Question about AOC CRT Monitor
AOC 7Elr crt Monitor
The monitor screen is working normally but the horizontal output transistor gets so hot it will fail in 10 minutes if the monitor is not shut down. What part is the most probable cause? Please help.
  • 125 Answers
SOURCE: Horizontal output transistor keeps failing
The horizontal output transitor is always connected to the primary winding of the flyback transformer (via collector) and also to the horizontal deflection coil via an electrolytic capacitor. The most likely suspect for damaging the transistor is the fylback transformer. In some countries there are electronic stores that test flyback transformer by winding a few turns on the ferrite core and applying a test voltage. This test will only test the secondary. The primary winding is difficult to test for turn to turn short because the resistance is quite low and you do not know the 'good' resistance.
Posted on May 16, 2007
SOURCE: AOC color monitor model 9g1rs, dead, ** volt, fuse good
Hi
You need to replace HOT(Horizontal Output Transistor) see number carefully before you replace it.
Posted on Mar 18, 2008
  • 1056 Answers
SOURCE: monitor problem
To do an internal repair on a CRT is beyond my level of expertise.
I would leave repairs like that to those that do know. I've heard too many horror stories about what can happen if you don't know your way around the inside of a CRT.
Posted on Aug 20, 2008
SOURCE: AOC 53N PROBLEM
DO YOU KNOW HOW TO SOLDER. IF SO, TRY TO OPEN THE MONITR AND LOCATE THE VERTICAL SECTION AND YOU WILL FIND LOOSE SOLDERS. A SINGLE HORIZONTAL LINE MEANS THAT THERE IS A PROBLEM WITH THE VERTICAL LINEARITY OF YOUR MONITOR. FIND SOMEONE WHO KNOWS HOW TO FIX COLD SOLDERS
Posted on Dec 19, 2008
  • 400 Answers
SOURCE: My Monitor AOC CRT Model F1770 is always adjusting
Try to unplug the power cable from the mains for about 10 minutes then replug and try again.
Make sure all cables are well connected.
Try to test it on another computer if possible.
If that doesnt help then it sounds like a hardware problem with the monitor and you wont be able to repair it your self.
Posted on Jul 24, 2009
My samsung syncmaster 794 monitor light is blinking but monitor not get on
If you tested that to another working CPU but the same problem before, i think that monitor has a problem in horizontal section, check the B+ atlaest 175v if is it normal the power supply is ok, check the H.O.T horizontal output transistor, remove or hang the 3 pins then power on the monitor, if the led did not blinking the H.O.T has fault may be leak,open or shorted.
Sep 28, 2010 | SAMTRON 55V 15" CRT Monitor
Hi
Mar 14, 2008 | AOC CRT Monitor
No power dead set 5en aoc monitor
just try to change the horizontal transistor C5386 or CXXXX... with a new one....
Feb 22, 2009 | AOC 5 En 15" CRT Monitor
Power blink
Horizontal output transistor is shorted or flyback problem
Oct 17, 2008 | AOC CT720G 17" CRT Monitor
Crt monitor problem
try to check the pincusion...
Jun 27, 2008 | AOC LM729 17" LCD Monitor
Monitor not Display
Hi Rey,
Hope this helps you like what I did to resolve this kinda problem. If you can manage to open the chassis/cover check first if the HOT (horizontal output transistor) is good, if good check the SMPS (switching mode power supply) primary and secondary side if there are short filter capacitors, diodes, transistors and open resistors. Major faults to consider is by checking the load of SMPS, control circuit, driver circuit, feedback ckt.
Please let somebody to assist you (a certified technician) how to open the chassis safely due to electric shock. Please be guided accordingly.
Best regards,
Rosener Guyano
Jan 30, 2008 | MPC Computers AOC 7F 17" CRT Monitor
Dead set lg studio works v452 monitor
lg g505 this moniter 5 or 10 mnt woking then hot transister is damaged why this problem ?
Jan 26, 2008 | LG Studioworks 45 14" CRT Monitor
AOC 5En monitor
replace new moitor....
Nov 13, 2007 | AOC CT720G 17" CRT Monitor
May 15, 2007 | ViewSonic E70f 17" CRT Monitor
Crt computer monitor model 6332-03n
Hi, you can try lowering the screen resolution, the color quality and the screen refresh rates. Work from there and observe each setting/increment. soon as the monitor quits, press escape to revert to previous setting. I get the impression that you are familiar with electronics, the problem is your monitor horz. freq is playing catch up and eventually fails. Lowering your PC setting then might do the trick. To lower the settings, right click on desktop, properties, settings tab & advance button - Monitor. Hope this be of some help. Good luck
Apr 24, 2007 | IBM E74 17" CRT Monitor
Computers & Internet Logo
152 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
