Question about Masterbuilt Turk-'N'-Surf's Turkey Fryer
The screw housings for the black piece, that fits on side of machine and allows the heating element to fit into place, has broken on all 4 screws. Do you have a new black piece for replacement?
    Problem Solver:
  • 19 Answers
I was told they no longer make this part. I had the same problem.
Posted on Nov 29, 2011
Replace Heating element DV353EWBEVF/A1
hello . hope this helps . not easy but id doable , plan this when u have some time. how hard to do it yourself 1-10 id say 8
1st unplug the dryer .
remove 2 screws located in the rear top of the dryer , those screws are holding the top panel in place.
once you have removed those screws go back around to the frt of the dryer and with your hands on top of the panel push the top panel back and top panel should lift back and out.
next remove 2-3 screws holding the faceplate (display panel) to the frame , from the inside and unclip the wiring harness and set to the side. next remove 3-4 screws holding front panel to the cabinet of the dryer then reove front panel and set to the side now you can see the heating element enclose in a housing. remove a screw holding the housing and slide housing to you. disconnect the 2 connectors going to heating element. some revisions heaters slides out , some models you must remove a few screws holding element in place. Samsung does sell the heater assy witch comes all together for a few more dollars but less labor. re assemble
Oct 10, 2014 | Dryers
"How do remove a N115 fridge out of its housing to fit a new element"?
screws on bottom by access panel outside then trim piece inside screws on top or bottom
Jul 31, 2014 | Thetford Refrigerators
Where is the heating element located on the kenmore plus pdryer. I purchased it in 1982
on that vintage dryer the heat element was behind the rear panel. When looking at it from the rear with the back panel off it is inside of the housing on the right side. The way to remove it is to raise the main dryer top by removing the 2 phillips headed screws on the top where the lint filter fits and pop up and raise the top and from the front you can look behind the back wall the holds the drum up, from the front on the top of the housing the element fits(left side when looking at it from the front) will be a bracket that holds that heater housing to that rear drum support plate. Remove that screw(5/16th inch hexhead) and go to the back and pull housing out from top of housing then lift off from bottom.When reinstalling be sure the housing fits into bracket and the bottom of where it goes. To remove the element there will be one 5/16th inch hex headed screw at the bottom by where its opened. The part # for that style heat element is 4391960 it is available from your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apdepot.com
apwagner.com
midwestapplianceparts.com
Thanks for bring me back to the old days i started my appliance repair career a year before you bought that dryer (1981)
I hope this has helped you with your dryer,
Gene
Aug 13, 2011 | Dryers
Ge front loading washer door won't unlock
Some machines do this when the power is cut, there should be what looks like a screw heat on the front of the handle which will allow you to unlock the door and open it. If there is still water inside you will need to empty the machine first. There is usually a hatch at the bottom of the unit, open this hatch and you will find a cap to unscrew, unscrewing this cap will empty the contents of the machine onto your floor so be prepared!!!!!
May 08, 2011 | GE Washing Machines
I took apart my eureka quick up vacuum and am not sure how to re assemble
I just did the same thing and had to reassemble also. I recommend turning it upside down. First make sure the belt is wrapped around the motor threads as well as the brush threads, then rest the brush more or less where it goes in the front of the vacuum. The white plastic pieces each have a small hole - you need to insert one end of the brush into each while plastic piece. When you lie the plastic piece flat you should see that the other end fits together with the top of the vacuum. The trickiest part is getting the tiny little wheels into place. Just worry about the 2 in front first. Set them carefully into place in the square holes in the front corners of the machine. Use your finger or a screwdriver to fit the mini axles properly into the grooves. Carefully push the bottom of the vacuum into place until it seems to snap in place (be careful that the wires are tucked in well) and screw in the 4 main screws. Final step is to reattach the smaller black cover to the bottom (back) side - be sure to get that wheel in place before fitting the cover on and then tighten up the final 2 screws.
