Question about General Electric SCA1001KSS 900 Watts Microwave Oven
Door is very hard to open - General Electric SCA1001KSS 900 Watts Microwave Oven
Door hard open
It sounds like the hinges are worn out or broken. Probably cheaper to buy a new one that to fix the old one.
Oct 15, 2014 | GE Advantium 120 Convection/Microwave Oven
How to fix the door button on panasonic microwave t6648fx?
Clean the inside edge of the door and oven where it contacts the door. Grease or oil is preventing the door to swing open.
Aug 28, 2014 | Panasonic Microwave Ovens
Kenmore quick touck microwave, door latch hard to open & shut
If your want to start the easy path, get a Q-tip and some light weight grease and lightly grease the door-switch levers inside the door latch holes and see if that solves your problem. If not, then you will have to remove the cover, and likely you will find the door switch assembly and it's metal mounting support are bent on something of an angle - the switch assembly should be at 90 degrees to the front of the microwave oven so that he door latch fingers can slip in and activate the control switches easily all at the same time - straighten the switch frame which may require you to remove the switch bank temporarily. The little bit of grease still doesn't hurt to do it.
Reassemble.
May 11, 2014 | Microwave Ovens
Our Kenmore Microwave Hood combo model # 401.88529011 door sticks and is very hard to open off and on
Possible that the door lock is jammed, it can also be due to jamming of the door switch or the plastic lock being stuck on.
You need to remove the front panel , and reset the door assembly.
Jan 25, 2013 | Kenmore Microwave Ovens
My microwave turns on with the door open?
Check the door switches and mounts. See this help file.
Dec 17, 2011 | Sharp Microwave Ovens
We have a GE Profile microwave and every time we open the door it trips the breaker. We turn the breaker back on and use the microwave and as soon as the food is done cooking and we open the door - bam,...
For a breaker to trip, you have to have an over voltage condition that is usually referred to as a short. Since your unit works in the cook cycle and only trips the circuit breaker when you open the door the short has to be in the door latch switch or reset circuit. So it wouldn't be that hard to repair, but since it is 7 years old and not the most energy efficient unit, if you aren't able do the repair yourself, then I would replace it!
You can get an idea of how hard the repair would be by going to the searspartsdirect.com web site and putting in the model # off the ID TAG. Then look for the door latch assembly and that will give you an idea of the cost of the parts and get an idea of how hard it is to replace.
Aug 07, 2011 | Microwave Ovens
Sub-Zero 601 F - when the door closes is re-vacumn seals and take 3-5 minutes before you can re-open the door. Is this time adjustable to something less? This is very inconvenient when working in the...
Q: Why is my door hard to open?
A: Your unit was designed for an airtight seal.
A vacuum seal can form after the door is closed. Wait several seconds for pressure to equalize before reopening the door.
I have had this problem as well. A quick solution is to put a thick straw between the seal and the unit. this usually makes it easier to open. Don't forget to remove it though.
Mar 27, 2011 | Microwave Ovens
Door Release Button not working on Panasonic Microwave NN-T664SFT
The problem I had experienced with the Door not opening easily will be resolved by removing the micowave oven top cover with a tamper proof torx head, replacing the door switch and reinstalling the top cover.
Jan 19, 2010 | Panasonic Microwave Ovens
Door is hard to open
you can solve this yourself by removing door pins and straighting the hinges
Jan 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp Microwave model R-1850A door won't open
Hi ,there are two posibility to repair . 1. by ordering parts to the web site of sharp .
2. You may check from shop same type of part bring sample or in the appliances center near you.
Jan 14, 2008 | Sharp R-1850A Convection/Microwave Oven
General Electric SCA1001KSS 900 Watts Microwave Oven Logo
49 people viewed this question
Top General Microwave Ovens Experts
William Miller
William Miller
ken skalski
john h
Are you a General Microwave Oven Expert? Answer questions, earn points and help others
