Question about Zephyr Hurricane AK2536 Kitchen Hood
Hood AK2536 installed without removable grease cup. Where can I buy 2 of them..
  • 8,197 Answers
Basic instructions to make bread in B48M
  • 1 package (1/4 ounce) active dry yeast
  • 2-1/4 cups warm water (110° to 115°)
  • 3 tablespoons sugar
  • 1 tablespoon salt
  • 2 tablespoons canola oil
  • 6-1/4 to 6-3/4 cups all-purpose flour
Directions In a large bowl, dissolve yeast in warm water. Add the sugar, salt, oil and 3 cups flour. Beat until smooth. Stir in enough remaining flour, 1/2 cup at a time, to form a soft dough. Turn onto a floured surface; knead until smooth and elastic, 8-10 minutes. Place in a greased bowl, turning once to grease the top. Cover and let rise in a warm place until doubled, about 1-1/2 hours. Punch dough down. Turn onto a lightly floured surface; divide dough in half. Shape each into a loaf. Place in two greased 9x5-in. loaf pans. Cover and let rise until doubled, about 30-45 minutes. Bake at 375° for 30-35 minutes or until golden brown and bread sounds hollow when tapped. Remove from pans to wire racks to cool. Yield: 2 loaves (16 slices each).
Oct 21, 2017 | Kitchen Appliances - Others
Emerson microwave mwg9115sl over heats then turns back on after 20 minutes
Your magnetron is overheating, which can be caused by:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
The first suspects in my book are fan failure, blocked vents, or bad magnetron.
Jan 10, 2013 | Emerson Microwave Ovens
How to change wheel bearings on jaguar xj6 front 1996
Disconnect the vehicle battery ground lead.
Support the vehicle at the front and remove the appropriate wheel.
Remove brake caliper and disc assemblies see SRO 70 10
Note- Do not allow the caliper to hang by either harness or
flexible hose.
Pry off the hub grease cap
Remove and discard cotter pin
pull off castellated nut retainer
Remove the hub nut and bearing washer.
Carefully remove the hub assembly from the stub axle.
Pry the original seal from the spigot and discard.
remove the bearings and using a drift punch knock out the bearing cups.
Remove all traces of grease and dirt from the stub axle and back plate.
Note: the backing plate may be used to pull the inner bearing and seal if they stay on the stub shaft.
Press in the new bearing cups using a socket or other tool of the correct size to prevent damaging the new bearing cup or hub.
Note: Do not use bearing to press in the cup.
Pack the annular gaps of the oil seal lips with grease.
Wash the hub assembly thoroughly.
Ensure that the hub inner seal diameter is free of debris or damage and is lightly lubricated prior to assembly.
Only replace complete bearings, never cup or race in isolation.
Pack each race with approximately 4 ml of grease and position the inner race onto the stub axle.
Apply a smear of grease to hub inner surfaces and bearing cups. Assemble the hub to the stub axle followed by outer race, bearing washer and hub nut.
It is not necessary to fill the hub cavity with grease, merely protect from corrosion with a coat of lubricant. Seat the bearings by slightly tightening the hub nut whilst rotating the hub. Do not apply load without rotation.
Adjust End float. Set a Dial Test Indicator and adjust the hub nut to achieve the correct end float.
.001-.003"
As the adjustment is made, continually load the hub axially in both directions.
Without disturbing the end float setting, fit the castellated
nut retainer so that it aligns with both hub nut and stub axle drilling.
Secure nut retainer using a new cotter pin.
Reassemble brake rotor and caliper. Bolts MUST be tightened to specification
operation of the braking system verified.
Reassemble wheel
Dec 25, 2010 | 1996 Jaguar Xj Series
How do u change the rear bearings?
Hello Friend:
#1) Raise Car in The Rear Support it Good on Jack Stands.
#2) Remove your Wheel or Wheels if Doing Both Sides.
#3) Now Right in The Center of Your HUB you'll see a Dome Cap Remove the Cap,Now Remove the Cotter Pin, then the Spindle Nut and Washer.
#4) Now you'll pull your Hub Assembly Off ,The Outside Bearing will more or Less Fall off the Hub.But you'll need to Remove the Outer Bearing Race Its the Metal Angled Race.
#5) Before you remove the Outer Race take a Seal Remover and Remove The Grease Seal on the Inside of Hub.
#6) Now the Inner Bearing Will Come Out.You NOW Can Remove Innner and Outer Races.Use a Puch and Hammer Lightly Tap it by Working your Punch Side to Side.
#7) Now You've Remove BOTH inner and Outer Bearing Assemblies.
#8) Before you Start to Install New Races ,Get some Brake Clean and Clean The Inner Hub and the Spindle Good.
#9) Use a Bearing Race Installer Tool to Tap your New Bearing Races in.NOTE: you Don't want to Scar the Beveled Part of the Race Cause thars Where your Bearings Rotate.
#9) Races are in : Now take a Wheel Bearing Packer if you have 1 Availible: If not Pack As Much Heavy Duty Hi Temp Bearing Grease Into the Bearings. And Put some on the Spindle Were your Bearing Run on.
#10) Now Using a Seal Installer Tap your Inner Grease Seal into the Inner Hub Housing.
#11) OK Now your Ready to Put Your Hub Back on:Note: Put a Little Grease in The Domed Cap after you've Got the Hub On.
#12) DON"TS Get Grease on your Brakes or anywhere in The Brake Pad Assembly. #2) Don't Use the OLD Cotter Pin Get a New One. :#3) When Adjusting your Spindle Nut Don't Under Tighten or Over Tighten==Just Snug it down where theres no Play when you Take your Hands 1-Top=1 Bottom and Make Sure theres No Play.
