Question about Whirlpool Dryers
No heat but the dryer electrical system is ok
  • yadayada
    yadayada Dec 28, 2010
    Electric or gas dryer?
    Novelist:
  • 222 Answers
Check the thermostat or sensor of dryer,that one is connecting to heater if this sensor or thermostat worn out no power go to heater of dryer.
Posted on Dec 28, 2010
Ge Dryer 4 years old model DBVH512EF0WW no heat power is good to dryer heater ok thermostats ok PROCESS OF ELIMINATION LEADS ME TO a power board above drum, diagram says it has some relays on the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Sep 10, 2011 | GE DCVH515EFWW Electric Dryer
Dryer is not heating but otherwise ok
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 23, 2011 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
No heat. Elec. power OK. 12 years old
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 19, 2010 | Whirlpool WGD5200TQ Gas Dryer
Electric dryer not heating. breaker ok
heatman101
Nov 11, 2010 | GE Profile Harmony DPGT750EC Electric...
Dryer want heat up? Fuses checked, ok.
heatman101
Oct 15, 2010 | Roper REX4634KQ Electric Dryer
Gas dryer starts ok. After the first cycle igniter comes on but flame does not. It only works ok again after dryer cools down again. What dryer part could be bad?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 13, 2010 | Dryers
NEW Electric Whirlpool Cabrio Steam Dryer; NO HEAT
Check temperature sensor.  Check to see if heating element is OK.
May 29, 2009 | Whirlpool GEW9250 Electric Dryer
Intermittent heat in our GE electric dryer
Hello Makathi,
Your problem may be related to a few things.. Depending on the age and use of your dryer, your heating element may be on its way out ( meaning that the element itself is eroding to a point of it not getting hot enough and will eventually open and need replacement) but.. you could have other issues too that affect the dry time.. You need to verify that your exhaust system is free from lint and is NOT restricting air flow out. You could have something in the blower itself that restricts air flow. Those are the basic components associated with your system dry process. If I were there, the very first thing I would check is the exhaust path out of the dryer ( including the end diverter to make sure that isn't restricting flow) Since yours is an electric dryer, you could do a simple test indoors by detaching the exhaust line and running the dryer inside for a short time.. The byproduct of electric dryers isn't as dangerous as a gas system so its ok to run it that way to check the flow coming out of the dryer,... Chances are one of the things I mentioned will solve your problem.. I'll keep an eye out for your feedback.. Hope this helps you
Regards,
Rick
Nov 22, 2008 | Dryers
Kenmore gas/electric dryer
theordis:
When you say electrical power is working Ok ,I would assume you are saying this because the dryer is tumbling.
Which could mean you are only getting 120 volts to the unit but it will not heat with out 240 volts.
If you are getting 240 volts.
You could have an open thermostat, an open heating element. A bad timer contact or a open switch on the motor.
All these can be tested with a Volt-Ohm meter.
((((The Electrical supply must be turned off and at least one wire dissonnected from the component being tested.
woodychoppers
Aug 13, 2008 | Kenmore 75944 Gas Dryer
No Heat - Electric LQC Test OK
Try and re-set your 220V breaker one time ,because your dryer will run 120V for the motor to run,and the other 120Vsupplies the electricity to heat the coil.Small chance it could be half the breaker is off.Second, if the advise above doesnt correct it than odds are its a bad igniter.Some dryers have a amall re-set on the high limit thermostsat
Apr 26, 2008 | GE Profile Harmony DPGT750EC Electric...
Open Questions:
Dryers Logo
32 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
