Question about Electrolux Pronto 2-In-1 Stick/Hand Vacuum - Cayenne
I have a Electrolux Pronto 2 in 1 Mod.EL 1000 Type B Ser. 073803699 it has 6 rechargeable batteries.... I need replacements... Where do I get them and how much...
5 Suggested Answers
  • 2692 Answers
SOURCE: Electrolux Pronto 2-in-1: Looking for a part
Here is their on-line store to get the parts that you needed.
http://electroluxservice.stores.yahoo.net/
Posted on Jan 02, 2009
SOURCE: can the battery be replaced?
No but there was a recall on the battries, so try calling electrolux usa and they should replace it for free.
Posted on May 01, 2010
  • 3 Answers
SOURCE: Battery for electrolux pronto stick vac 2 in 1
The battery replacement for the PRONTO is not a consumer level maintenance procedure.
However, I just replaced the 4 original EMX1600sS batteries by anotther model with the same specs and my PRONTO is working fine now. The battery model is
Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs
Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web.
There are other similar models available that could be used but have in mind the limitations for the dimensions and capacity in mAh.
The dimensions of the original cylindrical batteries are aprox. 33 mm (1 1/4") X 22mm (7/8").
Anything under those specs should work.
Good luck.
Posted on Dec 08, 2010
  • 2418 Answers
SOURCE: Is it possible to replace the battery (loosing
Let me say this; The battery replacement for the Electrolux is not a owner level replacement procedure. However, you can replace the 4 original EMX1600sS batteries . The battery model is Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web. Anything under those specs should work. These types of battery's will cost about $15.00 on the web.
Posted on Jan 27, 2011
WILL NO CHARGE
The battery is probably no longer rechargeable due to age or to the number of times it has been recharged. If the battery can not be replaced, then the entire vacuum needs to be replaced with a new one.
Aug 02, 2015 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Batteries are not recharging. Where can I get replacements for Model EL1000 Pronto Vac?
Let me say this; The battery replacement for the Electrolux is not a owner level replacement procedure. However, you can replace the 4 original EMX1600sS batteries . The battery model is Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web. Anything under those specs should work. These types of battery's will cost about $15.00 on the web. The battery's are in the hand held unit bottom or back side area, you access them by taking out all the screws in the back side of the hand unit.
Jan 15, 2011 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Is it possible to replace the battery (loosing charge fast, weak power) for Electrolux stick vac EL 1000? Wher to buy the battery an dhow much cost? Thanks LJ
Jan 12, 2011 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Rechargable batteries need to be replaced
you may not need batteries just a new charging plug. if the batteries are damaged all you need to do is replace the handheld part of the pronto, this is where the batteries are located.
Jul 09, 2010 | Electrolux EL1000A2 Pronto Bagless Stick...
Electrolux 2-in-1 Pronto does not hold charge, I believe it's a battery problem. How do I get then replace the battery, since it is located in the hand vac part of the vacumn?
Good luck.
Jun 28, 2010 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Can the battery be replaced?
Apr 17, 2010 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
This battery works perfect too (for your model), take a look on amazon: Amazon com tenergy 2 3a 1600mah nimh. Cheers
Dec 22, 2008 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Battery needs to be replaced in eletrolux pronto 2 in 1 stick vacum,can i order one
Good luck.
Sep 02, 2008 | Electrolux Vacuums
Electrolux Pronto 2-In-1 Stick/Hand Vacuum - Cayenne Logo
188 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
