Dvd or cd stops playing after a few seconds, followed by clicking noise from disc player
    Guru:
  • 1,463 Answers
This could be the laser are on the way out ,
maybe time to with a new to replace it with to replace a new one they are cheap enough to replace.
riz.
Posted on Jul 07, 2008
The player will read dvd but will not play cd
Richard: This is what EHow.com said: "
  • Turn on the DVD player. It generally takes a few seconds to get going. Take out the DVD if there's one in the drive already.
  • 2 Make sure the disc isn't scratched or dirty. Use a soft rag to clean the disc if you see any smudges. Insert the CD into the DVD player's disc drive and close it.
  • 3 Press the "Play" button on the DVD player or remote control. Some DVD players will begin reading the disc automatically. Pushing the button works just as well.
  • 4 Use the "Scene Selection" buttons on your remote to select a track. Some DVD players have odd ways of ordering the buttons on the remote. You might have to play around a bit before you find all the right buttons to work the CD playing function of your machine.
  • 5 Crank it up and enjoy your music. The DVD player will act just like a CD player and play the tracks of the CD through the TV.
  • Read more : http://www.ehow.com/how_2036285_use-dvd-cd.html
    May 28, 2015 | Televison & Video
    When i put in a dvd, it makes clicking noises, after that a notice
    follow this steps and fix it. God bless you
    Does not play disc
    1. No disc. - Load a disc into the tray.
    2. Disc has been loaded upside down. Place the disc with the label side up.
    3. Disc region code does not match region code of the player.
    4. Disc type is not the correct type to play.
    5. Disc is damaged or dirty. Clean the disc or try another.
    6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
    Nov 14, 2012 | Sony Televison & Video
    My dvd player tray does'nt open when it should and when i insert a disc to play, it only plays for a few seconds then it stops but the disc continues to spin
    Hello
    The laser pickup unit of your DVD player may either be faulty or dusty. Just put in a cleaning disc into it and play it for at least three times, and check. If it does not help you, the laser pickup unit of your device should be replaced with same type and number. Just check the loading belt too. OK.
    Dec 16, 2011 | Zenith XBV443 DVD Player/VCR
    DVD Player stops reading disc Error message :
    usually this happens when lens cannot read the the disc. Due to few reason 1 Your disk is scratched 2 Your DVD lens is covered with dust 3 You need to replace DVD lens
    Try another few CD/DVD to rectify whether there is any problem with dvd you are trying to play
    if this error occurs on all the dvd you played then the most likely proble is with your DVD lens either its coverd with dust use Disk cleaner if not you got to replace a new DVD lense as per model
    Feb 18, 2010 | Samsung DVD-V9800 DVD Player/VCR
    When I go to play a dvd, a clicking noise is heard and the movie will stop playing. With some dvds I cannot play them all as the noise begins immediately. What can I do???
    Sounds like the laser head that reads the disk is getting lost and trying to search for the track. This is often caused by a dirty laser head or dirty disks, try using a cleaner disk (available at Wal-Mart or just about anywhere) Follow the package instructions and clean the laser head see if that cures it.
    Sep 15, 2009 | Emerson EWD2203 DVD Player/VCR
    When playing a DVD, picture & audio stop for a second one a while, no problem when playing a CD
    this may just be the mechanism changing diretion as it reads the second layer on the disc usually because the film is too long to go on one side of the dvd disc.
    quite normal.
    but if happening quite a lot during playing a film then it could be something as simple as cleaning the mechanism. NOT for the untrained
    Jun 01, 2009 | Teac DV-H550 DVD Player
    DVD stopped playing all DVDs
    Reset you player by doing the following:
    With the player on, hooked properly to your television, and on the correct station:
    Open the tray
    Close the tray (with no DVD inserted)
    Hold the stop button down for a full 5 seconds
    The CyberHome screen should appear. You should be able to play your dvd's now.
    Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
    Problem with original dvd
    Before performing any operations, make sure of the following: ? Check the connection with the TV. ? Turn on the TV and select the correct input on the TV to view the pictures or on-screen indications on the TV screen. ? For DVD playback, you can change the Setup menu setting to your preference menu... Alos, make sure thay the system and disc region code numbers are incompatible: The following discs cannot be played back: ? DVD-Audio, DVD-ROM, DVD-RAM, DVD-R, DVD-RW, CD-ROM, CD-I, (CD-I Ready), Photo CD, etc. Playing back these discs will generate noise and damage the speakers. * Note on Region Code DVD players and DVD Video discs have their own Region Code numbers. This system can play back DVD discs recorded with the color system of NTSC and PAL whose Region Code numbers include ?3.?
    Dec 15, 2005 | JVC TH-A5 System
    Computers & Internet Logo
    83 people viewed this question
    David Payne
    David Payne
