Question about Nike Hpi Savage Flux Tork 2200 Motor 25 Volt Brushless
I have a problem with Slipping Clutch on my HPI Savage Flux. It keeps slipping even after I tightened it. Less than 5 seconds on the gas is slips again. Please let me know my truck is brand new. Only ran it for 2mins! thanks!
5 speed losing power when accelerating. high rpms but no power
sounds like a clutch slipping replace it or tighten up the cable....
Aug 17, 2015 | 2003 Dodge Neon
Savage xl 5.9 clutchbell keeps striping and or the teeth bend any solutions
Replace BOTH gears and make sure there is a little play in tooth contact!
Jan 31, 2014 | Savage Xl 5. Rtr Nitro Monster Truck With...
Something isn't catching
Your clutch is slipping, doing this might ruin the flywheel. I cannot tell if this is wear or more likely an oil leak (slipping that much is normaly accompanied by lots of smell and smoke if it is a slip, not with oil leak though)
Oct 27, 2009 | 2004 Mazda 6
'94 VW Jetta III - clutch ''slipping''
I would have the clutch adjusted
Aug 01, 2009 | 1994 Volkswagen Jetta
Rpm spikes
it sounds like the bands on the transmission are slipping if it is an automatic trans if it is a manual the clutch is slipping if auto take to dealer. if manual adjust the clutch cable out some it connects to the transmission with a thick cable near the bell housing tighten the cable to give it less play 3 or 4 turns
Jun 23, 2009 | 1994 Ford Thunderbird
Second clutch slipping after only 60,000 mi. first got 121,000
SLACKEN the clutch cable. I had the same problem with my wife`s Legacy - as the clutch plate wears, the cable tightened up. It started to slip. When I asked the Subaru dealer to adjust it they TIGHTENED it even more, and said the clutch was slipping because worn out, and needed replacing. It took three minutes to slacken it off myself and the car has now done another 20,000 miles with no clutch problems. No wonder Subarus are now so rare in rural areas! The adjustment is right at the back of the engine in the middle under the firewall. You may need top adjust the "HillHolder" cable as well. DON`T PANIC! It`s easy AS
May 26, 2009 | 2000 Subaru Outback
Nike Hpi Savage Flux Tork 2200 Motor 25 Volt Brushless Logo
163 people viewed this question
Top Nike Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Nike Toy Expert? Answer questions, earn points and help others