Mar 25, 2011 | Eureka& Cordless Quick Up Vacuum
My frigidaire dryer LEQ642DS0 will not shut off by itself, would that be the timer or the knob? Also if it is the timer, is the kenmore/frigidaire part #131062300 (timer) compatable with my dryer
Instructions
Things You'll Need:
* Phillips and hex nut screwdrivers
* Replacement thermal fuse
* Replacement thermostat
1. Disconnect the dryer from the electrical outlet.
2. Slide a putty knife between the top panel and front panel on the left side. Slide the knife toward the center of the dryer to release the left-side spring clip. Repeat the process on the right side. Lift the top panel up and rotate toward the back of the dryer. The thermal fuse and thermostat are located along the dryer's back wall, attached to the heating element housing.
3. Disconnect the two wires from the thermal fuse. The thermal fuse is an inch-long rectangular plastic part, located near the top of the heating element housing. Remove the screw holding the thermal fuse in place. Remove the old fuse. Place a new fuse on the housing and replace the screw. Reconnect the wires to the fuse.
4. Remove the wires on the thermostat. The thermostat is a black, oval-shaped part located just below the thermal fuse. Remove the screws holding the thermostat in place and slide it out of its slot on the heating element housing. Slide a new thermostat into the slot and replace the screw. Reconnect the wires.
5. Lower the dryer's top panel and press down until the spring clips lock into place. Plug the dryer back into the electrical outlet.
Feb 24, 2011 | Frigidaire Dryers
How to change the belt?
Yesterday I have the same problem: the belt of my Sunbeam bread machine broke. My problem is I didn't find a belt replacement yet. Once you have a replacement, to change the belt:
1. Unscrew the 4 screws located at the bottom of the machine
2. Open the top of your machine. You'll see 8 screws that put together the bottom of the chamber with the walls. You need to unscrew those screws with a very long screwdriver (caution with the heating element).
3. There is one screw attaching the heat element to a ceramic rectangle to the opposite side of the chamber. Unscrew this TOP scew.
4. Once all those screws are out you have to force the bottom piece of the machine with a flat screwdriver. This bottom is attached to the top part with some clips on the front and the back of the machine.
5. Once you open the bottom "cap", caution when separating both pieces. You will find a flat cable that is connected from the computerized pannel to one card attached to the bottom part of the machine. This plug located on the card at the bottom part of the machine have one drop of glue securing the two parts. Twist off the drop of glue and you can disconnect the cable from the card without any problem.
6. Once both parts (top and bottom) are separated you can proceed unscewing the 7 screws that fix the motor to the plastic bottom "cap". You need to do that to access the bellt area.
7. To place a new belt just unscrew the bolt that fix the large "circle". Take away the bolt, the 2 washers, the rectangle one and the "circle". Place the new belt around the small circle (motor) and the big circle. Return the big circle to its original location (align the square part of the wheel with the square part of the screw) and push it to set it in place. Return the rectangle washer, the flat washer, the pressure washer and screw the bolt to secure the pieces.
8. Put all the pieces together in reverse order: *screw the motor to the bottom plastic piece; *connect the flat cable to the card; *push the top and bottom pieces together and until all the clips fall in place; *screw all the little screws to the botom of the inside chamber; * screw the little/long screw to fix the heat element to the ceramic rectangle; *screw the bottom screws.
AND ENJOY YOUR MACHINE! :0)
Dec 29, 2009 | Sunbeam 5891 Bread Maker
I cannot remove the plate to pute the other plate on
Here's a copy of the manual instructions...
Detail Sanding
Your tool is equipped with a teardrop base which allows you to use it on large flat surfaces
and tight spots or corners.
The pad tips may wear unevenly, depending on use. The pads are designed to allow you to
interchange and /or rotate the diamond tip.
Fitting Sanding Sheets ( Fig. 2)
• Detach the two diamond-shaped tips from the sanding sheet.
If this doesn't provide enough information, take a look at the pictures in the manual at the following link: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/589307-02,MS550GBMS550GH.pdf
If you still have difficulty getting the base off, write back and let me know specifically what the trouble is and I'll try to help you with it.
• Hold the tool with the sanding base facing upwards.
• Place the sanding sheet onto the sanding base.
The diamond-shaped tip can be reversed and replaced when worn.
• When the front part of the tip is worn, detach it from the sheet, reverse it and press it onto
the sanding base again.
