Question about Compaq Computers & Internet
Crashed while installing windows updates only fans running nothing else.
  • Compaq Master
  • 27,725 Answers
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Posted on Dec 28, 2010
Display driver
If you have windows 7 and windows 8, your computer must be running in VGA driver by default, as no driver is present, run windows update,
it will install all the required updates automatically .
Or you can go to device manager in system under control panel,
and manually update driver searching from internet.
Dec 10, 2013 | Acer Veriton M480 M488 Vs480g Desktop Pc...
I'm try to install new window 7 64 bit into compaq presario c700 ,but load and stand after window load. it says window starting and nothing happen.
Hi there !
If there is problem on loading you window 7. Try to run it on safe mode by pressing F8 when starting to reboot your computer. When running on safe mode, windows will automatically fix some error regarding some loading problems.
After press F8, just choose run on safe mode and it will read and fixed all errors on drivers. Computer can crashed because of faulty drivers installed or too many same drivers installed. This solution will fix your problem.
I hope it helps you. Thank you for using FixYa !
Jan 09, 2011 | Computers & Internet
Previous PC crashed, replaced it with a HP running Windows 7 Home Premium. Have zero sucess in trying to install it. Downloads updates and then downloads the installer. Then it quits trying.
If your tryintg to install the windows seven try from the boot menu to boot from cd,. once you start up make sure to partition the drive so theres nothing lef ton it and you ould be all set.
Jan 06, 2011 | Computers & Internet
Service pack 2 for xp crashes the system
Access http://www.microsoft.com/downloads
and download XP Service Pack 3, and install it.
It is *NOT* necessary to install SP2 _before_ installing SP3.
After installing, run Windows Update (for another 80+ updates issued since SP3 was issued).
Dec 26, 2009 | E-Machines M2350 Notebook
Update KB946140 and Error Code 646
Sometimes MS update has compatibility issue.Better no to install cause sometimes it can create a bug (Blue Screen Crash) to your system.Try to restore yor windows 7 to an earlier point and the error message gone.Also try to turn off your automatic update so that you can choose your update to be installed.
Nov 09, 2009 | Microsoft Outlook with Business Contact...
Is there a fix for Windows XP Home SP3 crash? my computer crashes all the time, i can format but i thought that there may be a fix because this is a known issue and many people have the same problem. If...
To make it short, you can try un-installing SP3, but the reason you computer is crashing is due to a program that is having incompatibility issues. That doesn't meant that your programs can run on SP3, it mean your programs and maybe even your drivers were install when you had SP2 and they didn't like the service pack update. You can definitely try to find which programs or driver are causing the problems but I recommend. Do a full format(non quick) and then a fresh install of windows and then update windows, and also try to download the latest drivers from the manufactures website and then install your programs.
**So yes I recommend an operating system re-install.
May 14, 2009 | Microsoft Windows XP Home Edition
BIOS Update Problem
If your laptop is only 3 months old it should be covered by warranty with Toshiba, the best course of action would be to consult them regards this issue.
Mar 22, 2009 | Toshiba Satellite Pro L300D-EZ1006V...
Computers & Internet Logo
16 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
