Question about Amana Washing Machines
Pictures or directions to fix a belt on the alw880qaw model washer
  • 57 Answers
1st: (I assume you have of the ront panel and machine is unplugged) Look at the motor. The pump is below it(right). Disconnect the pump hose watch out water is still in the pump. 2nd: Identify the 4 1/2" mounting bolts holding the Motor frame to the washer frame. Take those out. Careful the motor will drop so try to prop it up or cushion it(don't want to break the motor) 3rd: Pull off spring on tensioner pulley(do not lose this). Then take off belt(if not already off) Pull the motor and mount out. 4th: Youu will need some torx bits to remove the pump( I think it is the t-20 or t-25 it's just good to buy a little set of them). It should have three of them. Before you take off the pump look how the belt is orientated to the pump. After you get teh pump off it is easy and self explanatory. Then assemble in reverse except wait to the last to put the belt around the big pulley under the washer tub. Also it can be helpfull to have another person hold the motor as you try to start the 1/2" mounting bolt. Hope this helps you.
Posted on Dec 28, 2010
How do replace a belt on my Amana Washer, model ALW880QAW? It stopped spinning and agitating and when Itook the front off I saw a broken belt. I have the belt, But I don't know how to replace...
look around the motor you will see the mounting bolts they just might need to be losend or removed in order to remove and install the new belt some have a sleeve in the middle of the bolt that needs to be removed, try to do one bolt at a time, some times that helps.
Aug 21, 2011 | Washing Machines
I have an amana Model ALW880QAW Top Loading Washing Machine. It sounds like a bearing is going bad when the washer is in the spin cycle. I am familiar with repairing applicances and I would like to know if...
I have an Amana top loading washing machine.. The machine recently emitted a burning odor and the machine has stopped spinning. when turned to spin cycle there are bumping sounds and it no longer spins. Does this model have a belt which might need replacing or does it have a transmission and does it sound like possibly extensive transmission work. If it is the transmission, is it likely repair costs would be greater than the value of this machine?
Jul 25, 2010 | Amana Washing Machines
Maytag/Amana top-load washer motor humms but fails to start
id start with the start capacitor first. but ive seen a bad pump lock up a unit too. motor switch could be bad if the capacitor does not fix
Jun 24, 2009 | Amana ALW880WH Top Load Washer
Replace Broken Belt
Here is the link that will explain how to do it:
http://www.applianceaid.com/amana-wash.html#belt
check this link u ll get if u dint really sorry for in convinience
Jun 17, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Amana clothes washer alw880qaw
Hi, Check the belt first. Remove the lower front panel and see if the belt is ok. Please let me know if I can assist you further.
Thankx
Vic
May 25, 2009 | Amana ALW880WH Top Load Washer
Help with belt replacement
You have to remove the motor from the tub, there are 4 scews holding it on. then take off the pump using a star type bit
Dec 17, 2007 | Washing Machines
Washing Machines Logo
80 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
