Hello: I own a LCD 32"
  • 5 more comments
  • egk3 Dec 29, 2010
    Excelent.........
    When I initially unplugged the set, I didn't wait long enough.
    Happy New Year.
    egk3
  • egk3 Dec 30, 2010
    Hello again:
    I'm sorry to say that my 'Jubilation' was short lived.
    I shut the set off as requesed.
    Turned it back on, picture and sound was there, Next morning same problem.
    TV doesn't boot up properly and all there is, is sound.
    Please explain more about the 'TV Module'
    Ewan
  • egk3 Jan 08, 2011
    Hello
    I'm still awaiting a response from my last email as my the solution and results were short lived.
    Can you explain what the TV Mpdule is and what would it take to repair?
  • egk3 Jan 12, 2011
    This LCD is less than 2 years old.
    Because of my pension budget,trashing the tv is not really an option.
    The events are as such:
    Watching TV, screen goes blank, not black (sound ok)
    Unplugged TV (power off), left for over an hour, plugged back in, TV was ok for half and hour then went blank again.
    The boot up process is that when the TV is turned on initally the screen should go blue with the wording 'Electron' across the middle then to the TV station.
    At this point, when turned on, screen goes from black to a dark grey with some speckling but no 'blue boot-up' window(same idea when you boot up a computer and the Windows logo (welcome to EXP etc.)
    Changed cable outlets and cable but same results.
    Thanks
    Ewan
  • egk3 Jan 14, 2011
    eagle338:
    Sorry for the delay (flu) in uploading the requested photo's. Unfortunately the photo's uploaded to 'ImageShack.us' didn't turn out all that well.
    When the TV is turned on, it now shows a 'dark shade of blue' other than black when off.
    I think I have pushed so many buttons that the source is not the cable TV anymore......anyway, in one of the photo's you can see a small box with the wording 'No Signal'
    Hope this helps.
    Ewan
  • egk3 Jan 14, 2011
    Yes please:
    In my search for information, all I have been able to come up with is from a websiteIn located in the Ukrain, unfortunately they don't do hoiuse calls!
    On the site, it indicates what parts they use. Here is a copy of the paragraph give.
    IN «ELECTRON» television sets the following units are used:
    - Philips and Toshiba picture processors;
    - high-quality and reliable Samsung, Panasonic, LG-Philips, HUA FEI (Philips), Irico picture tubes;
    - Sharp, LG-Philips, CMO (Taiwan), AUO (Taiwan) panels for liquid-crystal television sets (LCD).
    Hope this helps
    Ewan
  • egk3 Jan 19, 2011
    Again sorry for the delay, I was waiting for your reply to my last email but failed to expand the tab 'view more comments'
    I will remove the cover plate and get the Part # to you later today.
    Ewan
  • 4,889 Answers
It sounds like you have a malfunctioning T-con board. Can you please take a picture of the screen, upload it to imageshack.us and get me the link so that I can see for myself?
Posted on Jan 12, 2011
  • 11 more comments
  • eagle338
    eagle338 Jan 14, 2011
    Its a confirmed case of T-con more so coz you can see the no signal message(since you must have changed the inputs by pressing the buttons). It is relatively is easy to replace and is inexpensive. With little care you can do this yourself. I can help you find a replacement if you wish to.
  • eagle338
    All that info is not necessary. All I need is the part number of the t-con board. Unplug the set and remove the back cover. At the top center of the chassis you will see a board with two ribbon connectors(LVDS cables) going into the screen. Just get me the part number off the board that the cables go from and I will find you a replacement and tell you how to replace it.
  • Flugel Jan 18, 2011
    Hello eagle338:
    Sorry if this is the second message you receive, but I'm not sure the first got through.
    I've found the t-con board( I think ) Model# FSP205-4E03. Is this also referred to as the 'power supply'?
