Question about GE 5803P Multi-disc DVD Player
We have been using a GE5803P Muti-Disc DVD in place of a CD player. Lately, it sounds like the disc is rubbing or slipping when it tries to read or play a CD. Is this a common problem for this model? I have taken the cover off for a look, but have not disassembled anything yet. Are parts or service still available? This model has worked well up to now and does microphone inputs for Karaoke.
  • 3 Answers
SOURCE: ge 1101 pa dvd player keeps saying no disc
Try turning the disc over.
Posted on Dec 25, 2008
  • 289 Answers
SOURCE: i have combi tv/dvd player. the dvd is noisy when disc is put in
hi..the reason to this problem is your belt.
once you replace the belt you wont get such
type of sounds.Replace the old belt with the
new one.This will solve the issue.
check this out..
thank u..
rate me..
Posted on Feb 22, 2009
  • 814 Answers
SOURCE: the dvd player displays "no disc" sometimes.
In your entertainment center there maybe a very low level vibration interrupting the dvd lasers ability to track the dvd's.You should try using a rubber damping pad under the player or putting noise damping feet on the the player. This should stabillize the player and let the unit work correctly Hope this helps you with your problem.
Posted on May 04, 2009
petraman7
  • 1175 Answers
SOURCE: my GE1101P dvd player says
I would try running a cleaner disc in it first.
If youre not scared to open the case ( WITH AC UNPLUGGED)
try finding the laser lens and clean with swab of 90% alcohol
Posted on Aug 19, 2010
  • 8457 Answers
SOURCE: I want to record pictures from my computer to a
DVD+R x8 or x16 disc best format to used.90-95% compatiable from computer recording to used on any DVD player for viewing,if ur dam computer program u are using to copy it out it not have it own secret codes patend it.
Posted on Aug 19, 2011
I have a philip AZ2045 CD Player , but lately it can't detect the cd. Everytime I tried to play a CD it always written NO CD or CD EROR... Can anyone help me ,please ??
Try using a DVD / CD disc cleaner. There is a lens on the driv which detects if a disc is inserted and to read the info on the disc. If its dirty, it wont read properly.
Sep 17, 2015 | Audio Players & Recorders
CDS slipping when playing.
Try the disc in another CD / DVD player.
It is important to make sure that the DVD itself is the problem, and not the CD / DVD player.
Cleaning a CD / DVD player is a much more intricate process that requires device-cleaning hardware.
Lay the disc artwork-side down so that you can easily clean the playing side.
You should always avoid setting a disc playing-side down to prolong its lifespan.
Gently rub the disc with a soft, lint-free cloth to remove all traces of dust and fingerprints. Always rub a disc from the center toward the outer rim in a light motion to prevent any other damage.
Apply a light amount of toothpaste to a cotton wool ball and gently rub the disc from the inside out.
You may need a few drops of water to make the toothpaste spread easily.
Cover the entire surface area of the disc, or at least the area that is scratched.
Toothpaste is a gentle abrasive that works well for fixing simple scratches.
Clean off the toothpaste with the cloth, once again rubbing from the inside of the disc toward the rim.
Try not to push too hard to prevent further damage.
Apply other kinds of light abrasives such as baking soda or glass cleaner if the sound is still distorted.
Remove the solution with the same gentle rubbing technique.
Purchase a disc-cleaning spray from a local video or electronics store.
These sprays are effective in removing any grime from the disc and filling small scratches.
hope this helps
Sep 30, 2012 | Philips Fwm608/12 600W Subwoofer Mini...
CD/DVD drawer won't open so CD stuck inside :(
Well you can please follow the below steps -
1. Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
2. Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It's the part that holds the DVD loader in place.
3. Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don't want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
4. Slide the disc tray out. If your disc got stuck before it was read, it's probably still on this tray. If so, your problem is solved. However, if the disc was fully set and loaded, the job isn't quite finished yet.
5. Move the small mechanical arm that holds the disc in place over so that the disc and the reader are both exposed. Some DVD players will not have anything holding the disc in place. Instead, these devices use a system not unlike that of a common DVD case. The DVD will be locked in place in the center.
6. Carefully lift the disc up and out of its loaded position in the DVD player. This may entail sliding the disc reading mechanism over slightly. This won't hurt the device as long as you're careful. You should be able to access and remove the disc.
Good Luck!! Thanks for using FixYa!!
Feb 03, 2010 | Cambridge Audio Azur 540D DVD Player
Whenwe try to use dvd it reads bad disc used dvd
Hi did you try cleaning the washer that spins the cd they often get glazed and slip causing the cd to spin at a low rpm causing the bad disc error.
Feb 01, 2010 | Daewoo DV-6T955B DVD Player/VCR
It can't read dvd disc, but if i'm using an mp3/cd its fine
Was this a burned dvd or a store bought one? Sounds like the laser that reads dvd is dirty, try to play another dvd and see what happens after cleaning.
Nov 05, 2009 | Jensen's VM9312 Car DVD Player
It is not reading the blank disks anymore, i wonder if the laser needs to be cleaned. I place a new disc which is labeled Audio and the player won't recognize it and states "NO Disc" insert disc. the...
Sounds like that may be the case. You can buy one of those cd cleaning discs and try using that. or if you want to spend the time dis-assembling the recorder and use some rubbing alchohol and a q-tip to clean the laser lens. Otherwise not worth the cost to repair.
Oct 15, 2009 | Philips CDR778 2-Disc CD Recorder
My Dvd Player does not read disc when they are
first, try using rubbing alcohol and cotton swab and clean the glass laser lens eye.
If cleaning the lens doesn't work, then the lens control circuit will need to be replaced
Jul 09, 2009 | Televison & Video
Bad disc
Try cleaning the lens yourself. Before taking drastic measures as replacing stuff, try cleaning the lens on the DVD/CD Drive. You will need to open the unit and also open the DVD/CD case. Make sure you do this while the unit is unplugged from a power source. Locate the lens that reads a dvd/cd. Now get a cotton swab and moisten it with isopropyl alcohol (rubbing alcohol) and gently rub the lens clean...use the other dry end of the cotton swab to rub it as well. Try not to use too much alcohol on the swab and not too much force when rubbing. Let it dry for a minute or 2 and screw the unit back into 1 piece. Moisture, cigarette smoke, insence smoke, and dust can cause a barrier between the DVD/CD and the reading lens and by doing this you will either fix the unit or know that it is a problem that will need replacing. Good luck!e lens yourself manually
Jun 23, 2008 | Cyberhome CH-DVD 300 DVD Player
Dvd player not loading
I openned mine up and found that the lens carrige was not in the fully retracted position. I pushed it all the way back to the back of the slide. Then I removed the two screws on either side of the spindle support so I could get to the lens. I hit the lens with some compressed air, plugged it in and loaded a disk and it worked like a champ. Listening to some Stevie Ray Vaughn right now!!! And going to watch some movies later. ;)
Good luck, I hope this helps someone.
Wrench
Jul 09, 2007 | Apex Digital AD-1110W DVD Player
Cd not reading
problem no disc when this is a disc in the player
Jul 08, 2007 | TruTech TT1620 DVD Recorder
GE 5803P Multi-disc DVD Player Logo
103 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
