Question about HP Photosmart 2610 All-In-One InkJet Printer
Colored photos have a parallel red green line running the full width of the picture. Can this be eliminated?
    Genius:
  • HP Master
  • 1,739 Answers
Streaks or Lines in the Printed Image
An ink cartridge could be running out of ink or your ink cartridges require cleaning. Need to check ink levels, run the clean print cartridges utility and then print a diagnostic page.
Working through the steps outlined at the link below will help you to diagnose your specific problem.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00219790&cc=us&lc=en&dlc=en&product=421139&tmp_track_link=ot_search
Trust this is helpful.
Posted on Dec 28, 2010
  • Mary Kus
    Mary Kus Jan 29, 2014
    I am getting a red & green line across any photo I print, but not if I print text. I changed the color cartridge with no change. I am ready to replace this printer with a non-HP priinter!
How do I fix my Samsung Plasma TV? It has vertical green and red colored lines a pixel width that will go in an out of normal activation. Model: PN60F5350BXZA
hi bring the menu up, if the lines go through the menu it's panel fault, if there behind the menu could be dirty or faulty lvds cable dirty connections on the boards,thanks
shaun
Feb 13, 2017 | Samsung Televison & Video
XR 8600 what color wire on the output connects
Peavey XR 8600?? Well it's 600w per ch. at 4 ohms/per side. So, whichever mode you use (Main, or Main/Monitor) you are best to have a 4 ohm total load for each channel of amplification. Ex.--Mains only, one 4ohm speaker per channel will give you 600W per side. Or two 8ohm speakers per channel in parallel, which makes a 4 ohm total load.
Main/Monitor mode---treat it the same way. one 4ohm, or two 8 ohms parallel. per channel.
Your best situation is to have a 4 ohm total load for each channel of amplification to get your 600W.
Parallel-- 8ohms each / 2 speakers = 4 ohm
Feb 20, 2010 | Music
My componet/av only shows black and white on my vizio vp422
The 37" Vizio I just bought has a very confusing feature where the same input can be used as either the Y channel of the component or the full video channel for composite. If you plug a component source into the TV and then select the composite input ("AV" on the remote), you will see a black and white version of the full component signal (makes sense as the Y channel is just the luminance component). As sad as it is, I was stumped by this for a while until I happened to hit "COMP" and got full color. FWIW, the manual warns about this, but it really doesn't emphasize the point. I wonder how many returns they get because of this.
Mar 16, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
1/2" yellow line appearing in the middle of a background colored page
sounds like you need a replacement drum as it sounds like it is faulty, this is a replacable part and needs to ber replaced from time to time, this is a common symptom of this fault
Oct 03, 2008 | HP LaserJet 4600dn Color Printer
Parallel vertical lines through left side of Panasonic Plasma tv
This sounds like one of the driver boards at the bottom or top of the screen has an intermittent fault. The set will have to be taken in to a service centre.
May 31, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
Lines horizonal - seems to be caused by voltage to green CRT
Your green CRT is shorted. To test put your red crt socket on the green and your red on the green. then try turning up red control if the green now works its not your tube. If the same thing happens with the red socket on the green you can be sure its the green CRT if the green works properly with the red socket, then you have a problem in the green drive circuit and not the CRT. hope this helps.
Jan 19, 2008 | Mitsubishi WS-55313 55" Rear Projection...
Colored Lines at the top of the picture
To reset the convergence EEPROM, press "menu 0359 to enter the convergence menu, then press "8970" to reset.
Sep 19, 2007 | Mitsubishi WS-48513 48" Rear Projection...
No Picture
I have the same problem was working fine and less than 2 months bam red screen green lines top to bottom no image on any input just volume works....Now i will be a victim of there horrible warranty service
Jan 09, 2007 | Westinghouse LTV-37WI 37 in. LCD...
HP Photosmart 2610 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
