Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Machine has power to it but wont work at all - Whirlpool Ultimate Care II LSQ9549L Top Load Washer
  • 57 Answers
Will it fill? Could be a bad wire in to the control. If it fills and does nothing then check the lid switch. Kinda vague hard for me to tell with out much more info.
Posted on Dec 28, 2010
Wont start
the on/off switch could have gone out, make sure the wall outlet is working also, could be the power cord could be the problem, the machine needs to be serviced after sitting so long.
Dec 06, 2015 | Sewing Machines
The on and off switch wont turn on
Check Power
Check the outlet by plugging an appliance into the same outlet the washer was plugged into an running the appliance a hair dryer works good for this it will draw some amperage. If it works fine move on.
Control
To check the control remove the top panel and then remove the console to access the wiring to the control. Find the wire feeding the control from the main power cord. If you cannot visually see this refer to the tech sheet or service manual. Connect voltmeter to the 2 wires feeding the control if it is recieving power and it does not respond replace control
May 23, 2013 | Hotpoint Washing Machines
Had power cut now machine wont work changed the fuse still nothin
check power from the wall socket if its ok the doorlocks and motors are prone to blowing the circut board can be expensive
Jul 30, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine wont spin
Your machine may not be receiving adequate voltage to start. Make sure your machine is plugged in. Also, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Or check to make sure no fuses in the fuse panel are blown. Try plugging something else into the same outlet. If it won't work either, then there is likely something wrong with the power outlet. Any of these could be the reason power is not getting to your machine. Also, refrain from using an extension cord to plug your machine in.
Dec 03, 2008 | Indesit W 123 Front Load Washer
My ps3 wont turn on and i think a disc is inside. what do i do?
I just want to let everyone know that I had the same problem. This isn't a fix to make the machine work again. This is a fix that will let you get a disc stuck in the machine out when the ps3 won't power on. Turn the machine power off via the switch in the back. Hold the power button on the front of the machine down for about 15-30 seconds. Then, without letting go of the power button on the front of the machine, turn the switch on in the back. This made my machine power on for about 20 seconds, just long enough for me to get the disc out of machine. I could then take the ps3 back to the retailer I purchased it from. Just to clue everyone in on a possible cause of this problem, the woman from Sony techical support, the one who told me this trick, said that this is happening only when playing Activision games. For me it was Call of Duty 4. Binary Bob
Nov 30, 2008 | Sony Playstation 3 (PS3) Console
E-machine t2682 desktop
cpu setting in good jumper on mobo set on 1 2 pin not 2 3 for reset ? could be bad mobo what socket mobo do uuusse
Jan 21, 2008 | E-Machines T2682 (000002965) PC Desktop
Wont work at all
Need to know the model number and serial number before I can assist you
Jan 09, 2008 | Maytag Atlantis MAV8000
F&P GW511
Try just unplugging the machine for a while....letting the circuit board clear any "memory". I worked for me with a spin cycle issue.
Sep 23, 2007 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
14 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
