Question about Sony Reader Pocket PRS-300
My sony ereader says usb connected but on the screen it says charging stopped. the note at the bottom says that the reader is unable to charge as no power supply is being detected. Also it doesn't show up in my reader library as connected. How can I fix this?
5 Suggested Answers
  • 11 Answers
SOURCE: Ereader library won't open
If you're using the Windows Operating System, the issue may be caused by the Data Execution Prevention feature in the Windows Operating System or if certain folders used by the Reader Library Software are corrupt. Please click on the below link and select the desired Operating System to get the troubleshooting steps.
If the issue persists, uninstall the Software and restart the Computer.
Next, disable all the active Software's (Firewall, Anti-virus, etc) in the Computer and reinstall the Software.
Also, please ensure to check the "Launch Software" at the end of the installation. This should resolve the issue.
If you're using the Macintosh Computer, uninstall the Software as per the below mentioned steps:
First, click "Go" and then click "Applications" in the Main menu.
Next, in the "Applications" folder, in the right pane, double-click on the "Utilities" folder.
Then, in the "Utilities" folder, double-click "Terminal".Now, in the "Terminal" text window, type "sudo /Library/ebookLibrary/". There is a required space between sudo and /.
Next, please press "ENTER" on the keyboard. A confirmation message will appear. Please enter your Password or leave blank if you do not have a user account password.
After the Password has been entered or left blank for no password, press ENTER. You will receive the message that the Reader Library Uninstall is finished.
Now, please click "Terminal" and then "Quit Terminal" to exit the Terminal application in the Menu.
Finally, close all other open windows.
Now, restart the Computer and reinstall it.
Note: Ensure that the Reader is not connected to the Computer while performing any of the above mentioned steps for Windows/Macintosh Computer.
Posted on Mar 05, 2010
  • 1417 Answers
SOURCE: My screen is frozen and
The Sony Pocket Reader allows you to read on the go, and easily fits into a coat pocket or purse. It is a convenient way to carry books with you, as it is very lightweight and small. Of course, you may encounter glitches with any electronic equipment. If you are having an issue with the Sony Reader,
there are a few troubleshooting steps you can take to resolve it.
  1. Reset the Sony Pocket Reader by pressing the "Reset" button on the back with a small pin or paperclip. Turn the "Power" switch to turn on the Reader. This will not affect the content that is stored on the device. If you connect it to your computer before turning it on, the computer will not recognize it.
  2. Give the reader enough time to charge fully when necessary , if the battery life is short. You may need to replace the battery if the problem persists. To do this contact the nearest Sony Service Center. If it has been a long time since you've charged the reader, it will take repeated charging to charge it completely.
  3. Wait a few hours if the reader will not turn on. If any moisture or condensation has gotten into it, it will likely work after you give it time to dry out.
  4. Check that the device lock is not turned on, if you are having problems with your computer recognizing the reader. Verify the "indicating connection via USB" is displayed at the top of the reader's screen. If it is not, disconnect the USB cable, wait a few minutes, and then reconnect it.
Good luck and thanks for using fixya.
Posted on Jan 18, 2011
SOURCE: Can I delete a book off of the Sony ereader PRS
how do i delete the books that come with the ereaderprs 300
Posted on Apr 02, 2011
  • 94 Answers
SOURCE: Reader Library lists reader as "error" and not "reader".
Solution is reboot the Mac on 32 bit if you are running on 64 ... here's how to:
Posted on Jul 17, 2011
I cant charge my e 705 ereader
What are you using to charge it? How old is your ereader?
Are you using a usb cable to computer to charge? Or do you have an adapter that goes in the wall socket that connects to your usb cable.
You may need a new usb cable, or depending on the age of your ereader maybe a new battery.
Oct 26, 2012 | Sony e-Book Reader
My Sony ereader touch isn't charging. Pluging it in to either the computer or the wall charger, and the light doesn't go on. The screen is frozen on the last page it turned to.
Hi suebagnall,
If the redlight does not come on, try the following:
1. Connect the reader to the wall charger (make sure you use the Sony Charger ACS5220)
2. Hit the Reset button at the bottom of the reader
3. Check if the redlight comes on
4. If so, leave the reader charging for 15 minutes to see if it takes the charge
5. If this does not resolve the problem, probably you will need to contact Sony to get it repaired
Jun 27, 2011 | Sony Reader Touch PRS-600
I drained my battering, recharged it, but now the ereader is not responding. I get the opening ereader line, and the 2 arrows turning, but then it jams.
Hi bairdsus,
Looks like the reader is not fully charge, you can try this:
1. Connect the reader to the computer or wall charger, make sure the redsteady light comes on, if not try the "Reset" at the bottom of the reader for 3 seconds then check the light again
2. Allow the reader to charge for 15-30 minutes and then disconnect it
3. Try to turn the unit On/Off and see if now you can access the books now
Note: If you are using any memory stick or SD card, remove them.
Good Luck!
Jun 11, 2011 | Sony Reader Touch PRS-600
My sony ereader has been plugged in for 2 nights to my MAC, and each morning it still only has 1 battery cell left. The computer detects it and the ereader displays the USB cable is connected. How do I...
Seems like your MAC goes into sleep mode, when this happens, the computer does not supply power to the USB ports to save power. When the computer does this, there is a big change that will drain out the battery of the Reader. You can try this:
2. Hit the reset button while is connected for 3 seconds (Reset is located at the bottom of the unit)
3. Leave the reader charging for about 40 minutes then disconnect the reader and check the battery meter
4. If you can see that the reader took some charge then leave it connected for 2 hours or until the redlight goes off
Good Luck!