    I also posted a couple of photo's on 'imageshack.us' but again, not sure they made it. The model # is of photo 'Back Panel #3'
    Ewan
  • eagle338
    eagle338 Jan 18, 2011
    No thats not it. FSP205-4E03 is the part number of the power supply. The T-con board looks like this . Two ribbon connectors go into the display from the two ports at the top of the tv. Also I could not see the images uploaded to imageshack. You can mail them to vls_powerful2002@yahoo.co.in
    http://im4.ebidst.com/upload_big/9/5/7/1...
    I was afraid of that. The only other board that resembles what you are referring to have all the video/audio inputs soldered to it.
    I've emailed all photo's to your yahoo account.
  • eagle338
    I did not get the images. Note that its yahoo.co.in not yahoo.com
  • eagle338
    The board in the image backpanel 4 looks like it. It can be the backlight inverter but lets see.
  • eagle338
    eagle338 Jan 19, 2011
    Ok. Surething. I will get you the link to the replacement as soon as I get it.
  • Flugel Jan 20, 2011
    eagle338:
    Here is the Part # on the board JLS-05-32E1. Found a link in the net. Uploading a photo of it to imageshack now.
    What makes you think it is the Inverter and not the T-Con as mentioned in the member solution list?
    Ewan
  • eagle338
    eagle338 Jan 20, 2011
    The inverter controls the backlight. In other words, the screen won't light up at all if it fails. Since that is not the issue here I am 100% sure its not the backlight
    OK ao where does that put me?
  • eagle338
    The T-con board that we were discussing about all the while. You said you found the part right? Please go ahead and order it. When you get the part let me know and I will guide you in replacing it.
    No. The last board we spoke of was the JLS-05-32E1 (power board) Back Panel #4 which I found and you dismissed. Correct.
    The board in photo Back Panel #2 PT2670A3 I can't find. Thats the board with all the audio, video inputs soldered to the board., and appears to be the board you are looking for.
    Is that correct?
  • 19,396 Answers
Hi.
A white speckled screen is often given by cable problems or it is a symptom of TCon board malfunction.
Try first disconnecting power for about fifteen minutes. Also check cables and connections at the back of the TV.
If the problem comes back, call the retailer to get the TV repaired. The internal boards (TCon, PSU and main digital controller) must be tested and eventually replaced.
Here an user manual for this model.
Regards.
Ginko.
Posted on Dec 29, 2010
    Genius:
  • 1,126 Answers
The video processor could be locked up do to a small power surge, and if you unplug the set from the wall for 40MIN, it should reset back to normal, if that don,t work, you need the TV module changed out.
Posted on Dec 28, 2010
  • Veril Gillette
    Veril Gillette Dec 29, 2010
    No Prpoblem,Take Care.
  • 10,865 Answers
Hello egk... that tv is no longer under warranty and it sounds like it has more than one problem. I would seriously consider donating it to be recycled and purchasing another one in january or february when the winter sales will be outstanding. Joe
Thanks for choosing Fixya!
Posted on Jan 09, 2011
    It has a year left but I'd have to take it to the Ukraine for repairs!
I just bought a curtis tv with no remote. Is it useless?
No, just get a replacement remote.
  • Amazon.com: Customer Reviews: CURTIS INTERNATIONAL ... www.amazon.com/INTERNATIONAL-Replacement-LCD4686AW-PLED3216A-LCD... Find helpful customer reviews and review ratings for CURTIS INTERNATIONAL Replacement Remote Control for LCD4686AW, PLED3216A, LCD3235A, LCD3227A ...
  • www.amazon.com www.amazon.com/INTERNATIONAL-Replacement-LCD4686AW-PLED3216A-LCD... We would like to show you a description here but the site won't allow us.
  • discount replacement CURTIS tv remote controls original ... www.electronicadventure.us/curtis.htm Enter your Curtis remote part number or the model number of your TV, DVD, Audio, etc in search box, or manually search below:
  • Buy CURTIS LCD3227A Remote Control $29.95 - REMOTES ... www.remotes-express.com/Curtis/LCD3227A.html CURTIS LCD3227A Remote Control This CURTIS LCD3227A is only one of the many Curtis remote controls we carry. Enjoy the full functionality of on-screen menus and ...
