Just replaced genuine ink cartridges with originals, no compatibles and I'm getting horizontal hit and miss lines when I copy a document from my computer. I've tried the nozzle and head clean, turned printer off and then on again 6 hours later but no improvement. Colour crtridges seem ok, just the black
    Problem Solver:
  • 8 Answers
Does it have ink jet print heads they may need replacing as well as the ink cartridges.
Posted on Dec 28, 2010
Poor print quality
Make sure you are using genuine Lexmark cartridges. Lexmark products work best with original supplies. Lexmark does not recommend the use of refilled, re-manufactured, or clone cartridges. You might not get the print quality you expect from ink that is specially formulated by Lexmark.
Check your cartridge ink levels. From the printer operator panel, go to Maintenance > View Ink Levels. Replace the cartridge that has low ink level. If your ink levels are still substantial for printing and you are using genuine Lexmark supplies, please contact Lexmark Technical Support Center for further assistance.
Dec 28, 2011 | Lexmark X9350 All-In-One InkJet Printer
Original Vs Compatible Ink Cartridges - Which is Better?
If you will be printing large numbers of documents and other files then compatibles make good financial decision.
Compatibles are cheaper than originals. However you should check that you are getting good quality compatible ink cartridges.
As long as you are printing at least once a week then compatibles will serve you well without problem. To keep your printer in tiptop condition you should swap for an original cartridge once in a few months. This may seem like a foolish idea when you are saving money, but an original cartridge will help clean your print head and keep your machine working optimally.
If left for a long time ink can dry out in the cartridge and on the print head causing damage. Original ink usually has extra chemicals and agents to prevent this from happening. As you are likely to have to buy a new compatible cartridge if this happens any cost saving you achieved lost immediately.
Aug 12, 2010 | Brother Office Equipment & Supplies
How to print using black ink only on Espon dx5050?
Did you use Epson Genuine Cartridges??
ALL…. Epson & Brother Requires Genuine Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother MFC-240C All-In-One InkJet Printer. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
If you have Genuine Epson Cartridges, and have ink in ALL THE CARTRIDGES, to print in black only, Make the following settings on the control panel. SEE BELOW:
Select the number of copies.
Select l [Plain Paper].
Select the paper size you loaded.
To make a color copy, press the
x StartE[Color] button.
To make a black-and-white copy,
press the x Start D [B&W] button.
If you find this information helpful, pls rate me.
You can download the entire manual. Just click on link below. I found on the web:
http://safemanuals.com/314159.php?k=3c8871ac74c76c7b6bdba73063efb872&ID=552849&q=EPSON%20STYLUS%20DX5050
Thanks and Good Luck
and pls rate me.
Feb 16, 2010 | Epson Stylus DX5050 All-In-One InkJet...
My printer keeps leaving lines through my documents I have cleaned the heads all other bits several times.
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 05, 2010 | Epson R245 InkJet Photo Printer
Can I print a document without color ink?
Jan 31, 2010 | Epson Stylus Photo R300 InkJet Printer
MFC-240C. replaced black ink cartridge. I've done so before ok. This time we had the original refilled. The computer shows it full, but when you hit print nothing happens. thanks
Did you use Epson Genuine Cartridges? Brother Genuine Cartirdges????
IF YOU ARE USING GENERIC CARTRIDGES, MAYBE IT WOULD BE
BE BETTER IF YOU DISABLE THE INK MONITOR.
The next step would be to disassemble and clean the Pads/Heads.
A good Forum below Click on link below.:
http://www.fixyourownprinter.com forum, which had plenty of details about similar issues.
Jan 28, 2010 | Brother Multi-Function Center MFC-240C...
My printer was printing fine, iloaded new ink
Epson does not like Generic/Compatible Cartridges
MUST BE GENUINE
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
Put back in Genuine Cartridges, and see if it works. This is the only advice I can give you. If you find this helpful, pls rate me.
Jan 04, 2010 | Epson Stylus DX4450 All-In-One InkJet...
Put in a compatible red ink cartridge but no red ink printed. Can't put in the original cartridge in to verify the printer as it is detected as empty. However, for other colors that I replaced with same...
So, is the new cartridge "compatible", or is it not as compatible as they claim?
Try a "genuine" replacement cartridge.
Start the software that came with the printer.
There is a "ink-jet test" utility, and a "head-cleaning" utility.
Run each of them, to see if anything is "clogged".
Dec 05, 2009 | Office Equipment & Supplies
Wrong colours!
Hi Dannydoda,
I understand that, you are using different compatible ink cartridges and having problem with colors.
HP printers has a small built in firmware, which can detect the original ink cartridges and the ink level.
Using other compatible ink cartridges may damage the print heads of the printer.
I suggest you to replace the ink cartridges with original or Genuine HP cartridges.
You can also try some of the steps to fix the issue as given in the web link.
please click on the web link given below and perform the steps carefully.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00042885&cc=us&lc=en&dlc=en&product=79499
This should fix the issue.
Have a great day!
Mar 21, 2008 | HP PSC 2210 All-In-One InkJet Printer
Blue lines running through my image
Did u use the original ink cartridges or compatible ones or refilled?
Jan 18, 2008 | Epson Stylus CX6000 All-In-One InkJet...
37 people viewed this question
jasbo
jasbo
