Question about Toshiba DVR660 DVD Recorder/VCR
Hi my toshiba d-vr660 will not play video tapes the tape ends up on a sideways angle and then ejects help?
  • Toshiba Master
  • 6,771 Answers
I think by your description that you have a bad loading basket, it might be repairable but don't be surprised if they suggest a new one (if it is available)
Posted on Dec 28, 2010
Why does the tape get caught in my toshiba rd-xv45kb recorder when i try to eject the cassette and the tape snaps
Not sure about the Toshiba but generally when inserting a cassette it is lowered onto the tape drive. There is a device that will register the presence of a tape which used to commonly be a phototransistor or similar mounted on a short post that is covered by the cassette.
Once the machine knows a tape has been inserted, when play is pressed two vertical rods move towards the heads dragging the tape with them enough for it to make contact with the sound head and wrap part of the way around the video head to make playback possible.
When stop, forward or reverse winding or eject is pressed those two rods move back to the starting position and the surplus tape is wound back into the cassette.
If a cassette ejects leaving a loop of tape that can mostly be pulled out little damaged the reeling in mechanism isn't working. If the tape is jammed and comes free only after breaking the rods aren't returning to the start position.
Engineers use an empty cassette case suitably modified so once the vcr cover has been removed the operation can be observed. The problem might be a worn belt or rubber drive wheel or a problem with the hidden linkages - or it might be an electronic problem.
Apr 22, 2017 | Toshiba Televison & Video
Vhs tape will not play
Probably the loading belt has stretched or gone brittle. Another possibility is the lamp in the centre of the tape loading bay has failed.
Mar 09, 2014 | Toshiba DVD/Video Cassette Recorder...
Jvc minidv cassette not working display saying end tape does this mean tape has come loose.
End tape means that you have recorded the full 60 standard play or 90 minutes long play and you should rewind the tape or eject it.
Oct 15, 2013 | JVC GR-DVL100 Mini DV Digital Camcorder
Our Toshiba VCR won't play tape. It ejects tape after a few seconds.
If you are trying to play older VHS tapes, you may have to run them through some fast forward-rewind cycles to condition them and relieve stress
Jul 20, 2013 | Toshiba D-VR4 DVD Recorder/VCR
Toshiba d-vr660 shuts off when video is inside
If the problem is the vcr section you load a tape and it shuts down, it probably is the idler assembly that is not transporting tape correctly. I recommend a vcr/tv tech to check the unit with an estimate.
Dec 29, 2010 | Toshiba DVR660 DVD Recorder/VCR
OUr Samsung SCL 810 Hi-8 Camcorder is flashing Lemg-Eject in yellow, but won't eject a tape. We know it is old, but we're trying to transfer all the tapes to other media so we won't lose them and now the...
I had a similar problem with a Cannon Optura PI and had to send it in. It was better, but I still have problems on occasion. If your intent is to transfer all the tapes to media, I would suggest purchasing Toshiba's DVD Video Recorder/Video Cassette Recorder. Model: DVR620KU. I use a VHS-C Cassette Adapter to play my VHS-C tapes in and the dubbed them to a DVD. Works great. Unfortunately, there is no 8mm/VHS Adapters, since 8mm, Hi8, miniDV are different formats with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with past or current VHS technology. Your best bet would to borrow a HI-8 Camcorder and then dub your tapes to DVD's using the Toshiba machine. Here is a link to the Toshiba machine. http://www.testfreaks.com/dvd-players-recorders/toshiba-dvr620/
Good luck
Dec 28, 2010 | Samsung SC-L810 Camcorder
Eject error R
Use different tape. Is the tape still attached to the feed spool, or has it become separated ?
Jul 11, 2017 | Samsung VP-D361 Mini DV Digital Camcorder
Samsung SCD-5000 miniDV tape deck problem
Hi, I have a SCD 5000 Samsung camera. The video plays and records. But the camera side does not show in the video screen. HELP me
Jul 06, 2007 | Samsung DouCam SCD-5000 Mini DV Digital...
Playback & Ejection Problem
Hi, You usually get an EJECT TAPE when the camcorder has found an internal problem and either the videocassette or the camera itself has developed a problem. In you case, it looks like you tape has a problem. Daniel
Sep 04, 2005 | Canon ZR25MC Mini DV Digital Camcorder
Toshiba DVR660 DVD Recorder/VCR Logo
122 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
