Question about Acer Aspire 5500 5570-2609 Laptop
My acer laptop froze yesterday so I shut it down, when turned back on - did the Fix screen - fan that and now it is just hung trying to open up. All I see is the Microsoft Corporation and the bar beneath it running. Had it on for 3 hours searching in that screen and my desktop never came up - any suggestions?
    Problem Solver:
  • 20 Answers
Try removing the battery from the rear end of the laptop.Leave it for 2 to 3 hrs and then try putting back the battery and turn it on. As soon as you turn on. Keep on tapping F2 key from the first row of the keyboard and go to Boot utlilty select and press Ok. It really works.
Posted on Dec 28, 2010
  • Acer Master
  • 6,771 Answers
It could be software issues caused by a virus, try using a recovery disc that came with the laptop, if you have it. If the recovery process fails, then you are probably looking at a bad hard drive.
My Dell Inspiron 1525 laptop has been having trouble with overheating. I used a laptop fan but my 9mo pulled it off the table and broke it. I went through the process of shutting it down after using it...
holding the fn key on boot will start the pre boot diagnostics if theyre clean then the heatsink and fan need cleaned out as they get blocked with dust, there should be a panel that you can remove on the back
Feb 24, 2011 | Dell Inspiron 1525 Notebook
Hi, I purchased a acer on 8/20/10. Updated with a new video card on 9/9/10. Worked great until 10/3/10. I was playing a game and the computer froze. I had to do a hard shut down. Computer came back up,...
Hello sir, if your hard drive and video card is new for now, then maybe your memory card is not enough for your PC. And please try to check the processor because I encountered some problems like that.
Oct 08, 2010 | Computers & Internet
Acer 3100 laptop lights on fan on slow but no screen
Remove the battery and disconnect the Ac adapter from the laptop. Press the power button and hold it for 10 seconds.Reconnect only the Ac adapter and power on the laptop.
Post back if the above solution doesnot work , it could be bad video card driver.
Thanks for using fixya
proton
Aug 12, 2009 | Acer Aspire 3100-1405 Notebook
Shutdown Issues
It could be overheating, either you need to replace the fan, or at least open it up and remove any dust (bunnies) that may have built up inside, if your fan is gummed up it won't spin which then causes computer to overheat.
Jun 28, 2009 | Acer Aspire 4315 Notebook
Unit Always Shuts Down While In Use
all the laptops on the world have warm problem. if you use your notebook dirty place your fan could get dirty and not working well and not makes cool anymore. in warm system can shut down itself. it is often does. if you open your laptop back case you will see the fan. there are olny 4 screw. clean the fan and screw again. try it.
sorry for my enghlish.
May 17, 2009 | Acer Aspire 7720 Notebook
Screen picture froze, powerd down, powerd up, blank screen
open cbinet of crt,
then internally check circuit connection.
or check for external lead connect very well or not ,one of power,and data cable.
Jan 25, 2009 | Acer Aspire 5100 Notebook
Acer Aspire L100 overheating
You could try a new cpu fan and heatsink. They are normally inexpensive. if this does not work make sure all the case fans are working and check to see if your ram is overheating
Dec 22, 2008 | Acer Aspire L100 PC Desktop
Laptop wont turn on at all!
try sensing if your cpu fan is working, it is under the power switch side, you can see small exhaust slots, put your hand beside it and feel if some air is coming out when you turn on your pc.
When you turn you pc on and only orange light blinks, it means that no power was getting into it, it blinks because no electrical power is coming from your power adapter and the battery is drained. Check your power adapter cable, this is the very cause why your pc is shutting down. usually the wire from the adapter to the pc is faulty.
Nov 01, 2008 | Acer Aspire 3000 Notebook
Over heating
I would suggest you to check the heatsink and cpu fan,
it could be dirty, if it is dirty, clean it and it should work fine.
To see heatsink and cpu fan, open 4 screw on the back of your laptop.
remove the cover, remove the fan screw (3), remove fan,
remove 4 screw on the cpu heatsink, remove the heatsink.
if your heatsink and fan are clean, it could be something else cause the shut down.
in this case you should send it for repair.
Oct 07, 2008 | Computers & Internet
Blue Screen of Death, but not quite
hard drive is a main failure concern, check to ensure power supply is plugged in. sounds like you have a corrupted rgistry file-locate OS for that unit and hit ''repair'', should solve the problem.
Jun 29, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
23 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
