Question about Hoover Dishwashers
Hoover dishwasher model HED 6612/1-80. Has all lights lit up and beeping. Error code in manuel says "too much inlet water" What does this mean and how can i correct this. Thank you
rickzilla
  • 706 Answers
SOURCE: Dishwasher Error code/
F5 according to the manual suggests you have an 'increase in temperature when element should be off" The possible cause : Faulty element, Faulty elecronics controller or faulty temp sensor.. In all cases they suggset you have your service reapir person resolve...
Hope this helps..
Posted on Sep 22, 2008
  • 113 Answers
SOURCE: error code e4 on kenwood kdw12st3a dishwasher too much inlet wate
HI there,
I have had the same problem as most of you. I seem to have fixed it by
1. Bail out all the water from the inside
2. Remove the filter and 2 x mesh pieces.
3. Continue to bail out the water from the filter well.
4. You will probably find pieces of food or fat/debris in the bottom of the well. Remove these.
5. Tilt back the dishwasher at 45 degrees for 30 mins or so to drain and dry the flood sensor.
6. Boil a kettle and pour it down the well. Immediately put the dish washer on a eco wash (no tablets or anything) with half load (ie half water) and this will ease the water pump.
7. Let the dishwasher run its cycle.
8. Clean the filter again and the filter well.
It sounds quite long winded but with a £250 item you need to take care of it. Make sure you rinse most plates before loading in the future.
Hope this helps!!!
Good Luck!!!
neo
Posted on Mar 01, 2009
Todd_pdx
  • 22 Answers
SOURCE: will not fill with water and all the lights flash and beep
Probably a frigidaire will need a new touchpad.
Posted on Mar 31, 2009
SOURCE: new hoover HED 6612-80 dishwasher
hi, i have same problem with my hoover dishwasher same model as your own, did you ever find out how to fix the problem. your help would be really welcomed. thanks lesley
Posted on Sep 01, 2009
  • 5 Answers
SOURCE: Hoover hed6612 dishwasher wont work
We have had the same problem but have found a fix.
1. If any of the wheels have come off the top sliding basket/rack you need to make sure they are all back on for each wash ( ours are very loose! )
2. Push the top rack in FIRMLY before you wash - make sure it engages at the back.
That's it - solved it for us after months of problems.
I think that as the wheels get worn the top rack does not fully engage at the back and this is when the problem starts manifesting itself. We have some new wheels on order but they are taking ages to arrive.
Posted on Mar 30, 2010
My dishwasher is just flashing F10 all the time
Codes are pretty generic between Hotpoint, Hoover and Whirlpool.
Heating element fault
Issue: The LED lights on your dishwasher are displaying in the following sequence (please see below these error codes for your LED reference
  • LED 1: OFF
  • LED 2: ON
  • LED 3: OFF
  • LED 4: ON
Action: We recommend you call our customer service centre to book an engineer.
Here is the Hoover site.
http://service.hoover.co.uk/advice-centre/dishwashers/
Error codes Hotpoint
Jun 19, 2016 | Hoover 24 in. HD97E Free-standing...
Dear gents, I face problem in hoover HDW1400 dishwasher machine Error E1 kindly need your support to solve this issue
The E1 error most likely means that the dishwasher identified a slow fill issue. First, make sure that the inlet water connection is not leaking and that the water valve is open. Make sure that the incoming water is as hot as possible from your water heater. (Wash some items by hand first.) Next check the inlet valve and those connections. Check the voltage across the valve to make sure that it can open. (If the valve failed in the closed position, there will be no water in the dishwasher when you open it in the middle of the cycle.)
Next check the float valve to ensure that it is rising and falling properly. If the float is blocked in up position, the washer will assume that it didn't properly fill and stop operating. Check the switch as well to ensure that the signal for the float position is properly being provided to the CCU.
I hope this helps. Unfortunately, I can't find the HDW1400 model number to assist you in obtaining any replacement parts. Please check the model number. If the model number given inside the door of the dishwasher is different than that given above, please add a comment with the full model number of your dishwasher. If your unit is under warranty, contact Hoover directly.
