Question about Microwave Ovens
Hi i have a problem with my servis m6725w washin machine it drains and fills but wont spin the drum at all
    Brigadier General:
  • 8,909 Answers
Motor brushes? Thyristor on control board? Belt broken? Not a lot else it can be.
Posted on Dec 28, 2010
My washing machine do not spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 31, 2011 | Microwave Ovens
My bosch washing machine is leaving a grimey residue in the drum after the wash. I have tried to run the machine without any clothes to see whether it was simply not emptying properly but that's fine -...
This bosch washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2011 | Bosch Microwave Ovens
Keurig Coffeemaker says to descale. How do I do that?
Hi, unplug the coffee machine and remove the cup.
Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
Unplug the machine and dump the water into the sink.
Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue.
Apr 28, 2011 | Microwave Ovens
Not filling up
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 16, 2011 | Microwave Ovens
Machine goes thru all the wash cycle but gets to last min and keeps spinning then comes up with f11
Not knowing what sort of machine you have, one of these should help.
F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
F11 - Pump cannot be activated - Book a washing machine repair.
F11 - Heater timed out. The heater has not reached the required level. Book a dishwasher repair.
F11 - No pump connection - Book a tumble dryer repair.
Mar 17, 2011 | Microwave Ovens
DRUM MOTOR NOT WORKING TO TURN DRUM. PROGRAMMER OPERATING OK AND ALSO PUMP MOTOR. HOT AND COLD WATER FILLING MACHINE OK AND EMPTYING OK.IT WOULD SEEM TO BE THE MOTOR AT FAULT? THE MACHINE IS 6 YEARS...
Your question was head "microwave ovens" but I think you are talking about a washing machine.
Replacing the motor is a matter of judgement as to the reliability of the machine generally.
If this is the first time the machine has failed in 6 years, then I would have the motor replaced.
If there have been a series of faults, then replace then machine.
(Incidentally I assume that you checked the drive belt).
Jan 06, 2011 | Microwave Ovens
Bosch w/mc will not spin, just fitted new brushes to motor but it still wont turn.control unit seems to be working as will fill and drain but will not spin.
Depending on the model, the control panel has a triac on it. That fails giving the idea that the brushes have failed. BT139 I think from memory. Large transistor style component with three legs.
Jan 04, 2011 | Microwave Ovens
When i put it on i put the washing in then set it to programme then it fills up with water then makes a grinding noise it does not make the noise when it spins
The drum bearing is worn. A replacement will sort that out. They are not to bad to fit. Remove the back panel, put some thick cloth or cardboard on the floor and put the machine face down (after draining the filter and drum of water!). All will reveal itself when the belt is removed and the pulley is taken off with a tripod type puller. Remove the old bearing from the shaft and housing and replace with the replacement one. Bearings are readily available from online stockists are are fairly inexpensive.
Hope that helped.
Oct 20, 2010 | Microwave Ovens
Washing machine not spinning
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 08, 2010 | Siemens Microwave Ovens
Wash cycle wont finish start button does an 8 flash cycle
Hi, these machines get corrosion in the door safety switch. I would start there.
A little cleaning of the contacts might get that machine going. How about a repair manual?
I have a few:
http://docs.google.com/fileview?id=0B5If-wTgYWH5ZmJjMzhhMmYtNTI1Zi00MDExLThiNTMtYmE0NzQ3OTdmNGFi&hl=en
Take care
Apr 11, 2010 | Microwave Ovens
Microwave Ovens Logo
62 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