• When the whole tip is worn, remove it from the sanding base and fit a new tip.
Tip of the Sanding Base ( Fig. 3)
When the sanding base tip is worn, it can be reversed or replaced.
• Remove the screw.
• Reverse or replace the worn part.
• Fit and tighten the screw.
Finger Attachment ( Fig. 4)
The finger attachment is used for fine detail sanding.
• Remove the screw.
• Remove the diamond-shaped tip holder from the sanding base.
• Fit the finger attachment onto the sanding base.
Contour Holder Attachment (Fig. 5)
• The contour sanding pieces are for sanding curved surfaces and grooves.
• Remove the screw.
sanding base.
• Fit the contour holder onto the sanding base.
Fitting and Removing a Contour Piece (Fig. 6 & 7)
• Choose the contour sanding piece profile most suitable for your application.
• Place one end of the contour sanding piece into the recess at
the front end of the profile holder.
• Push the other end of the contour sanding piece until it clicks
into place.
To remove the contour sanding piece, push it forward then pull the rear end out of
the profile holder (fig. 7).
Fitting a Sanding Sheet Onto a Contour Sanding Piece (Fig. 8)
• Align the sanding sheet with the contour sanding piece.
• Press the sanding sheet onto the contour sanding piece, making
sure that the sanding sheet follows the shape of the profile.
Mar 23, 2009 | Black & Decker MS550GB Mouse 5 Amp Detail...
I can't seeem to find out how to put the new lamp back into the t.v
if this is either of the 51" or 56" DLP tv's, it is very simple.
-Make sure tv is UNPLUGGED!
-Open the side compartment on left side of tv as you are facing it from the front.
-Take off the door and you will see the lamp housing.There are 2 screws facing you.Unscrew these and set the screws aside.
-Now pull on the housing a little and it should slide out.You may need to wiggle it a little.
-Set housing down on table or somewhere with good light.Make sure not to touch bulb of either the old lamp or new as oils from fingers can distort picture.
-Now,undo screws on shiny metal piece.There are 2.Take off metal housing piece.
-You now see the back of the bulb.If you look at the lamp from the front,you will notice where the 2 wires are fitted into a bracket with 2 screws.
-Unscrew those screws to loosen the bracket.The replacement lamp should have the exact same bracket.If not you can just undo the wires to the old lamp and connect the same wire harness to the new one.
-once the wire bracket is unscrewed, pull it out of its fitting and then unscrew the 4 screws holding the lamp in.
-Take notice of how the shiny metal clamp-fitting is situated to hold the lamp in place so you can put it back on the right way.
-Once loosened, the bulb should be able to come out and you can put the new one right in it's place. Make sure to keep the top wire connector on the bulb at about 11 o'clock and that a nub on the bulb fits through a spacer on the shiny metal clamp-fitting.
-Now tighten the 4 screws on the clamp-fitting and make sure the wire screw connectors on bulb are tight as well.
-Take the now loose rubber-covered wires and tighten them into the bracket-fitting the way the old ones were,with plugs and lamp facing the same way.
-With everything now tight,put metal housing back on and tighten the 2 screws down.
-Take the whole unit and slowly slide it back into the tv making sure that the plugs slide into their rightful place.This should be easy,but may require a wiggle or two.
-Now screw in the 2 screws you have left into the plastice mounting piece. Re-attach the door and plug the tv in.Wait a few minutes and then turn on tv.
-It should work.If not, unplug tv and check all connections.
TIP:Do not put a cold bulb in and then turn on immediately.I like to let the bulb sit in the tv with it plugged in for a while until the bulb is warmed and ready.
Good Luck! -Chris
Mar 10, 2009 | Vivitek V37835 46 in. LCD Television
Hoover Floormate wheel assembly
You must remove the top gray piece it has six tabs 2 in front, two in back and 2 on sides where the foot pedals are. Be very careful not to break them. Then you cn remove screwsa nd install the piece.
Oct 22, 2007 | Hoover Floormate H3000 Upright Wet/Dry...
Masterbuilt Turk-'N'-Surf's Turkey Fryer Logo
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
