Question about Proscan PS50700 50" Rear Projection Television
Need to replace on off switch not working where do I find one
    Brigadier General:
  • 8,909 Answers
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, and a list of Dealers for spare parts, as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
There will be lots of TV repair places that will have one if you remove the broken one as a sample.
I hope this helps.
Posted on Dec 28, 2010
06 300c drivers side window not functioning after replacing door switch
must have pull a wire loose in there check and fix as needed
Mar 17, 2015 | Cars & Trucks
My trigger switch works sometimes and then other times the trigger switch doesn't work and my light goes dead. Do I need to replace the switch and if so can you buy them.
Either the switch is bad or the wires going to/from the switch are loose and making intermittent contact. You need to open it up to see whats happening.
Feb 27, 2015 | Channellock Channel Lock 4v Dual Driver
GE Monogram ZV950S D2SS range hood - lights on one side stopped working then on both sides. This happened as I was changing bulbs. Everything else works.
Light doesn't work
  1. Light bulb
If your refrigerator light does not power on, the first thing to replace would logically be the light bulb itself.
  1. Light assembly
If your refrigerator light does not power on and you have replaced the bulb, this is an indication that the light assembly may have malfunctioned and will require replacement.
  1. Light switch
If you notice that your refrigerator lights are not working, replace your refrigerator light bulb. If this does not correct the issue, proceed to check the power light switch.
  1. Door switch
If your refrigerator light is not working and it is not the bulb itself or the power light switch, the next thing to check is the door switch. This can be checked for continuity with an ohm meter. If there is no continuity present, the door switch will need to be replaced.
  1. Light socket
If your refrigerator light is not working after replacing the light bulb, check for a possible damaged light socket. If the socket is faulty, replace the part to get your refrigerator light to power on again.
  1. Light board
If the refrigerator light is not working the light board could be defective. The LEDs on this board are not repairable, so the entire board will need to be replaced.
Feb 15, 2015 | GE Refrigerators
On/off switch
you will need to replace the switch, if it is combined to a control board you will possible need to replace the complete board. if you are ok with unplugging when not in use that works too
Mar 02, 2014 | Franklin Chef 85lb. Ice Maker FIM90
Ignitor not working
This sounds like the switch for that specific burner is bad. You will need to order the switch for that particular burner. Sometimes it is the entire harness that will need to be replaced because all the switches come as a set. The front or top switch panel will have to be removed to replace the switches. Turn off the power before attempting any service.
May 01, 2013 | KitchenAid Kitchen Ranges
How do you change a blower motor control switch `
you must replace head unit, as an assembly no way arround that I know.
Aug 07, 2012 | 2007 Toyota RAV4
I have a 2002 protege a/c wont work on all blower speeds and my friends 2000 blower will only work on 2 settings
Replace fan switch in dash.Or may even just need connections cleaned with some wd/40. To replace switch you need to remove dash and knob's, Then you have a switch that has the wires from fan to connector. . If these are ok and clean you need to replace your blower motor, Best of luck to you.
Apr 04, 2011 | 2003 Mazda Protege
LEFT TURN LIGHTS WILL NOT WORK ON 1993 TROOPER
believe it or not, a 4 way flasher can cause this even if it itself is working properly, otherwise flasher, bulbs, or switch is bad .
Oct 06, 2009 | 1993 Isuzu Trooper
Aloha Breeze Ceiling fan M# 29081, Fan Switch Problem
call 1-800-295-4448
you need a switch from them the internal mechanism is different. its free of charge
Nov 14, 2008 | Aloha Housewares (93645) Ceiling Fan
Proscan PS50700 50" Rear Projection Television Logo
46 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
