Question about Whirlpool GH9176XMS 1100 Watts Microwave Oven
Everything works except it won't heat it worked one time and the next it didn't what is the most probable cause? there are no smells like something has burned
    Brigadier General:
  • 8,909 Answers
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Posted on Dec 28, 2010
My Frigidaire oven model feb386wech emits a burning plastic smell when heating up and cooking. What's causing this?
After 16 years of service, the oven may be starting to consume itself. I have found melted light fixtures and scorched, brittle wiring. If you can't isolate the source of the smell, it could be time to replace.
Nov 13, 2016 | Frigidaire Microwave Ovens
Kenmore 721.80403 microwave won't heat
If the turntable does move as well it is likely the inverter (power) or the Magnetron itself.
Nov 03, 2012 | Kenmore Microwave Ovens
Ge spacemaker microwave JVM1650 won't heat
sounds like possible magnatron or diode thats the case its not worth repairing. but if your handy then google model nuber and get the part be extreamly careful because of the power capacitor holds extream volts. turn off and allow to sit 15min before working on
Oct 23, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave isn't heating/cooking on any setting but the turntable, light is working. What should I check before calling a repairman?
There is nothing more you can do, you have verified everything is working except it is not heating the food. The next step is have the repairman come in to isolate the cause.
Jun 02, 2011 | Maytag MMV4205 Microwave Oven
Everything works except for the heating. CLocks, lights etc.
There are a few parts that will cause this problem, the first! a high voltage diode "opens or shorts" the second! is the high voltage capacitor becomes defective, next the magnetron is a common failure "heats the food" the least less likely to fail is the high voltage transformer. The cost for parts and labor will be on the high side to rectify the situation.
Jan 25, 2011 | Microwave Ovens
Microwave Heating Problems
Magnatron or the HV Transformer. Each has a distinct odor, Mag is heavy and thick burning smell transformer is more electrical. Eric
Aug 04, 2009 | Microwave Ovens
Limited heat power
It sounds like the transformer is shorting out on you but is not completely shorted.It will be shorting out on the output side of the transformer.this will give you a lower output level,and will cause the microwaves to be weaker.(less turns of wire in the secondary of the transformer).The short will probably get worse.Simply replacing the transformer should cure the microwave.
Jun 23, 2009 | Kenmore 63682 / 63684 / 63689 Microwave...
Everything works except heat
this is something you should probably call a repair technician for, due to the danger of the componentry.
Usually in ther case of this problem, even a technician will advise you to replace the unit, in the minds of cost effectiveness and safety...
Mar 21, 2009 | GE JE1540 Microwave Oven
Everything works... except the heat!
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can probably find an exploded view by entering your FULL model number here: http://www.searspartsdirect.com
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
If you think the problem is on the control panel, which we repair these nationwide for $39.95 postpaid.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 12, 2008 | Microwave Ovens
Whirlpool GH9176XMS 1100 Watts Microwave Oven Logo
37 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
