Question about Panasonic Toughbook CF-51 Notebook
My CF-51 will not boot. I get two beeps when I power on, but that is it.
  • Panasonic Master
  • 27,725 Answers
The beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Dec 28, 2010
How do I reset the bios Password on a Panasonic Cf-51
This method may help;
1) Locate and remove the RTC battery
2) locate and remove the main battery and unplug power supply.
3) depress the power button for 30-60 seconds.
you do not have to solder anything to the board if there are posts ic 61,63 on MAIN PCB then just put a jumper across them while you power up. if its just 2 SMD pads just use a needle probe to arc the connection.
Oct 10, 2016 | Panasonic Toughbook CF-51 Notebook
Irql not less or equal blue sreen cf-51
reformatting the disk / restore computer back to company settings...is only the resolution for this...
To reinstall your operating system, you must have a CD drive in your multimedia pocket.
Note: CF-51 (Mk2) and CF-51 (Mk3) can also boot to an external Panasonic USB CD drive.
When the laptop is first powered on, the Panasonic name appears in white lettering with the phrase 'Press F2 to enter Setup' directly below it. When this phrase appears on the screen, immediately press F2 on your keyboard. Put the Panasonic recovery CD in your drive and use the arrow keys to move to the boot tab. Change the order of boot so the CD drive boots first. To do this, highlight the CD drive and press F6 until CD drive is the No. 1 listing. Press F10 to save your changes, exit and follow the instructions when your CD starts running.
Jun 14, 2011 | Panasonic Toughbook CF-51 Notebook
On power up, the "Panasonic" screen will appear,
perform a clean install of new OS.This is due to boot error.
Jan 05, 2011 | Panasonic Toughbook CF-51 Notebook
The lapstop does not boot up. the MP indicator
Please try the following troubleshooting steps:
1 Disconnect the battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Connect the charger (don't connect the battery yet) and try to start by pressing the power button.
Let me know if everything remain same.
Also listen carefully for any beep sounds.
Mar 03, 2010 | Panasonic Toughbook CF-51 Notebook
I would like to restore my cf 51 to original factory settings how do i do it?
Boot with the recovery CD in and ensure the first boot device is CD. Follow on screen instructions.
NB = All data will be lost in this procedure so back up all important data.
If you do not have Recovery CD, you MAY be able to download it from manufacturers site. You will also need Windows CD key handy (Under laptop)
Dec 22, 2009 | Panasonic Toughbook CF-51 Notebook
Panasonic CF-51,s are becoming common on Ebay but most do not have hard drives or caddies installed.The caddies cost more than the computers & are almost impossible to find for sale.Is it possible to...
I found this via pendrivelinux.com:
http://www.pendrivelinux.com/testing-your-system-for-usb-boot-compatibility/
So try that out. I just got a toughbook cf-51 and will try it soon myself. Mine came with an XP reg code so maybe that can run from a virtual machine inside of linux.
My advice is to resist the urge to drop yours onto cement from a couple of feet. Not quite that tough.
The hard drive caddy is "the catch", for certain.
Too lazy to look into what the hdd connector is for that, maybe there's a cable or converter somewhere.
AV
Oct 22, 2009 | Panasonic Toughbook CF-51 Notebook
I have a panasonic cf-51 with 40-gig drive. I want to upgrade the drive with something at least 160 gig. Do you have any drives available? What spec should I be looking for?
Basically, any EIDE interface hard drive will work, if you buy a new drive, just make sure to use the included software to boot the laptop up with in order to initialize the new disc and make it useable on your system.
Sep 27, 2009 | Panasonic Toughbook CF-51 Notebook
Wont power up
yes no reset. your battery got low voltage. recharge by your charger.
May 26, 2009 | Panasonic Toughbook CF-51 Notebook
Beeping Blues
Something has hung up. Try removeing hardware, ie... battery, cd drive, keyboard, etc... until you find the nonessential piece of hardware that is hanging up your boot process. (nonessential to the operating system)
Jun 24, 2008 | Panasonic Toughbook CF-51 Notebook
Toughbook CF-51 Sound
You can download the XP drivers from the panasonic site. CF-51 got many flavors and be sure that your model numbers are at hand when you retrieve the factory installed drivers.
Delete all SigmaTel drivers from the registry hardware section. This would help reinstall the correct driver. The presence of these wrong registry values prevent successful installation of the factory drivers.
I have installed se7en, vista and XP successfully. The sound is really problematic since Dell and Gateway laptops use similar sound chips and offers drivers on the net... but they don't work at all. The Gateway driver seems to install perfectly from device manager report, but only the mic works & no sound.
What I do is install the factory provided drivers in XP compatible mode and then use windows update to download the latest SigmaTel drivers (se7en pre-beta). Windows got a more compatible driver but it can only install over the original since the chips cannot be recognized.
Jun 12, 2008 | Panasonic Toughbook CF-51 Notebook
Panasonic Toughbook CF-51 Notebook Logo
111 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
