Question about Kenmore 66469 / 66462 / 66464 Microwave Oven
I have a two year old kenmore 721.66462. It was working fine and then it started to make a major hum and now the food does not warm up. I disconnected it and tried the outlet with a fan and the outlet is fine and so is the outside circuit breaker. I then plugged the microwave into another outlet and it still has the same problem. Any ideas?
    Brigadier General:
  • 8,909 Answers
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Dec 28, 2010
My Rusell Hobbs 20L microwave wont heat food,what could be the problem?
If the control circuit turns on the power supply to the magnetron tube, the big power transformer should hum. Then after a couple seconds, it should hum louder as the magnetron warms up and starts to put out RF. If everything stays stone cold, the magnetron is probably shot.
These are repairable, and the parts are available. But you have to decide whether it is worth repairing. If it's past warranty, probably not. I am a radar transmitter engineer with 40 years' experience with these kinds of tubes, and if my ten year old microwave quits, I'm going to just throw it out (after I take it apart just to see what quit).
Apr 06, 2017 | Microwave Ovens
My Kenmore Microwave slowly heats but mostly the dishes vs. the food. By the time the food is warm enough, the plate or mug is practically baking. The microwave is only 4 years old, so I can&#39
Sounds like you don't have proper microwave-compatible plates or mugs. Must have lead in them, or in the paint (!?!) Try a plastic plate or even a paper plate. I can't think of anything that would make the microwave oven do that, UNLESS it's a microwave/convection oven, in which case, the convection heater must be coming on whenever you are trying to just use the microwave function.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 24, 2014 | Kenmore Microwave Ovens
Does not heat food
call that company server
Apr 05, 2010 | Kenmore 66292 Microwave Oven
Kenmore microwave's exterior and buttons
Hi it is quite normal for the outside of a microwave oven to get quite warm to the touch. with regard to the buttons not working; this will be due to a faulty touch panel mebrane that will need to be replaced. They are not too expensive so is a viable repair
Hope this helps
Jan 07, 2010 | Microwave Ovens
Hey Thanks!! I tried to warm food in the microwave and the microwave started to make a strong humming noise, didn't warm the food and has an strong electrical burnt smell. -What's wrong?
The unit had a meltdown. Anytime you smell something thats not normal its alway an internal failure. You could send it out to be looked at but at the price to replace it your better of getting a new one.
Nov 27, 2009 | Microwave Ovens
After use, fan keeps running and control panel not working
Hi, this is a major chip fault. this chip is located on the control board and, it is responsible for initiating the cooking cycle correctly. you will need to replace the control board asap. it has failed.
Jun 19, 2009 | Kenmore Microwave Ovens
Microwave not heating up food
This model is a lower-end type that probably didn't cost very much. Since it's over 2 years old, you have no warranty left. Most appliance repair shops charge extra $$ for servicing installed items in the home. You'd probably be better off purchasing a new comparable model. The labor fee alone might equal what you paid for it.
Jan 08, 2009 | Magic Chef Microwave Ovens
My panasonic genius microwave is about 4 years old and it just died is there any way of fixing it
my microwave started giving me notices to check the manual and would stop cooking the food. I turned the machine off, unplugged and looked at the back panel. Was I surprised to find the air flow vents completely covered in black dust. After wiping it up with a cloth and then a small toothbrush to completely clean out the air holes, the microwave works fine. What a simple solution to something I was beginning to think would be a major repair job. Surprise---simple is best!!
Sep 29, 2008 | Panasonic Microwave Ovens
Noise/humming while cooking; especially popcorn; intermitent on other food
Popcorn is heated by a metallic insert in the bag. This causes some additional power consumption by the magnetron. It is no cause for alarm.
Dec 19, 2007 | Kenmore 80412 Microwave Oven
Kenmore 66469 / 66462 / 66464 Microwave Oven Logo
100 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