  • Amazon.com: CURTIS INTERNATIONAL Replacement Remote ... www.amazon.com > ... > Remote Controls > TV Remote Controls z Amazon.com: CURTIS INTERNATIONAL Replacement Remote Control for LEDVD1975A2, LCDVD2234A, LCDVD199A2, LCDVD2454A: Electronics
  • CURTIS INTERNATIONAL Replacement Remote Control for ... www.ebay.com/sch/sis.html?_nkw=CURTIS+INTERNATIONAL+Replacement... Find best value and selection for your CURTIS INTERNATIONAL Replacement Remote Control for LCD2425A LCD3227A LCD3708A search on eBay. World's leading ...
  • CURTIS LCD3215A LCD3215E LCD3216E LCD3227A LCD3235A ... www.ebay.ca/sch/sis.html?_nkw=CURTIS+LCD3215A+LCD3215E+LCD3216E... CURTIS LCD3215A LCD3215E LCD3216E LCD3227A LCD3235A TV AC 2 AC POWER CORD 0 results. ... Replacement Remote for CURTIS INTERNATIONAL ...
  • Replacement Remote CURTIS INTERNATIONAL DVD6019B ' ... www.ebay.ca/sch/sis.html?_nkw=Replacement+Remote+CURTIS... Find best value and selection for your Replacement Remote CURTIS INTERNATIONAL DVD6019B search on eBay. World's leading marketplace.
  • Redi-Remote CURTIS INTERNATIONAL Replacement Remote ... www.sears.com/redi-remote-curtis-international-replacement-remote... CURTIS INTERNATIONAL Replacement Remote Control for LCD4686AW, PLED3216A, LCD3235A, LCD3227A. This is a custom built replacement remote made by Redi Remote ...
  • CURTIS LCD3227A - RemoteControls.com ' Remote Controls www.remotecontrols.com/product/LCD3227A.html CURTIS; CURTIS LCD3227A; CURTIS LCD3227A. Price: $29.95. Code: LCD3227A. Weight: 1.00 pounds. ... So if you return the remote a few days after the 30 days - no ...
  • May 28, 2016 | Curtis LCD3227A 32-inch LCD TV
    Black screen- fixable?
    probably a faulty internal PSU, changing the capacitors on the on-board PCB should fix it but hard to tell without opening it up and testing.
    Apr 26, 2012 | Hannspree XV32 32 in. LCD Television
    32 " LCD LED PICTURE
    Steve, what is the exact model number of your tv?
    TeeVeeMan2@gmail.com
    Aug 25, 2011 | Vizio L32 32 in. LCD HDTV
    Hi sanyo lcd 40xr10f - has come up with screen saver - have tried everything to get rid of it and return to TV - Television is brand new brought 2 days ago
    Hello
    Just press the display button on its remote control. its manual says that for each press the screen display will come On and OFF. If you feels any difficulty in get rid of this on screen display, get helped from the following way.
    vidit the website www.sanyoctv.com or call 1-800-877-5032
    Mar 19, 2011 | Sanyo DP32746 32 in. LCD Television
    My 37" Vizio, only a little over 2 years old.
    Might be true,might be not.These two websites have most of the tvs industries refurbishes electronic boards for the LCD and Plasma Tvs around.Tries websties Shopjimmmy.com,Ebay.com to buy a refurbish Main logic Tuner signal board for the replacement.
    Nov 08, 2010 | Vizio L32 32 in. LCD HDTV
    Need a sharp 32 LC-32SB21U screen
    Manufacturer Sharp Part Number LK315T3GW30R Description 32" VE PANEL ASSEMBL
    Sep 04, 2009 | Sharp LC-32SB21U 32 in. LCD TV
    Vizio 32 inch flat screen
    have you find out anything about it ?
    Jun 04, 2008 | Vizio L32 32 in. LCD HDTV
    Televison & Video Logo
    279 people viewed this question
    Top Televison & Video Experts
