Question about Roland Fc300 Guitar Foot Controller
I have a electric guitar, an amplifier and my new roland fc 300 and i need to connect all together. is that possible or do i need something else? please help me!
  • Anonymous Mar 17, 2014
    can i use a roland e-09 keyboard and a roland fc 7 together
  • Roland Master
  • 5,603 Answers
You just need the cables to connect the devices.
Posted on Dec 29, 2010
How to connect Gk3 equipped guitar to Electric Piano or Synthesiser ?
A Gk3 cannot be connected directly to an electric piano or synthesiser. The 23 pin DIN connector connects the GK3 / GUITAR to a Roland guitar synthesiser which produces the synth tones . This unit can be connected via midi cable to any external keyboard or synthesiser...to produce different or varied tones from the external synth ........provided the devices are able to communicate with each other...see the midi implementation charts for each device for information....
Aug 30, 2015 | Roland GK3 Divided Guitar Pickup
How do I connect my roland piano 5500 to an amp
On the rear of the piano there will be two 1/4" jacks labeled Output Left and Right. One will be labled Mono as well. If you are using a stereo amp, use both, and if a mono amp use just the mono output. If your amp is a guitar type, connect a shielded cable with 1/4" phone jacks such as you'd use with an electric guitar from these jacks to your amplifier. If you are useing a home stereo amp, you will need a cable with 1/4" phone jacks from the piano to RCA phono jacks on the amp end.
Oct 08, 2014 | Roland HPI-7F 88-Key Digital Piano -...
Roland troubleshooting
Are the speakers hooked up? volumes up? Is the guitar using active pick-ups? if so, is the battery good? is any noise coming thru the amo?
Jul 18, 2014 | Roland Ac60 Acoustic Chorus Guitar...
Static at louder volumes
All you need to confirm is to remove the connection to the guitar, remove the jack and cord to the guitar and now check if the noise is prevalent at higher volume, when the volume control is turned up. If so the fault is with the cord , the jack or the gutiar pick up insulation or internal connection or shielding.
Cross check with a seperate cord or another amplifier to confirm the case.
If the noise is from within the amplifier then it is possible there is fault in the preamplifier, fault with shielding of the inputs or the preamp, broken groung connection.
Compliments of the Season.
Dec 24, 2011 | Roland Ac60 Acoustic Chorus Guitar...
No audio output. muffled output from Phones jack
you need to check the power supply of the amplifier with the help of a voltmeter. if that is OK the power amplifier IC(integrated circuit) is gone bad, see for overheating of IC.
Sep 26, 2011 | Roland Ac60 Acoustic Chorus Guitar...
I am getting buzz, ******* noise with low Aon E string and open A, also the A on the 12th fret, its just below a, a flat is also causing a buzz, the micro tune is new, i had played with a friends over the...
This sounds like fret buzz caused by improper setup of the guitar. Likely the intonation needs to be set and the string height... possibly a truss rod setup as well. Take the guitar into a shop for setup unless you are adept at setting. There are a couple videos on guitar setup on YouTube, however do NOT try a truss rod adjustment yourself.
Jun 23, 2011 | Roland MICRO CUBE RX Compact Guitar...
Where can I buy a FC-300 RRC2 Board and connecting cable to repair a Roland foot controller?
More than likely you would have to contact the manufacture [Roland} for a replacement part. You can also search ebay.com for the product in question, maybe you'll find something inexpensive that you can use for parts.
Apr 04, 2011 | Roland FC-300 (MIDI Foot Controller)
I have noticed a buzzing sound generated from the amplifier when I play my low e string
Several possibilities come to mind:
The speaker is driven too far mechanically causing the voice coil to go into a non-linear region.
The cabinet, stuff inside, grille cloth, or even a logo on the cabinet is resonant and rattles.
Your guitar setup is not quite right leading to "fret buzz"
To troubleshoot, reduce volume and see if that helps...
Mar 04, 2011 | Roland Cube 40XL Guitar Combo Amplifier...
Roland Fc300 Guitar Foot Controller Logo
59 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Roland Music Expert? Answer questions, earn points and help others
