Question about Toshiba Satellite P205D-S8804 Laptop
System restore disc 1 erased & overwrote hard drive. Second disc won't start. All i get is a lengthy paragraph that boils down to : MEDIA TEST FAILURE, CHECK CABLE. PXE M0F: EXITING PXE ROM. tHIS REPEATS ITSELF IN A CONSTANT REPEAT.
    Brigadier General:
  • 8,909 Answers
This sort of error is far too common. There is no checking of the recording being done by the programme that prepares the disks.
What can I suggest? Purchase a new OS that is all you can do unless you have a friend with OS disks as you have the registered key on your Laptop and you do own the OS.
Hope this helps.
Posted on Dec 28, 2010
Reset my fujitsu laotop model M6210 back to factoy reset
RESTORING THE FACTORY IMAGE
The Restore Disc that came with your system contains
two utilities:
? The Recovery utility allows you to restore the original
contents of the C: drive.
? The Hard Disk Data Delete utility on this disc is used
to delete all data on your hard disk and prevent it from
being reused. Do not use the Hard Disk Data Delete
utility unless you are absolutely certain that you want
to erase your entire hard disk, including all partitions.
BOOT Priority Change
Before restoring an image, you must first verify that your
system is set up to boot from the DVD drive. To verify/
change the boot-up priority (rather than booting-up
from the hard drive or an external floppy disk drive),
perform the following steps:
1. Start your system and press the [F2] key when the
Fujitsu logo appears. You will enter the BIOS Setup
Utility.
2. Using the arrow keys, go to the Boot menu.
3. Arrow down to the Boot Device Priority submenu.
Press [Enter].
4. If "Optical Media Drive" or "CD-ROM Drive" is not
at the top of the list, arrow down to the drive in the
list, and press the space bar (or the + key) to move it
to the top of the list. (The system attempts to boot
from the devices in the order in which they are
listed.). Note that the BIOS for some systems will
indicate "CD-ROM Drive", even when a DVD drive
is connected. Then put in DVD restore disc that came with the computer and follow its instructions.
• This disc can only be used with the system with which it was purchased.
Fujitsu IT and Business Services IT Consulting IT and Business Solutions
Feb 19, 2015 | Fujitsu Computers & Internet
Tip
How to Erase a Burned CD
CD-RW stands for CD re-writeable. This type of disc can be written on or "burned" multiple times. However, in order to burn music or data onto a CD-RW that already has something on it, you must first erase the current contents of the disc. No special software is needed to do this, as you can do it with the Windows Media Player program, which already comes installed on all computers with the Windows operating system. Regular CD-R discs cannot be erased or reused--the discs must be labeled as CD-RW.
Instructions
Step 1.
Click on the "Start" menu button in the lower left-hand corner of the screen. Select "Windows Media Player" from the pop-up menu.
Step 2.
Select the "Library" tab in the main Windows Media Player screen.
Step 3.
Insert the CD-RW that you want to erase in the CD-ROM drive. Close the "AutoPlay" window if it appears.
Step 4.
Right-click the CD-ROM drive in the "Navigation" pane on the left side of Windows Media Player. Select "Erase disc" from the drop-down menu. This will automatically erase the contents of the disc.
on Jul 17, 2010 | Computers & Internet
Restore Compaq factory settings with no disc
Caution: Performing a System Recovery completely erases and reformats the hard disk drive - this includes deleting all data files you have created and stored on the hard drive. System Recovery reinstalls the operating system, programs, and drivers.
  1. Turn off the computer.
  2. Disconnect all connected devices and cables such as the Personal Media Drive, USB drives, printer, and fax. Remove media from drives, and remove any recently added internal hardware. Do not disconnect the monitor, keyboard, mouse, and power cord .
