Question about Mytopia Spades Master
Whenever i try to log onton spades master Mytopia it gives me a connection timeout error. how do i fix this?
GO GET FIREFOX AND GET THE FLASHSWITCHER ADD-ON IT WILL CHANGE YOUR FLASH AND YOU CAN GET ON THROUGHT FIREFOX! AND THE BOTTOM RIGHT CORNER YOU WILL SEE A F IT WILL BE IN A BUBBLE CLICK ON IT GET VERSION 9.0 THEN YOU SHOULD BE ABLE TO PLAY THATS HOW I GET ON
Posted on Jan 26, 2011
I keep getting an error 504 when trying to connect to a website. What is this and how do I fix it
A 504 error is a Gateway Timeout and is a problem on the website side not with your computer or internet connection. Try doing a reload or waiting for a while then try again as the server problem may be temporary or perhaps just a scheduled reboot.
If you continue to receive to the 504 then you should contact the website concerned to notify them of the 504 timeout.
Oct 17, 2013 | Acer Computers & Internet
Service code interrupt
Error type T11 [Pressure-control motor lock]
T11-***
!!System Error!!
Press Reset Key
If Recovery has Failed, Call Service
Reset method Jam reset or switch on power again
Error point Error conditions
600
Timeout error for reducing pressure (OFF -> ON) during print-pressure home
positioning.
601
Timeout error for increasing pressure (ON -> OFF) during print-pressure home
positioning.
602 The print-pressure limit sensor does not change during print-pressure operation.
620 Print-pressure operation was called with the print-pressure motor locked.
621
Incorrect print-pressure operation timing (print-pressure operation command was
received when the print-pressure should not change).
622 Sensor A is ON and sensor B is OFF during movement from area A to area D.
623 Either sensor A or sensor B is ON during movement from area D to area A.
624 The current area data is undefined.
625 The target area data is undefined.
626 Timeout during relative print-pressure movement.
Error type T12 [Master-disposal-section motor lock]
T12-***
!!System Error!!
Press Reset Key
305
The master compression sensor does not go ON within 6.5 s after the master
compression motor operates in the return direction.
306
Master compression sensor does not go OFF within 2 s after the master
compression motor operates in the compress direction.
307
compression motor operates in the compress direction, and the mastercompression-
motor limit sensor cannot count up until the compression-limit
position.
309
The master-compression-motor limit sensor does not change within 200 ms
during compression operation.
hope to be of help
Sep 27, 2013 | Riso RP 3700
Log in problem in my symbian device
There is no single system error log on Symbian OS. There is a system logger, of course, but each component/subsystem logs to a different place and has a different policy on how/if logging can be enabled. Unfortunately, IIRC the messaging components only write log files in debug builds, which isn't going to help you on a production device.
Tech Support ' Compute Support
Feb 15, 2013 | Nokia 5233 Mobile Phone
The server encountered an internal error or misconfiguration and was unable to complete your request. Please contact the server administrator, support@mytopia.com and inform them of the time the error...
Facebook did some sort of upgrade today that has been affecting many of the games. If you check the fan page of your game, they may have posted the same message that many games have done today.
It should be back soon.
Aug 11, 2011 | Mytopia Bingo Island 2
My spades game wont load up?? Please help???
Go to control panel aadd remove programs windows components games unistall (uncheck spades) restart.
Then repeat but install again it should work
Mar 07, 2011 | Mytopia Spades Master
Cant get on mytopia website anymore says connection timeout try again later its a game website cant go thru yahoo or mytopia or facebook
We Can Play in Hi5 the mytopia but there's no have many players not like before its about 20 players playing around visit mytopia.com and play with Hi5 or Android !
-Mytopia Community
Jun 23, 2010 | Microsoft Internet Explorer 7
Cannot connect to wireless network with Vista
I don not think there is a problem with your laptop. It connects to your network when you use the Ethernet cable, because the wired network is yours. As to the 4 networks to which you are trying to connect with the wireless, they must be secured as they should be. If you want to access them (and why would you since you have your own Internet connection), you will have to ask authorization from the networks owners (your neighbors). If they agree, they will provide you with all the information you require to log on and share their bandwidth.
Dec 28, 2009 | Microsoft Windows Vista Home Premium with...
XBOX Console error 07 now error 12
12 - kernel - DVD parameters (PIO/DMA)
Same as #10, only not very common.
10 - kernel - DVD timeout
Actually its almost the same as error 6/7/8. But also make sure the yellow cables are properly connected to the motherboard and the dvd drive.
1. Make sure ide cables are connected good.
2. Make sure the yellow cables are good and properly connected.
3. Still no succes? Try another dvd drive of which you are sure it is working.
6 - kernel - Cannot unlock HDD
If you understand the above, you should be able to understand what this means. It means you are trying to boot up the xbox with an harddisk that is locked in combination with ANOTHER motherboard than you are using it with right now.
What can i do about it, you ask? Well place the harddisk back in the xbox where it came from. After that, UNLOCK the harddisk with the same procedure i explained above (see error 5). Now when the harddisk is UNLOCKED, put it in the xbox which gave you the error. Now when you boot up with the chip ON it should not give you an error anymore.
However when you put the xbox on with the chip OFF your xbox will give you an error. (error 5) So to make sure you can boot original and boot with the chip ON. Next do the same as above: "Boot up your xbox with the chip on. Preferrably with a slayer evo-x cd. Now you choose "Eeprom management." Than you choose: "Lock hdd." It takes one second. After its ready it should say something like "Done"
When it is ready just turn off your xbox. Disable your chip and try to boot original. Now there should be no more error.
7 - kernel - HDD timeout
Most of the times, the IDE cable is not properly connected when you see this error. Please reattach the ide cable. Not only to the harddisk drive but also to the dvd drive. ALso try to reconnect the ide cable to the motherboard.
Press pretty hard so it goes all the way in. Make sure it is seated straight and proper in the drives and the motherboard. If you still have an error 7. Try another ide cable. If that won't work try another harddisk. If there is still no go, try to set the jumpers on the rearside of the harddisk drive. Set it to master or cable select.
8 - kernel - No HDD found
Please make sure your xbox hdd is attached properly. Most of the times the Ide cable came loose, or isn't seated properly in the IDE port of your harddisk. ALso make sure the power supply cables are intact and working.
Make sure the ide cable is also connected properly to the rest of the hardware (dvd and motherboard).
Dec 26, 2007 | Microsoft Xbox Console
Tcp slave messages are not forwarded to rtu master
I think your last sentence there might be what the situation really is.  Your not getting a reply back. Maybe you should check the response timeout the gateway has set on it for the slave.  You probably already know a slave’s response time can fluctuate wildly depending on the nature of the request sent, so maybe the timeout setting is too short? Its a place to start. .
Aug 03, 2006 | Lantronix (200.2071)
Mytopia Spades Master Logo
153 people viewed this question
Top Mytopia Facebook Apps Experts
Mirca Sekosan
Mirca Sekosan
Jerry Kramer
Jerry Kramer
David Payne
David Payne
Are you a Mytopia Facebook App Expert? Answer questions, earn points and help others
