I have an older-model GE washing machine. About 2 weeks ago I went down to put clothes in the dryer & the washing machine was still full of water but the dial was in the "off" position. I tried pushing in the dial and pointing it at the "spin" icon. It made a quiet noise like the motor was trying to spin and couldn't. I tried this a few times & finally it started spinning. This is how I've been operating it since, and sometimes it wouldn't make ANY sound when I moved it to "spin", but when I left it pointing to "spin", I would return an hour later & it had spun. A couple of days ago I did a load of towels & I nothing I did would make it spin so I ended up wringing out the towels and drying them. Is there anything I can do to fix this problem or am I better off just buying a new washer??
  • 57 Answers
Sounds like your timer is going out. Turn it to the spin cycle and see if it'll spin. If not jiggle the timer handle and see if that does it. If it works after jiggling the handle then you need a new timer which can be expensive. Or on the cheaper side it could also be a lid switch but sound more like a timer. Check the lid switch also.
Posted on Dec 28, 2010
Why do my front load ge washer leave lint on the clothes?
A lot of build up from front loaders is caused from "scrud" excess detergent or constant cold water use. Place a cup full of Epson Salts in the machine and run through a hot wash cycle every 4 weeks or so and this will help keep bowl clean.
Dec 03, 2014 | GE Washing Machines
Ge washing machine fills up with water on spin cycle
Sounds like the timer is screwed... Sending out the wrong signals and the dryer is doing the rinse cycle when it should just be the spin cycle. Do t know what your timer looks like in that washer but most now days look like the picture. 11_11_2013_2_52_52_am.png
Aug 16, 2013 | Washing Machines
Washing machine leaking
It sounds like the water valves are not shutting off completely.
You have faulty water valves & need to replace the leaking one.
Jan 30, 2013 | Fisher and Paykel Washing Machines
Wont get hot and dry clothes
If the dryer runs the same as before except it will not get hot then check your heating element that is more than likely your problem.
Sep 04, 2012 | Maytag MDG6400 Atlantis Gas Dryer
Older Ge Hotpoint Dryer will tumble but not light the gas to heat
You state it is an older dryer, so I'd suggest replacement. The water may have damaged numerous components, including the motor, which would be costly to replace.
Aug 28, 2009 | Hotpoint NWSR483GBWW Gas Dryer
I bought a GE front load washer last year model # WCVH6260HWW now I'm having problems with it. It keeps shutting off during a load. I push the Start/Pause button to get it going again, sometimes 3 or 4...
I have the same problem, and I believe it is because the filter is full. I'm tracking down the repair process now.
PUMP FILTER CABINET, COVER & TOP PANEL 285 WH23X10029 $68.00
I've downloaded the exploded view from GE.
Jul 01, 2009 | GE Washing Machines
GE Clothes dryer squeaks
My ge electricryer sqeaks very loud and makes a thumping noise. it just started a cuouple of weeks ago.
Jun 19, 2009 | GE DWXR483EBCC Electric Dryer
GE top load washer w/no lint trap leaves excessive lint
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
Jan 08, 2009 | GE WBSR3140DW Top Load Washer
GE WSM2780W Stacked Washer spin cycle
With no clothing in the wash tub take the following steps:
1. remove the front cover from the wash tub
2. run a full cycle of laundry and observe the tub's behavior
Potential Solutions:
A. If the tub begins to shake wildly during a full wash cycle with no clothing in it then you will need to adjust the 3 large springs on each side of the tub until the unit is working in a more-balanced position. This is simple to do by hand. If the tub appears to be shaking too far forward, then unhook the 2 large springs in back so they are tighter. Then run a full wash cycle again with no clothing.
* note: there are smaller springs too - you don't have to adjust these to fix your issue
B. If the tub works fine with no clothing during a full wash cycle, then try to load your clothing in a more balanced fashion. For example: if your wash load is only a small kitchen or bath rug then when the unit spins it will spin off balance with a wet & heavy item on only one side of the tub.
C. If you'd like to replace the 3 large springs, I can get you the part numbers. There are specific springs for both sides of the wash tub and they are different part numbers. The full replacement of the 3 large springs can be done by hand.
thanks,
Chris I.
Sep 24, 2007 | GE WSM2780W Stacked Washer / Dryer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