Jun 15, 2015 | Hoover Dishwashers
The dishwasher begins to start, then it stops, beeps and flashes the letters "IE" on the screen. We have tried every setting and it does the same thing.
Hello
The "IE" error code indicates a problem with the water inlet. The water supply valves are not turned on fully or the inlet hoses are kinked, clogged or frozen. Remove kinks in the hoses and remove clogs with a straightened coat hanger. If this does not resolve the problem, contact a service technician.
Sep 07, 2011 | LG LDF6810ST Stainless Steel Built-in...
My dishwasher ( 66517269400) won't turn on. Circuit is fine. It is getting power. I replaced the fuse. Clean light is flashing 7 times. Manual says "dishwasher has malfunctioned. Call for...
The F7 error code(light flashes 7 times) is a one of these, Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
So what you need to check is if the correct water level is in the tub,to check that start d/w let it fill and once you longer hear water entering,open door and the water should be level or just above the heat element, if not enough water first check water pressure to inlet valve,if pressure is good replace the water inlet valve part # 8531671 it could be picked up from your local appliance parts store,or online at;
repairclinic.com
searspartsdirect.com
apwagner.com
apdepot.com
midwestapplianceparts.com
Aug 20, 2011 | Kenmore 24 in. 17269 Built-in Dishwasher
Hoover HED 6612/1-80 dishwasher all four lights flash and beep whilst the machine drains, after a couple of minutes the beeping stops but the four lights glow. Cannot reset to cancel. Also still makes...
Not sure if you have got a user manual for this dishwasher. You can download one from this site.
You have a flood situation inside the dishwasher. See page 12 of the manual. There may be no water at the bottom of the machine but there is some overfill occuring. Also see error codes on page 13. This can be either because the flood detection circuit is faulty and giving false trigger or there is water in the base of the dishwasher housing due to leaking door gasket or hoses.
Some things to try. Turn mains power off and back on and see if there is any difference.
If not, then turn power off and pull dishwasher out from the kitchen benchtop. Put a few towels on the floor and tilt the dishwasher side to side on the base and see if any water comes out. Wait 5-6 minutes and turn power back on. See if it makes any difference.
Dec 15, 2010 | Hoover Dishwashers
Washer will not fill with water
Hi just read your posting.Now have you checked there is water coming out of both inlet hoses by removing the hoses from the machine end and putting the hoses into a bucket and turning the taps on?If there is 100% water coming out of the hose, is your machine beeping and showing an error code as a series of lights which will be lit when the machine is beeping.These lights will be in a row of 8 lights and starting from the left to right which lights are lit when the machine is beeping.Is it the 2nd and 5th or the 1st and 7th ---etc---?.Please reply with additional information on the questions and I am sure I can help you.Looking forward to your reply.
Oct 02, 2010 | Fisher and Paykel GWL11 Top Load Washer
Hi, we have a Hoover HEDS668-80 dishwasher at work. The first problem we had was none of the programs would run this turned out to be a broken door lock. After replacement we managed to get one pre wash...
Hello... Did you check the water inlet pump is turning on to let water go inside the machine? I think if you starts a cycle and feels no water in machine it stops and give error... Hope that will be faulty or before that I'm pretty sure you forgot to open the water inlet valve because you recently repair ?? please check
Sep 21, 2017 | LG LDF6810 Built-in Dishwasher
Will not fill with water and all the lights flash and beep
Mar 31, 2009 | Dishwashers
New hoover HED 6612-80 dishwasher all indicator lights staying on, manual says due to overfilling with water which is confirmed by water leaking on to floor, how do i solve this problem
Aug 17, 2008 | Hoover Dishwashers
Hoover dishwasher error codes
Hi we have a Hoover DT999 and according to the manual for that machine error E1 is water inlet tap turned off
Dec 18, 2007 | Dishwashers
Dishwashers Logo
269 people viewed this question
Top Hoover Dishwashers Experts
Owen Barnes
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
