Question about Whirlpool Dryers
I have a WHIRLPOOL LE7000XSW0 dryer. I recently replaced the thermal cutoff because it quit heating. Now it heats but is taking 3 cycles to dry a load. I tested all the elect. components , the heating coil is not grounding. My multimeter reads 3-4 on the ohms setting when I test my thermostat. Does it sound like that may be the problem?
    Brigadier General:
  • 4,088 Answers
If the heater is heating, probably the thermostat is ok. What does the ohmmeter read when you just short the two test leads together? Suspect low air flow through the machine--clean all passages including the outside vent of lint. Remove the lint screen and clean it of fabric softener deposits by washing it in hot water and detergent. Hope this helps!
Posted on Dec 28, 2010
  • momisme2 Dec 28, 2010
    It reads infinity, ie the needle swings all the way to the right. it reads this when I test the themal cutoff, the high-lo thermostat, and the heating coil. The only part that reads at this 3-4 on the scale is the thermostat itself. I did try cleaning all the vents, I cleaned the chute out with a long radiator brush. I also dismantled the vent right where the blower fan blows into it and cleaned it out good. It was dirty but after reassembling it, it still doesn't dry in one cycle like it used to.
  • drallim Dec 28, 2010
    On an analog type ohmmeter, when the test leads are shorted together, the meter should read zero ohms (and adjusted there with the zero-adjust control. If it won't adjust there, replace the battery in the meter). All closed thermostats should read zero ohms and the heating element should read somewhere around 5 ohms cold. If any thermal switch reads any resistance above zero, it will promptly open due to the heat generated by the (relatively) high resistance of the contacts in the device when current flows through the switch. The thermostat probably should be replaced. The other possibility is if the heating element opens when it gets hot. (replace it if it does). You didn't mention if you cleaned the lint filter or not. Good luck!
Thermal cutoff switch fails 2x in a year. Heating coil ohms out ok.
Whirlpool Thin Twin, dryer thermal cutoff failed twice - Appliance ...
forum.appliancepartspros.com > Appliance Repair Help > Dryer Repair
Oct 12, 2011 - 6 posts - ‎2 authors
Friends Whirlpool Thin Twin came with purchase of condo half a year ago. A month ago it stopped heating. I checked continuity and found the ... Whirlpool Dryer Thermal Cutoff
Jan 9, 2013
Thermal cutoff blew again (Whrpl Elect Dryer)
1 post
Jan 5, 2013
More results from forum.appliancepartspros.com
Why does the thermal fuse keep blowing in my dryer ...
www.shopyourway.com > Manage My Life > Questions
Dec 28, 2015 | Dryers
Why do clothes take a long time to dry even if dryer is heating?
One basic reason is your washer could NOT be spinning most of the water out, therefore your clothes are wetter than they should be, thus taking longer to dry:-)
Jan 22, 2015 | Whirlpool Dryers
Why won't my whirlpool electric dryter #ler4634dqo generate heat?
if you have a old house that has fuses sometimes only half of the fuse will blow making it look like the dryer is working but it wont turn on the heat element take the shielding off the heating element and start the dryer and see if they wires glow red hot when running and also after running the machine does the inside feel warm or cold if it is warm check the duct work on the dryer all the way out to the exit and see if lint is clogging it up
May 05, 2014 | Whirlpool Dryers
I have a whirlpool dryer that won't heat. I removed the heating element and there were no breaks in the coils. I had the thermal cutoff tested and it was bad so I replaced it as well as the part
check the little 1"long x 1/4" wide white plastic fuse located on the dryer blower housing in the lower rear area,its held in place with 1 hex head screw,if its open dryer wont heat
Mar 11, 2012 | Whirlpool Dryers
Whirlpool dryer model geq8858jq1.had a slight burning smell.cleaned the vent hose all the way outside and inside unit.smell decreased but then lost heat.found thermal cutoff opened.replaced and ran for...
Yes Thrmostat is bad "stuck" closed circuit will not open to stay at safe temperature. This can be dangerous. I never run my own machine at home unattended or while asleep. For fear something like this could happen and cause a fire had a recent problem with a Whirlpool. Replaced it after finding the "correct" one. I would bring the bad one with you when you go and get a new one.
Please leave a good feedback for me on here.
as i am trying to help people on here for free.
Jan 06, 2011 | Whirlpool Dryers
Have replaced heat element, thermostat, thermal cutoff, thermal fuse and cycle thermostat on whirlpool dryer. keeps blowing thermal cutoff! Exhaust is clear inside dryer and outside! What is causing all...
I'd like you to try something easy. Set the dryer to Air Fluff and see if the dryer still puts
out Heat let it run for about 2 full minutes If you dryer is still putting out Heat get back to me
Nov 06, 2010 | Whirlpool LER4634J Electric Dryer
Dryer tumbles, no heat, thermo fuse has been changed. Can it be the cycling thermostat or the heating element?
If you have changed the thermal fuse you may have a defective thermal cutoff (located at the top of the heater housing in the back). The thermal cutoff will come with the high limit thermostat located at the bottom of the heater and you should change both parts if the thermal cutoff is bad.
You can take both of the parts (the heater and the thermal cutoff) to a parts supplier to have them checked for continuity (they should both read "closed" if they are good).
Good luck to you!
Oct 07, 2010 | Whirlpool WED5300S Electric Dryer
Whirlpool Dryer Does not dry
Its the thermal fuse. when you jump or, by-pass the cycle thermostat, you are basically by-passing the fuse as well. replacing the thermal fuse will fix thsi issue.
The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Dryers Logo
63 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