Rotate The Hub During And When Tightening your Spindle Nut.
Put Hub Grease Cap on and Whell or Wheels and you Should be Good to Go.
Thanks for Using Fixya Please let me Know the Quality of my Advice/Solution by Voting Thank You From: d_hubbs
Jul 23, 2010 | 1993 Mercury Topaz
How to replace rear wheel hub
Sodium based grease is not compatible with lithium based grease. Do not lubricate the wheel bearings without first thoroughly cleaning all old grease from the bearing. Use of incompatible bearing lubricants could result in premature lubricant breakdown.
  1. Raise and support the vehicle safely.
  2. Remove the wheels.
  3. Remove the brake drum or brake disc.
  4. Remove the hub grease cap.
  5. Remove the cotter pin retainer, adjusting nut and flatwasher from the rear wheel spindle. Discard the cotter pin.
  6. Remove the outer bearing and cone assembly.
  7. Remove the rear hub from rear wheel spindle.
  8. Using Seal Remover (TOOL-1175-AC) or equivalent, remove and discard the oil seal.
  9. Remove the inner bearing cone and roller assembly.
  10. Clean the inner and outer bearing cups with solvent. Inspect the bearing cups for scratches, pits, excessive wear and other damage. If the bearing cups are worn or damaged, remove them using a Bearing Cup Puller (T77F-1102A) or equivalent.
To install:
  1. Throughly clean old grease from the surrounding surfaces. If a new hub assembly is being installed, remove the protective coating using degreaser.
  2. If the inner or outer bearing cups were removed, install replacement cups using Bearing Cup Replacer (T73-1202-A) or equivalent. Seat the cups properly in the hub.
If a bearing packer is not available, work as much grease as possible between the rollers and cages. Grease the cone surfaces.
  1. Using a bearing packer, pack the bearing cone and roller assemblies with a premium bearing grease.
  2. Place inner bearing cone and roller assembly in the inner cup. A light film of grease should be included between the lips of the new grease retainer.
  3. Install the retainer with Hub Seal Replacer (T83T-1175-B) or equivalent. Be sure the retainer is properly seated.
Keep the hub centered on the spindle to prevent damage to the retainer and spindle threads.
  1. Install the hub assembly on the spindle.
  2. Install the outer bearing cone and roller assembly on the spindle.
  3. Install the flat washer and nut. Tighten the nut to 18-23 ft. lbs. (24-31 Nm) while rotating the hub to set the end-play. Back off the nut and retighten to 18 inch lbs. (2 Nm).
  4. Install the new cotter pin.
  5. Install hub grease cap.
  6. Install brake drum or disc.
  7. Install the wheels.
  8. Lower the vehicle.
May 04, 2010 | 1998 Ford Windstar
How do you install the hood release cable on a 96 honda civic dx?
TOOLS:
Screw Driver, Plastic Cup to place your bolts.
STEPS:
1. Buy a new latch for $20 max. or $5 from your local junkyard
2. Open your hood. Take out your grille. Front bumper. Driver side fender and plastic fender cover.
3. Take the plastic panel covering the hood release latch. (should have 1 plastic screw, just pop that with a flat-head screw driver)
4. Remove bracket (2x -10mm bolts)
5. Remove the entire broken hood release with your new one.
6. Place everything back
7. Enjoy!
Oct 22, 2009 | Honda Civic Cars & Trucks
Built up grease in oven
I've found the best way to get grease to loosen up in any oven is to place a glass or coffee cup of undiluted ammonia in the oven overnight. The ammonia vapors attack the grease, softening it. The next day:
  1. remove the ammonia
  2. mix it with a 2 cups of water
  3. wear protective gloves
  4. using a non-abrasive cloth or sponge wipe the grease off the surfaces.
  5. switch to clean water only, wipe the oven one last time to remove the ammonia residue left by the cleaning.
Mar 29, 2009 | GE Advantium 120 Convection/Microwave Oven
Can't get the old hub off
hello again
i think the chat has occured a problem anyway i will continue here
  • Using seal removal tool 1175-AC or equivalent remove and discard the grease seal. Remove the inner bearing cone and roller assembly from the hub.
  • Clean the inner and outer bearing assemblies in solvent. Inspect the bearings and the cones for wear and damage. Replace defective parts, as required.
  • If the cups are worn or damaged, remove them with front hub remover tool T81P-1104-C and tool T77F-1102-A or equivalent.
  • Wipe the old grease from the spindle. Check the spindle for excessive wear or damage. Replace defective parts, as required.
To install:
  1. If the inner and outer cups were removed, use bearing driver handle tool T80-4000-W or equivalent and replace the cups. Be sure to seat the cups properly in the hub.
  2. Use a bearing packer tool and properly repack the wheel bearings with the proper grade and type grease. If a bearing packer is not available work as much of the grease as possible between the rollers and cages. Also, grease the cone surfaces.
  • Position the inner bearing cone and roller assembly in the inner cup. A light film of grease should be included between the lips of the new grease retainer (seal).
  • Install the retainer using the proper installer tool. Be sure that the retainer is properly seated
gOOD LUCK PLEASE ACCEPT SOLUTION
Mar 19, 2009 | 1996 Ford Explorer
Cleaning Zephyr Hurricane AK2636 kitchen hood
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Feb 28, 2009 | Zephyr Hurricane AK2536 Kitchen Hood
Zephyr Hurricane AK2536 Kitchen Hood Logo
138 people viewed this question
Top Zephyr Kitchen Ranges Experts
reliableservice
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