May 20, 2011 | Sony E-reader Portable E-book MP3 Player
Hi huffasia,
Looks like a charging problem, try this:
1. Connect the reader to the computer and make sure red steady light comes on, if not, then hit the reset button for 3 seconds.
2. Once you get the redlight, leave the reader charging for 15-30 minutes (make sure the computer does not go into sleep mode)
3. After you charge the reader, try the soft reset again and slide the power switch at the top of the unit.
If this does not resolve the problem you may try a hard reset on the reader but this will remove all content.
To hard reset:
1. Hit the reset on the bottom of the reader
2. Slide the power switch
3. Once "Opening Book" comes on the screen, press and hold the directional "down arrow" and the number "0" both at the same time until "Reset All" appears on the screen.
4. The screen will go blank, now its time to turn it on again.
Note: If after trying the hard reset, the reader goes back to the black arrows trying to turn around, then repeat the steps again.
Hope this helps!
May 16, 2011 | Sony E-reader Portable E-book MP3 Player
I have the sony ereader and it is locked. won't turn off or change screen how do I reboot?
Looks like the reader is missing charge, try this:
1. Connect the reader to the computer and make sure a red steady light comes on, if not, then hit the reset at the bottom of the reader for 3 seconds and check if the light comes on now
2. Leave the reader charging for 15-30 minutes
3. Disconnect the reader and see if operational now, if still frozen, try the reset again and slide the power switch.
Good Luck!
May 06, 2011 | Sony E-reader Portable E-book MP3 Player
My sony prs 350 ereader screen froze when i was reading my book when i try to turn it off the light turns red and it is fully charged
If the Reader is frozen, you can try the following:
1. Disconnect the reader from the computer
2. Hit the reset button at the bottom of the reader for 3 seconds
3. Slide the power switch
4. Screen will blink and will show "Opening book"
5. Allow the reader to load and then see if operational
Note: If the reader get stuck again, connect it to the computer for 15-30 minutes and allow it to charge, make sure the red steady light comes on.
Good Luck!
I have a sony e-reader prs-600. I plug in the reader using usb to my iMac (which is new) and it doesn't charge. I use a usb to electrical outlet converter (not sure of name) and it doesn't charge. I can...
Please turn OFF the Reader and press the Reset button using a sharp pointed object to reset it.
Next, please connect the Reader directly to a different USB port of the Computer using the supplied USB cable.
Now, please allow the Reader to charge for 2-3 hours and check if it charges. This should resolve the issue.
However, if the issue persists, please try connecting the Reader to a different Computer to confirm if the issue is with the Reader itself.
If the Reader is charging with a different Computer, there might be an issue with the iMac, else, with the Reader.
Note: please ensure to connect the Reader directly to the Computer using the supplied USB cable.
Mar 01, 2010 | Sony Reader Touch PRS-600
Computer will not recognize prs600 when you plug it into the usb port. I have used the reader before and downloaded books and now, all of a sudden, the usb port won't recognize the device. The reader is...
When this situation occurs, the Reader will not appear in the left pane of the Reader Library software or the Reader Library may shut down when connecting the Reader to the computer. Follow these steps to resolve this issue.
IMPORTANT: Before starting this or any troubleshooting procedure, verify that the Portable Reader has been updated with the latest firmware version and that the latest version of the Reader (eBook) Library software is installed on the computer. The latest firmware and software is available at the Sony Support Web Site.
NOTE: Because each of these steps represents a possible solution to this issue, open the Reader (eBook) Library software and connect the Reader to the computer after completing each step.
  1. If the reader is not recognized by the library software, close the software, re-open it and then check the connection status again.
  2. Verify that the Reader is turned on and is not locked.
  3. Verify that the Reader battery has an adequate charge.NOTE: If the Reader battery is discharged, allow the battery to charge for at least one hour before attempting to connect the Reader to the Reader (eBook) Library software.
  4. Verify that the USB cable is properly and securely connected to the Reader and the computer.NOTE: The USB cable should be connected directly to the computer. Connecting the Reader using a USB hub or extension cable is not supported.
  5. Verify that the Reader displays the USB connection indicator in the upper-right corner of the screen.
  6. Remove any Memory Stick® media or SD media in the Reader.
  7. Disconnect the Reader from the computer, close the Reader library software and restart the computer.
  8. With the Reader disconnected from the computer, perform a hard reset.
  9. With the Reader connected to the computer, uninstall and reinstall the Sony Reader USB driver.
  10. Install the Reader library software on a different computer and connect the Reader.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. Follow the below link to get it serviced:
Jan 30, 2010 | Sony Reader Touch PRS-600
Purchased a sony psr 600 ereader for my father at Christmas and it won't hold a charge more than 2 hours.
Read the below mentioned link :
However, if you confirm that the reasons are not those, then perform a soft reset. To soft reset the Reader, press the RESET button using a sharp-pointed object. Then, charge the reader for at least 4 hours. if the issue still persist, charge the reader by connecting the reader to a different USB port. You can try charging the reader by connecting it to the AC Adaptor.
However, if you did all those already, service of the reader mat requuire.
Follow the below link to initiate the repair.
Jan 10, 2010 | Sony E-reader Portable E-book MP3 Player
Sony Reader Pocket PRS-300 Logo
455 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
