Question about Keurig B100 Coffee Maker
Water will not go through. Water is not going through. put vinegar in the water dispencer but it wont put it through, Can I take the top off to get at the water compartment inside to clean it?
heatman101
  • 43501 Answers
SOURCE: my keurig will not pull in water. I cleaned it
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 13, 2011
  • 14 Answers
SOURCE: keurig coffee maker will not
Have you tried to de-scale your coffe-maker, and rinse it thoroughly?
If yes, according to the user manual, page 15
You should call Keurig for support when it still says "add water"
(http://www.keurig.com/help/B60_Use&Care_guide_spreads.pdf)
Posted on Dec 07, 2008
  • 76 Answers
SOURCE: Water will not come out
The heater element might be burnt out as opposed to a blockage - is the "trickle" hot and is there any steam - if so then lets assume a blockage - try CLR (Calcium, Lime and Rust) remover - excellent solution for this type of issue - the instructions for use are simple - when complete just run through a couple of cycles to make sure it is safe water again. CLR is available from hardware stores and is around $6 or $7.
Posted on Mar 18, 2011
heatman101
  • 43501 Answers
SOURCE: My keurig stops releasing the water after about an
heatman101
Posted on Aug 15, 2011
  • 586 Answers
SOURCE: machine has water still in cold part at the top.It
Hello there,
Are you sure you did the vinegar thing properly, because that seems to be an effective way of getting the water out of the top.
Unplug your coffee machine and allow to cool before cleaning. Clean outside of the machine by wiping with a clean, damp, nonabrasive cloth. Slide the drip tray toward you to remove and wash with warm, soapy water or place in the top rack of the dishwasher. Remove the K-cup holder by grasping the top with one hand and pushing up from the bottom with the other hand. Pull the funnel from the holder to remove. Wash the K-cup holder and funnel with warm, soapy water or place in the top rack of the dishwasher. Remove water reservoir from machine and wash it in the sink with warm, sudsy water or place in the dishwasher. The lid is not dishwasher-safe. Replace all parts that have been cleaned. Drain any water from your Keurig coffee maker. Fill the reservoir with 48 oz. of undiluted white vinegar (B100 uses 64 ounces of vinegar, and the mini personal brewer uses 8 oz.). Place a ceramic cup on the drip tray. Brew the vinegar into the cup then pour into the sink. Brew three more times. Fill the reservoir with fresh water and allow the machine to sit for four hours. Brew again until the reservoir is empty of all water.
If that was what you did in the first place. Thenthe next solution is for you to get the machine disassembled and drained of the water.
Hope this was helpful to you. Goodluck Elect_Comp
Posted on Sep 02, 2011
My kenmore he2 wont dispence the soap in the soap dispencer
Evening to you
Allow the washer to start a cycle and have the dispenser drawer ajar and observe through which dispenser the water goes.
Does the first stream go through the pre-wash dispencer,secondly notice where the main stream goes and lastly where the softener would go. If this can help you in any way just put use the dispencers as fits the washing.
goodluck
Kolbrun
Feb 26, 2012 | Kenmore HE2 Washing Machines
Water dispencer from inside fridge isnt dispencing water. makes noise like it wants to but wont. can my water line be frozen? my fridge is usualy pretty bare and the temp is on 6.
It is very common for the water dispensing tube to become frozen if there is a slow drip coming from the water fill solenoid in the back of the refrigerator.
May 29, 2011 | Refrigerators
The water comes out the top of the manuel filter so not all the hot water goes through the holder. the coffee is loosely put in the filter
Try running vinegar through the Keurig to clean and de-scale it. You should use white vinegar, run it through using several cups until there is no vinegar left, then use clean water to brew plain hot water until you can no longer smell vinegar. This will help de-scale the Keurig and potentially remove any plugged bits of coffee that may remain.
Mar 01, 2011 | Keurig Coffee Makers & Espresso Machines
Does not dispence right amount of water
2,,2,2 you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 19, 2010 | Keurig B60 Coffee Maker
It's not making ice. It's not even getting the water flow in order to make ice but the water dispencer is dispencing water.
If it will kick a batch out if you add some water to it then your water valve needs replacement. if it has ice in it but wont spit any out then your ice maker is bad. Some nice repair pictures: HERE
Dec 31, 2009 | Refrigerators
ICE MAKER NOT GETTING WATER AND ICE IS NOT DISPENCING EVEN IF WE
first check if you have frost build up in freezer 2 could be ice maker 3 water valve
Apr 05, 2009 | Kenmore 57029 Side by Side Refrigerator
Water over flowing in soap dispencer Whirlpool sport duet washer
A sock was in between the two tubs blocking the water going tnto the main tub. This caused the water to backup and overflow in the soap dispencer..and all over the floor I then put my hand in between the two tubs and pulled the sock out. Thanks to the expert group for giving me this solution.
Mar 20, 2009 | Kenmore Elite 45986 Front Load Washer
Water pouring from detergent, bleach, etc.. dispencer. Help!
This is joyce
He is right the Jets are probl stoped up with mold,
you need to take drawer out look to top of machine where water comes into drawer to dispense to your detergetnt, and see if their is mold, if so take squirt bottel full of bleach and squirt it up on the mold and let sit a while and then take tooth brush and scrub off as good as possible, run one cup bleach in machine with out any clothes . on hot cycle. do this 2 times see if this helps .
let me know. it can only help cant hurt.
willl make machine smell better, and never shut door to front loader completly shut, it needs air to dry or else it will mold.
thanks
joyce
Feb 11, 2009 | Maytag MAH8700A Front Load Washer
WATER DISPENCER DOES NOT WORK, YOU CAN HEART THE MOTOR GOING BUT
first thing to do is to remove the lower back panel behind the frige and disconet one of the water lines that goes to the top back of the frige and push the switch to get water with the line of. do that to the 2 lines one at to give you water back there. if none of the lines gives you water back there 100% that plastic valve needs replacing.
Dec 09, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Jan 27, 2008 | Kenmore Elite 45986 Front Load Washer
Keurig B100 Coffee Maker Logo
750 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
