Question about Moen 1 Handle LavatoryWith Drain Assembly - 64621P - Polished Brass
How do I repair a dripping Moen M4600 (1978) bathroom faucet? Looks like the Moen 1 handle 64621P that is pictured here. Thanks. Richard
    Genius:
  • 1,015 Answers
First shut off water supply and remove cover on top of handle.They generally just snap in place so you can remove with screwdriver or knife point. Remove screw in center of handle and pull handle off. There is a copper retaining clip that holds cartridge in place. It has a small hole in the center on top that you can insert scratch awl or other pointed tool in and pull straight up to remove.You can try to grasp center stem of cartridge with pliers and pull up to remove. If the cartridge has not been changed for a long time it may be very hard to remove.
You are going to have to replace the entire cartridge so you should have one on hand and you can purchase a tool made especially to remove moen cartridges.Just follow direction that come with cartridge or tool and remove cartridge. I would use the brass cartridge as I have not had good results with the plastic ones. When you get old cartridge out I would use a small amount of faucet grease or petroleum jelly to lube o-rings and then reinstall new cartridge and clip,handle,screw,and cover. Good luck and thank you.
Posted on Dec 28, 2010
How to remove "cover" on faucet for drain
under the sink there is a rod that screws into the back of the drain pipe right under the bowl of the sink unscrew the nut holding the rod in and the drain plunger will pull up
Sep 24, 2011 | Moen 1 Handle LavatoryWith Drain Assembly...
Faucet drips. How can repair it? Thanks
Do a search for "moen repair cartridge" buy one and replace it...
You also will need the pulling tool to to it easily..
http://www.google.com/search?q=Moen+repair+cartridge&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
http://www.masterplumber.net/moen.htm
heatman101
Apr 13, 2011 | Moen 3175 Legend One Handle Shower Faucet...
Dripping after water is shut off/how do i dismantel to check rings/gaskets
If you contact Moen ( http://www.moen.com/ ) they will send you a new cartridge free of charge and it will come with complete instuctions.
Mar 05, 2011 | Moen 1 Handle LavatoryWith Drain Assembly...
My moen bathroom sink handle came off. The srew into the handle comes up from the stem? how do I access the srew to reinstall handle? Thank-You
pop the cap off top of handle with steak knife, screw is underneath,unless yours is like the one pictured,then its an allan screw from the back.you had one when it was installed and,these can be really stuck
Jan 28, 2011 | Moen Bathroom Sink Faucet - 4-inch...
My single pull up type faucet is stuck and I cannot turn it on?
http://www.moen.com/shared/pdf/4621pt.pdf This web site has a parts break down of the faucet.
This web site has more information for your faucet.
http://www.faucet-warehouse.com/Moen/chateau/bathroom-faucet/4621p
I hope this will be help full to you in how it is put together. If you have to take it appart to work on it.
Jun 06, 2010 | Moen 4621 Chateau 1 Handle Bathroom Faucet...
How do I fix a dripping MOEN T4572 lavatory faucet
If you contact Moen, they will send you a new cartridge, as well as tool to replace it. ( 1-800-buy-moen )
No charge.
Jan 18, 2010 | Moen Monticello Single-Handle Kitchen...
The handle turns past the 'off' point and then drips. This is the Monticello faucets. I can't find pictures that aren't any more than black squares at the Moen site. Have no idea on how to get this...
You need to hold the lever handle off and turn the bell part counter clockwise you may need a small strap wrench or rubber guard that fits on the pliers it was very common for the plastic piece inside the handle hub to break call 1-800-buymoen and they will send you new parts at no charge
Nov 13, 2009 | Moen Bathroom Sink Faucet - 4-inch...
I have a slow leak coming from the spout
ooops, didn't mean for that to be a request, sorry...It was a solution. Although, if you dont want to deal with Moen, you can get one at your local plumbing suplly store. I recommend taking the old one with you (make sure you shut the water off first!). Again, good luck
Sep 03, 2009 | Moen 4621 Chateau 1 Handle Bathroom Faucet...
Bathroom Faucet Handle Fell Off
There is a small allen screw in the base of the handle- the part the stem screws into to turn the water to the on position. If you have lost the one for your handle call moen at 1-800-289-6636 in the US. Their hours are Mon-Fri 8-8 EST and Sat 8-18:30 or follow this link MOEN. In Canada 1-800-465-6130 and hours are Mon-Fri 7:30-17:00 EST.
Mar 11, 2009 | Moen Bathroom Sink Faucet - 4-inch...
Moen 1 Handle LavatoryWith Drain Assembly - 64621P - Polished Brass Logo
2,991 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
