Question about Linksys VOIP VONAGE PHONE ADPTR 2-PORT PAP2 Router
Hello, I have a Linksys PAP2-VN VoIP adapter from Verizon Voicewing which you know is now defunct. I cannot access the web setup utility because it requires a password that was set up by Verizon and I cannot get it from them since Voicewing is defunct. My phone number was 302-226-8306 in the U.S. Do you by any chance know the passwords/usernames that Verizon used on these devices? I would love to be able to use on on another VoIP service. Thanks in advance for your assistance. Regards, Ed Scherer
  • 2,385 Answers
HelloThe Password/user name will provides you by Verizon, try admin:admin
Here is a list of the most prominent VoIP services providers of this type but better service:
1. Vonage 2. Lingo 3. Voip.com 4. BroadVoice 5. Packet8 6. ViaTalk 7. AT&T CallVantage
Hope it helps, if so do rate the solution Good Luck
Posted on Dec 28, 2010
Password recovery on PAP2
There is a hard reset that can be done via the phone IVR. Connect an analog phone to the RJ-11 port on the PAP2 and pick up the handset, where you will hear dialtone. Press * (4) times and you will be told you are entering the configuration menu. Press 7 3 7 3 8 + # and you will be asked to enter 1 to confirm. Congratulations, you factory-defaulted your PAP2, the adapter will restart and you can log in with the default user name 'admin' with no password.
Mar 06, 2011 | Linksys SPA-2102 NA Analog VoIP Adapter...
Hello,I have connected a linksys voip
Hello dandashi77,
I am using a Panasonic DECT 6.0 Series cordless phone. However, the VIATalk.com VOIP Services uses a LinkSys PAP2 adapter which can work with any type of phone. A Broadband connection is required to use the VIATalk.com VOIP service. Setup is very simple and the instructions areeasy to follow. Just a few simple things to do.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Jul 30, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Connect my phone adapter
You need to register/subscribe to a VOIP provider first like Vonage and the likes. Then you need to register through your VOIP provider the phone ports of your router. ISP is different from VOIP.
Oct 24, 2008 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Linksys SPA2102 interfearing with winmx/360 sharepro, frequently resetting connection
If your planning to connect the phone adapter behind a router make sure that the following ports are open/forwarded on the router; UDP ports 5060-5061, UDP ports 16384-32767 take note that 5060 and 5051 one are SIP ports and must be assigned to the IP address of that was assigned to by the router to the adapter or the IP that was manually configured on it.
I found a link that could help you check the setting on your linksys phone adapter
http://www.voipvoip.com/linksys-pap2/
Hope this will help you solve your VOiP problem...
Regards,
Sep 11, 2008 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
How can i unlock linksys mode pap2-vn?
The only way so far to unlock this is to request Vonage to do it since the VN unit is locked to Vonage.
May 31, 2008 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
I have a linksys PAP2-NA VoIP adapter. I want to lend to my customers but want to lock the access to admin so they cannot see my settings
Hi rajahc,
That's easy (as long as your voip provider didn't locked it themselves), just log-in to your PAP2's setup page and set the user and or admin password under the system tab. Hope this helps
Cheers and best regards,
May 09, 2008 | Computers & Internet
Port forwarding
try this.
1.Access setuppge of the router through http://192.168.1.1
2.User name admin Password is password
3.Once you are int he setup page on the left side click port forwarding
4.You may need to ask linksys what are the ports needed to open for the PAP2 device that you have aqnd get its IP address.
Apr 18, 2008 | NetGear WGR614 Router
Not able to connect my voip adapter to internet
hello sir iam working for voip and iam a tech?
and u r using linksys pap2 which is not a router its just a phone adapter so it will work through a router so try this first
is ur modem is a modem router and u have 4 ether net port on it and u can able to access inter net through hard wired and connect this pap 2 adapter through one of the ether net jack on the modem router (ut starcom)>an dit has a fire wall which block ur voice signals so u need to open some ports on it try this link to open all ports and u need to try this with a pc which connected through hard wired on the modem router go to through this link
http://www.portforward.com/english/routers/port_forwarding/UTStarcom/UT-300R2U/Vonage.htm
and also disable the fire wall on the router screen and reboot the linksys pap2 and ur ut star com modem router also and connect ur phone directly to phone jack 1 on the pap 2 device if u have any issues let me know
and rate me solved if its helps thx
Dec 04, 2007 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Fax thru pap2
NOTE: Set the following parameters under Line 1 or Line 2 tab, depending on what Line the fax is registered to.
Step 1:
Access the PAP2’s web-based setup page.
Step 2:
Once the PAP2’s web-based setup page appears, click Admin Login then click switch to advanced view.
Step 3:
Click Line 1 or Line 2.
5185-003.png Step 4:
Look for Network Settings set Network Jitter Level to high.
5185-005.png Step 5:
Go to the Audio Configuration section and set Silence Supp Enable, Echo Supp Enable and No Echo Canceller to no. Set FAX Passthru Method to NSE, FAX Passthru Codec to G711u and Use Pref Codec Only to yes.
5185-007.png Step 6:
Go to the Supplementary Service Subscription section and set Call Waiting Serv and Three Way Conf Serv to yes.
5185-009.png NOTE: If the above settings did not work, please power down the PAP2 and power it on after 30 seconds.
Step 3:
Nov 30, 2007 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Linksys VOIP VONAGE PHONE ADPTR 2-PORT PAP2 Router Logo
602 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
