Question about Ricoh Aficio 2035 Copier
I m facing toner sign in af 2035 i have replace td sensor i/o board , power supply, but after machine start in first or second copy toner sign is generated. what should i do now ?a
  • 62 Answers
You have to change the ID sensor machine is not getting the bare drum and patch voltage based on this ID voltages your toner supply depends -thanks
Posted on Jan 01, 2011
Ricoh aficio 1035 copier gives error code 390
TD sensor defective
TD sensor not connected or disconnected damage
Poor connection between the TD sensor and IO board
IO board defective
Toner supply defective
* Insufficient toner in developing unit
Apr 16, 2014 | Ricoh Aficio 1035 Copier
Code SC 390
SC 390 is a TD sensor code try changing developer (Type 24) B0649645 if not that then maybe the TD sensor pn#B2475310,
Mar 18, 2014 | Ricoh Aficio MP6001 Copier
I have af 2035/45 ricoh i am facing paper jamming at exit unit. i have done replaced sensors and bicu board and check all related wiring, but couldn,t find solution.
paper jam in aficio hasnt reset . but you must check all doors .it may be one door in your machin is open .more than more right door check it
Apr 27, 2012 | Ricoh Aficio 1035 Copier
I have problem with Richo mp 7000. in this machine when we are doing TD initialisation Call service SC 342 is coming.... I changed TD sensor but the problem still exists .... another think related to this...
How old is your Drum? if it is due then replace the drum and replace a new developer then make a TD initialization Everything now must be started from the scratch.
I will start fresh from the scratch but before you will start fresh check if the toner supply system is functioning properly.
Check SP 2209 maybe somebody before you did some wrong adjustments.
Another way to troubleshoot this problem is to activate the sp 2967. "During auto process control execution after the main switch is turned on, the toner amount in the development unit is normally checked and adjusted using the ID sensor. However, in some environments, such as where there could be traces ammonia in the air, copies could appear dirty or too dark because the ID sensor reading is not reliable".
Again..the easiest way is the simplest one:
1. Empty and vacuum the dev unit.
2.Put a new filter and a new bag of dev.
3. Run 2801 only once , run 3001-02 assuming that drum is good, blade & brush are in PM cycle and id sensor clean, run 2962 and verify if 3901 is on...it should be.
Good luck
Aug 27, 2011 | Ricoh Office Equipment & Supplies
Af 2045-SC390
That error is related to a bed reading in a sensor of the Development Unit, called "TD sensor".
You can try to take of the development unit and see if there is dust of toner or even if the plug is broken (i saw that happens sametimes).
The development unit is placed under the PCU.
Open the front door and you will se it.
If you can not see nothing abnormal like dust or broken plug i advise you to call your provider to change the TD sensor or the development unit.
any doubt reply to me ok?
Mar 05, 2011 | Ricoh Aficio 2035 Copier
Td sensor setting problem ricoh 2035
i think you are facing the problem with SC-390 while initialization,The TD sensor output voltage is less than 0.5V or more than 5.0V after 10 consecutive times during copying. that meens TD sensor defective or Developer failure or IOB bord faiure if you are not a tech. person please call the right person to fix this problem
thankyou
Dec 16, 2010 | Ricoh Aficio 2035 Copier
What does the error C390 on an aficio 1013 photocopier mean
TD sensor error test value abnormal the TD sensor output voltage is less than 0.5v or more than 5.0v after 10 consecutive times during copying the possible cause willbe TD sensor defective,TD sensor not connected or connector damaged ,poor connection between the TD sensor and the I/o board (IOB),I/O board (IOB)defective ,toner supply defective
May 20, 2010 | Ricoh Aficio 1013F Copier
Add toner ricoh aficio 2045
Toner supply is controlled with readings from TD sensor on the developing unit and the I.D sensor above the drum by default.
These are low cost parts and easy to change.
(The TD sensor on this model have been known to fluctuate back and forth by a fair margin so is a good place to start).
You could also try stripping down and cleaning out the toner hopper.
Check the four mylars are present and the grabber is opening wide enough to grab the toner bottle nozzle successfully.
Check the toner hopper exit slider is opening fully when the PCU is inserted.
I had one of these 'add toner' faults today and it was the toner hopper all clogged up inside.
The side bit where the toner drops down had hardened clumps of toner stuck around the side entrance mylar and the exit hole.
Check also the toner motor. I have seen these fail. Run simulation output check for toner motor. I would remove the toner supply unit and hold the motor when you run this simulation. Sometimes the motor turns but does not have enough torgue to turn the toner supply unit.
Mar 05, 2010 | Ricoh Aficio 2035 Copier
I Have konica 7130 i can t Made L detection The
Code 0006 TCSB (toner control sensor board) output signal D/A conversion error To Clear SW2 (sub power switch) OFF/ON Problem Solutions, Replace 2? PRDB (printer drive board) 1? TCSB (toner control sensor board)
Aug 04, 2009 | Konica Minolta Di1610 Copier
Ricoh 6513 Service Code 370
HI there I hope it is the colour machine version so below is the description from the service manual.
Thanks J
SC370 Abnormal TD
sensor
information (K)
- Timing -
When communicating with
TD sensors, during
printing process, or
process control self-check
- Condition -
TD sensor output exceeds
4.5V or drops below 0.5V.
• Poor connection
• Dirty sensor surface
• Defective TD sensor
• Toner density is out of
range
• Not enough developer
3-007-001 1. Make sure the TD sensor is properly
connected.
2. Check if the connectors on the TD sensor
interface board 1 and the slip ring and the
TD sensor interface board 2 are properly
connected.
3. Clean the surface of the TD sensor.
4. Replace the TD sensor. If it becomes OK
after the sensor is replaced, replace the
developer of color related to the problem.
If the problem is related to the toner density
(too low or high), find the cause and fix it.
Jan 23, 2008 | Ricoh 6513 Copier
Ricoh Aficio 2035 Copier Logo
157 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
