* Was working fine until I cleaned out the pump / filter and then I put some water backwards into the water pump outlet under a little bit of pressure and heard something release and felt the pressure drop. The water pump started working again but there was now something rolling around under / inside the drum. I wonder if I blow off a seal or a water pick up pipe that ended up were it shouldn't be ? Immediately after doing this, a rumble sound started during wash cycle and during spin cycle it comes to and abrupt holt with a loud wering sound. Can this be something as simple as a warn drive belt ?
  • andrew_w_bur Dec 28, 2010
    Thanks for your help I will follow your direction and see how we go :-)
  • Washing Mach... Master
  • 19,396 Answers
Hi.
You need to access the drain hose connected directly to the pump. In most front loader machines this is done removing a panel located on the front side of the machine, at the base, right below the windows. Behind the trim or metal door you will find a cap that opens rotating counterclockwise.
In most top loader the pump and hose are accessible from the bottom side of the appliance, leaning the machine forward.
Some model may have an access panel at the back of the appliance.
Instructions on how to access the pump are usually reported in the manual.
Disconnect power and be ready to collect the water with a container before accessing the drain pump hose (often called drain filter housing).
Posted on Dec 28, 2010
  • Ginko
    Ginko Dec 28, 2010
    Hi.
    As said, by blowing or pumping water from the drain hose side you have probably moved objects and blockage that was trapped in the pump housing, that is likely causing the noise.
    All the best.
    Ginko.
I have a keystone springdale 311ressr. My water pump is under the carpeted step by the bedside stand. There is no access panel that I can find. How do I get to it to winterize?
Drain the supply tank (or run the pump until it sucks air) then pour a little RV potable antifreeze into the supply tank, open each faucet/outlet -- one at a time -- and run the pump until antifreeze appears at that faucet, close it and go to another one until all are running antifreeze - they color it to make this easy. All piping and pump and tank is now full of antifreeze and protected. In the spring put a little fresh water with a dose of chlorine bleach in the tank, run that through all outlets, fill tank with clean water and run that until you can't smell chlorine. System is clean and ready for use.
Oct 19, 2016 | RVs
Coffee holder cup blocked
The same just happened to me, thus, looking for a replacement filterholder.
Jun 12, 2013 | Ariete Cafe Retro Espresso Machine
Filter rattleing in front compatment
Assuming that by "filter" you mean the bit behind that little door at the bottom on the front of the machine........
The other thing that's in there is the workings of the drain pump. It sounds to me as if something hard has got in there and is stopping the pump from turning properly.
Turn the power off before you start.
Once you've got all the water out, all you'll need to do is to open up, remove the obstruction and (if it's what I expect it is) buy yourself a drink with it. (There is a big round plug behing the little door. Give it a quarter turn and it will pull out. On some machines, you may have to loosen a small locking screw before the front of the plug will turn)
The tricky part of this is getting the water out when the pump isn't working. The best approach is to pull the machine away from the wall. Put a basin on the floor, then remove the drain hose from the standpipe it plugs into and allow the machine to empty by gravity into the basin. When the basin is about half full, lift the hose up to stop the flow and empty the basin before starting again. This way, you can get the majority of the water out of the machine.
There is always going to be a little bit of water left. The safest way to deal with this is to put cloths down to catch what spills, slide a baking tray under the corner of the machine, and crack open the pump/filter cover (closing it again to allow you to empty the baking tray) - repeating until no more water comes out.
An alternative approach to this last bit is to tip the machine backwards, physically remove the drain pump from the machine (while still connected to all the hoses) and then suspend it over the basin while opening it up. If you know what you're doing, this is much quicker and cleaner than the baking tray approach - but you have to be really careful not to get the electrical bits of the pump wet and not to let the machine topple over onto anybody.
A.
May 02, 2010 | Zanussi FJS1225W Front Load Washer
The machine fills up but will not drain or spin, I have just removed hoses and there is no blockages, could the filter need cleaned, is so where is it located?
First, if there is still water in the drum lower the outlet hose into a bowl and if no water comes out then you have a blockage but if water flows out then the pump is at fault. To clear a blocked filter on a WMA machine which still has water in it, first tilt the machine backwards and open the door, bail out the contents of the drum with a mug or sponge untill it is as empty as you can get it. Now lower the machine back down again and remove the lower inspection panel at the back of the cabinet now tilt the machine forward.....place a tin of soup or something under it to hold it in a tilted possition, then put a bowl or deep oven dish under the sump to catch any remaining water when it is removed. Undo the retaining clip around the sump hose and disengage it from the container, the filter is inside the hose and can be taken out to be cleaned.Click the links for Workshop manuals on Hotpoint WMA and WM machines
Mar 27, 2010 | Hotpoint WMA40 Front Load Washer
How to clean pump
If your machine does not have a separate filter that you can remove from the front, then unplug power, and do the following -
Turn off water supply at taps under sink.
