Question about Braun Pulsonic Rechargeable Cordless Men's Razor - Silver
My cleaning container will not go to green after I insert a new cartridge. Never had this problem before. This is my fifth Braun shaver. I have a pulsonic. It is about thirteen months old. Shaver works perfectly. I can not clean razor. Please tell me what I can do.
  • 3,083 Answers
Are you using the cleaning solution? On the following web blog, it talks about the razor, and mentions the cleaning solution, that is needed:
http://www.shavingstuff.com/archives/014524.php
I saw similar problems reported on the net, and they had to send the unit in for repair and replacement of some "parts".
You might contact Braun, and see what support they can offer you. Here's their site:
http://www.braun.com/
Good luck, and hope this helps.
Posted on Jan 02, 2011
9595 Charger won't charge while in stand
Your charging and cleaning stand is faulty. They are not repairable because parts are not available. You can purchase a new clean and charge stand at shaveroutlet.com
Braun Series 7 and Pulsonic Clean Charge Base
May 21, 2017 | Braun Shavers Male Pulsonic System 9595CC...
How can I clean my braun washable series 3 (330) shaver. better. I can take it apart so far but just cant get under the blades
This model uses a 'shaving cassette'. The blades can not be removed from the foil assembly. Braun's instruction is to simply rense the shaving head under hot running tap water. Unfortunately, this does not work very well over time due to the poor design of these parts. Once they become clogged up it is usually necessary to replace the cartridge.
If replacement is needed you will find one at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-series-3-shaver-foil-and-cutter-head-cassette-32s32b-p-835.html
Jul 27, 2011 | Health & Beauty
I replaced the cleaning liqud cartridge but it shows the red light indicating it is empty.
here is the solution..follow the steps please..
Thanks in advance for rating me..Regards
  • Replace the cartridge in the base station and close it.
  • The indicator light should cycle then change to green. If it doesn't then unplug the base station, wait a few seconds, then plug it back in.
  • Press the lock button to clean the shaver. If everything went well it should start cleaning like normal.
    Aug 27, 2010 | Braun 360° Complete Electric Shaver
    The red cartridge light is blinking on my dock. What does this mean? A while ago, the dock fell over and all the cleaner liquid fell out, so maybe I just need a replacement for the cleaner liquid. If so,...
    Re the light:
    When the «cartridge» light starts flashing, the remaining fluid in the cartridge is sufficient for approximately 5 more cleaning cycles. After these 5 cycles, the cleaning performance will be reduced and the cartridge has to be replaced.
    When the «cartridge» light illuminates constantly, the cleaning function is locked and a new cartridge has to be installed.
    Only then, the next cleaning cycle can be started.
    To find a replacement, Refer to http://braun.com/ to find the website for your country.
    Otherwise, refer to http://braun.com/us/consumer-service.html which will help you locate a local Service Center.
    Mode number for the cartridge is CCR2
    May 26, 2010 | Braun Syncro 7680 Electric Shaver
    Red "empty" light on Braun Clean & Renew fluid turns on too soon
    Put a few drops of tap water in the solution if the light goes red until it goes out. Cheap, green way to reuse the plastic container!
    Total Cartridge Size = 170 ml
    DIRECTIONS:
    1.) Clean old cartridge with 70% Isopropyl alcohol
    2.) Add 3 ml of Lemon oil
    3.) Add 3 ml of glycerin
    4.) Add 2 ml of water
    5.) Add 70% Isopropyl alchohol to 3/4 of the top of the cartridge
    COST ANALYSIS:
    16oz (473ml) 70% Isopropyl alcohol = $1
    16oz (473ml) Glycerin = $10
    16oz (473ml) Lemon oil = $8
    Cost Savings on one unit
    Normal = $11
    Homebrew = $0.81
    Savings = $10.19 per refill
    Dec 15, 2009 | Braun Health & Beauty
    Just bought braun 8585 electric shaver, return it to the store as nothing happens while charging. Got a new one and still not able to charge it, shouldn't the indicator turn red or green? nothing happens....
    Did you insert a cartridge into the cleaning base? It needs that in order to work. Otherwise, try plugging the charger directly into the shaver. It should definitely charge the shaver, as long as the shaver is fine. Depending on the model, the charging indicator may be green or blue.
    Jun 03, 2009 | Braun 8585 Electric Shaver
    Braun Syncro 7680
    the red light tells you it is cleaning, a green flashing light tells you it's charging
    Jul 28, 2008 | Braun Syncro 7680 Electric Shaver
    Cleaning solution .
    I've heard of other people refilling the cleaning cartridge with other solutions rather than buying a new one. I understand the genuine article contains a lubricant as well as a solvent. You might have to manually lubricate the cutter head if you use a solution that does not include lubricant.
    Dec 19, 2007 | Braun Syncro 7526 Electric Shaver
    Braun Pulsonic Rechargeable Cordless Men's Razor - Silver Logo
    228 people viewed this question
    Top Braun Health & Beauty Experts
    shaveroutlet.com
    shaveroutlet.com
    Kazim ERGUNEY
    Kazim ERGUNEY
    Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
