looked up your model number
Mar 06, 2013 | Amana NED5100TQ Dryer
Battery fuse melted, alternator showing good at fuse ,but when reconnected gets hot and starts to melt
If this is one of the battery box top 3 green fuses, then your not alone. The receiver terminals inside the holder burn back and make poor contact causing arching and heat.
Cure is to install a set of 3 in-line fuses of 30amps obtainable from your local auto parts store to take the place of the original fuse block..
Aug 21, 2011 | 2004 Volkswagen Jetta
Fuse burned out on motor control board is the fuse the only problem
The fused burned out not because it is faulty but because a problem occurred, probably a short circuit, which resulted in the high-inrush of current. This burning out of the fuse on the motor controller module usually caused by faulty drain pump motor. Water leaks in the drain pump damages the pump motor winding and results in short circuit which eventually burns out the fuse. The drain pump must be checked first for such condition and replaced if necessary before replacing the fuse or the motor control board for that matter.
Jul 15, 2011 | Fisher and Paykel Washing Machines
My desktop 5108us presario made a 'pop' sound and stopped working. It will turn on but makes a couple rattling sounds and nothing happens. Inside, I see that a small fuse, up on the far left, looks like it...
It depends, motherboards usually dont have fuses. They have capacitors which can pop. Getting that fixed is dependent on how much someone will charge. I generally dont like replacing motherboards because of version issues, but replacing that part on the motherboard may not work properly. I would have a pro check it out.
Mar 01, 2011 | Compaq Presario 5108US PC Desktop
What fuse controls the radio and ac/heating in a 2002 Beetle?
A/C is protected by fuse on battery fuse block under black cover on top of battery.
These 30amp GREEN fuses burn out the holder. Check for burn and melting . Jumper Battery RED to individual small RED wires with another '' in line fuse '' of 30 Amp...obtainable from most car parts stores.
Radio has fuse in rear.
Jan 15, 2011 | 2001 Volkswagen Beetle
Hi my tv adapter keeps making sparking sounds and is given off a smokey smell. Will not allow my kids to turn it on. We only got it at Xmas
It can be deduced from your problem that the fuse located inside the adapter is burnt out,This occurs as a result of excess voltage which is passed into the adapter,the fuse in the adapter tends to protect excess voltage from going directly into the TV unit,
Hence,when excess voltage gets into the adapter,the fuses burns out and voltage cannot flow into the TV UNIT,
The solution is to take apart the adaptor and replace the cylindrical fuse which is burnt out,or as a better alternative,replace the adapter in order to obtain optimum performance in terms of protection of your TV unit.
Thanks and take care.
Jul 03, 2010 | Televison & Video
No power at all. Outlet is fine. Is there an internal fuse?
Yes there is most of the time. A new fuse can be obtained from radio shack. Most ovens use a small ceramic cartridge fuse ABC 15 or ABC 20. Please note though that this fuse usually blows because one of the small microswitches in the door circuit is bad (overheated and is burning up inside) or has operated out of sequence with the other several switches. Newer microwaves have one big switch assembly that needs to be replaced when the fuse blows. Make sure the door fully closes when replacing a switch. Be very careful with microwaves. There is very high voltage inside that could severely shock you!
Jun 23, 2010 | Magic MCB770W 700 Watts Microwave Oven
Replace burn out fuse
hello because theres a dead short somewhere what i mean by this is 1 of the components is faulty this is where you will need to do some checks or take it to an engineer
regards
shaun
May 22, 2010 | JVC RX-1028V Receiver
BLOWN FUSES IN THE POWER CORDS ON MY PVS72901
you can get fuses from almost any electrical shop, just take the blown fuse with you, give it to the shopkeeper and ask for a new one. The fuse might be blowing because,
-if you have a fan it might be blocked,
-the DVD Player gets switched on and off,
-The device its connected to might be malfuctioning.
HOPE THIS HELPS!
Jul 13, 2009 | Audiovox PVS72901 Portable DVD Player
Fujitsu 18C1 Air Conditioner Logo
232 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