Open door on machine, and pull the machine out by grabbing the drum.
When 1/2 way out, check pipes are not being pulled.
Remove machine and turn to make access easier. - Do not strain pipes !
Remove outlet hose - keeping it high - or water will drain out.
Drain into a roasting pan at ground level to remove residual water.
Tip machine backwards to gain access to pump underneath. Use a toolbox or similar prop for safety to prevent it falling forwards, You may need to disconnect hoses to do this.
If you do, there will be a little pressure in them - use an old towel to mop up spurts.
Pump should be visible from underneath.
It can be disconnected from outlet hose and drum hose.
Usually it is the drum hose that has any blockage within it. You will need a pipe wrench to undo the clips usually - slide them back over the rubber hose while applying pressure.
You can then disconnect the pump and remove it for cleaning.
Replacement is reverse of this procedure - check pump for screws, wire, coins etc that cause problems.
Mar 15, 2010 | Washing Machines
Water not pumping out on my hotpoint washing machine
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Could be a faulty or jammed pump or you may have a blockage in the sump filter or possibly in the outlet hose. First try putting the outlet hose in a bowl and see if any water comes out, if it does then you don’t have a blockage but either a jammed or faulty pump. Empty all the water out of the drum by filling the bowl or bucket and to stop the flow of water raise the hose higher than the machine. Continue doing this until the drum is empty. Tilt the machine forward and place a tin of soup or something under it to keep it tilted forward, place a shallow basin or deep tray under the pump to catch any water that will come out (rather than soak your floor) undo the clip holding the hose onto the pump and remove it. You may need to remove the pump but you could find a cotton bud or something in the pump housing that stops it from working or it may be a lose connection on the pump (check that first)
If no water comes out of the hose when you lower it into the bowl then you have a blockage and will need to bail the water out of the drum using a mug or jug. Tilt the machine backwards and you should be able to open the door keep it tilted by putting your tin of soup under it. When it is empty remove the tin of soup and tilt the machine forward, place it under it again and put a bowl or basin under the sump. Remove it from the container and you should be able to pull the filter out at this point but if not remove the other end from the pump and clean the whole thing out in the sink. If there is no evidence of a blockage in the sump filter check the outlet hose especially if it was connected to an under sink U bend.
Mar 04, 2010 | Hotpoint First Edition WMA20 Front Load...
Clean pump light is on - how do i do it?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} It’s not possible to give specific information on how to remove or clean your pump or filter because you never stated which make or model you have! But if you follow the outlet hose back into the machine it will lead you to the pump and the other hose coming off the pump will go to the sump/filter. It is then just a case of removing the hoses and cleaning out any blockage from inside. Be sure to turn off the power and empty the tub of as much water as possible first or you will end up with a soaked floor, it will also be an advantage if you can tilt the machine away from the pump before removing any hoses. (If the pump is at the rear of the machine tilt it forward and place a shallow bowl or dish under it to catch any water. Keep the machine tilted by putting a tin of soup or something under it. If it is at the front then tilt it backwards.)
Mar 04, 2010 | Whirlpool Washing Machines
My Breville800ESXL makes steam but does not make espresso.
jejones is right. try a coarser grind. it still makes great espresso, especially if you really pack a lot of ground coffee into the filter basket. Just make sure it is a bit coarser than you would normally use for machines without the dual wall filter basket.
Nov 19, 2008 | Breville Die Cast 800ESXL Espresso Machine
Water will not dispense
This is a very strange case, maybe I mean Maybe you should drop a little pressure from the main water supply.tight the pressure regulator a little bit and try it.
Maybe I am wrong.
Jun 25, 2008 | Kenmore 53642 / 53644 Side by Side...
Fast spin
IF the tub is spinning at high speed but the water is not draining fully. then you need to remove the filter and pump assembly and look for more blockage further past the filter/pump.
its not hard to do just a screw or 2 and a 2 clamps.
be certain that there are not some clothing or debris above the filter too , pull the door rubber back and explore around under the tub.
and be certain that the impellers on the pump move freely and are not broken. you need a flashlight.
disconnect the power because of the water present.
its only little work ,the pump comes apart easily.
Feb 26, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
