Question about Elo Entuitive 1545L (Black) 15 in. Flat Panel LCD Monitor
Hello, I am working on an ELO 1545L that the inverter fires up only for a bit. I've changed the elect.cap and no change. I've found a place that sells inverters but I need the pin out on this unit to match up the dim, on/off, power etc. Would be nice to have a schematic on this or at least the information on the pins of the inverter. Thanks, Monty, bench tech @VVS inc. Lincoln.
2 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: I got a ELO 1524L LCD touch monitor. The back
You should have 2 wires for 12~15 power going in, which you already indentified, 2 more wires should be for ground return, you can check for them by using Ohm meter between the chassis and probe the wire for less then one Ohm resistance. The other two wires, 1 wire will be for Dimming control (usually 0 = dimmed, 5vdc = full brightness), 1 wire will be for BACKLIGHT ON/OFF (0v= OFF, 4~5VDC = ON) control.
Dose the fuse on the inverter board check out OK? You can use other inveter board as long as the lamp connectors are the same and you just have to match the input signal pin. I have done many.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
See example of the fuse on the inverter board.
Posted on Jul 11, 2010
Viewpia lcd tv backlight not working
Measure the input voltage to back light inverter board, from the main power regulator board. If it is found OK, replace back light inverter board.
Jul 27, 2012 | Televison & Video
Hello! I've got a problem with my Samsung
You may still have the problem with the 5vdc filter caps problem, bad cap can look normal but can have high ESR. I always repalce them in a set not just the bulging one. The 820/25vdc caps are more likely to be for the 18vdc inverter backlights circuits. Inspect the caps on the logic board also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 02, 2011 | Samsung Computers & Internet
Jul 11, 2010 | Elo 15" Touch Monitor
Elo 17" LCD Touch screen ET1725L Powers off after 1 second
Your problem lies ion either your back light inverter or in the backlight tubes ( bulbs) which are embedded in the LCD display. The display has 4 ccf tubes inside of it that provide the backlighting. if any of these tubes are bad the backlight inverter will shut off after about 1 second. Because there are 4 of these tubes inside the screen you may not notice ( brightness wise) if 1 of them is out.
You can buy another backlight inverter( about $70.00 US) however, from my experience that would be a waste of money. Unfortunately, I think your problem probably lies in your LCD and the backlight tubes are not replaceable.
Hope this helps all who have this problem.
Good luck
Jim
Oct 28, 2008 | Elo 17' LCD MONITOR, TOUCHSCREEN, 1280 X...
Elo Touch Screen wont stay on!!
Hoya
I spoke with ELO techsupport and they said that I have a bad backlight inverter. I am looking for replacement parts. Have you found anything? If not, would you be interested in selling your USB controller unit from your monitor? Wake
Jul 08, 2008 | Elotouch 17" LCD Monitor
Aiptek Hyperpen with ADOBE PHOTOSHOP
This may come a little late but Updating your tablet with the latest drivers. Worked for me..
http://www.aiptek.com/drivers.htm#hp12u
Apr 08, 2008 | Aiptek HyperPen 12000U (HYPERPEN12000U)...
Blank screen
elo touch screen ET1925L -7SWA1 i get no picture on the screen but i hear sounds coming ou the back of theespeakers.. could it be the inverter?? help
Oct 24, 2007 | Elotouch 17" LCD Monitor
Elo Entuitive 1545L (Black) 15 in. Flat Panel LCD Monitor Logo
70 people viewed this question
Top Elo Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
Sam DeGonia
Level 1 Expert
shahid_ptv
Are you an Elo Computer and Internet Expert? Answer questions, earn points and help others