  3. Turn on the computer.
  4. From the Windows desktop click Start c00834869.gif , and then All Programs .
  5. Click PC Help & Tools .
  6. Click Recovery Manager . The Recovery Manager Welcome screen appears.
  7. Click Next .
  8. On the Software Program Re-installation screen select No , and then click Next .
  9. On the Hardware Re-installation screen select No , and then click Next .
  10. On the screen that prompts for Microsoft System Restore select No , and then click Next .
  11. The Recovery Manager prompts if you want to restore the computer to its original factory shipped condition. Click Yes , and then click Next .
Feb 24, 2014 | Compaq Presario SR5610F Athlon 64 X2 4800+...
I bought a new hardrive for my m2000 and when i load it it is giving me a "media test failure" response..... how do i load it properly?
If you bought a new hard drive (meaning the internal hard disk), it won't have anything on it. If you just install it and try booting your computer, there won't be an operating system to load. The BIOS (the operating system built into the motherboard) is set up to try loading the operating from connected devices in a certain order. Usually it tries the optical drive first, then the hard drive, and finally it tries to boot over a network connection. The media test failure message means it tried that last resort and still didn't find an operating system, and it's telling you that maybe you have a bad network cable.
You'll need to reinstall your operating system and applications so that the computer will start normally. If your computer came with a restore disc set, or you made a set yourself, you'd use those. If you don't have restore discs, you can do a fresh installation of Windows from CD. You need to find the disc for the version that came installed on your computer, since you'll need to use the product key from the sticker on the bottom. Drivers and utility programs you can download from Compaq's (HP, actually) support and drivers website.
Once you've got a bootable Windows system on the new drive, you won't get that strange message any more.
Jun 03, 2011 | Compaq Presario M2000 Notebook
I need to know how to unintall all the data on my WD hard drive and start over again fresh. Can you help me?
Mac OS X
1 Connect the Western Digital My Passport hard drive to the computer. Power on both.??
2 Open "Disk Utility," located in the Utilities sub-folder of the Applications folder.??
3 Select the drive you wish to reformat. Typically, drives appear twice; choose the furthest left.??
4 Click "Erase," and pull down the Format menu. Choose "FAT32." Enter a hard drive name, if desired.??
5 Click "Erase." A confirmation screen will appear, stating that all information on the drive will be lost if erased. Click "Erase." Once completed, the erased drive will function on both Windows and Macintosh systems.??
Windows
1 Download and install the Western Digital FAT32 Formatting Utility.??
2 Connect the Western Digital My Passport hard drive to the computer. Power on both.??
3 Open the FAT32 Formatting Utility and select the desired external hard drive. Ensure that "Restore factory original FAT32 partition" is selected.??
4 Click "Start." A warning message will appear, stating that all data on the drive will be destroyed. Click "OK" to continue. Click "Yes"' to navigate through.?
May 03, 2011 | Computers & Internet
Trying to fix an older pc presario SR2001WM it loads up to a black screen with the error: reboot and select proper boot device or insert boot media in selected boot device and press a key could you...
Most PC's built in this time frame no longer shipped with a separate set of recovery CD's. Instead, the manufacturer provided a separate partition on the hard drive that contained the recovery program. To access this program, you would first shut off the system and disconnect all peripherals other than your keyboard and mouse. Then start the computer, pressing the F10 key on your keyboard repeatedly as the HP/Compaq logo appears. A recovery menu would appear, giving you the option to perform either a standard recovery or, under the Advanced options, a destructive recovery. The standard recovery will attempt to repair the system, leaving any of your data files intact. The destructive recovery option erases everything, then restored the computer to its original, out of box configuration.
Unfortunately, the recovery partition is on the hard drive itself, so if your problem is due to a hardware failure rather than simply a software crash, the above steps will not work. If this is the case, you will need to contact HP/Compaq and request a restore CD. The following link will take you to their website, and walk you through the process of determining if a set of recovery discs are available for your PC. Select your operating system from the drop down menu and then follow the link labeled Recovery Media.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=3292424#N364
I hope this helps!
Mar 02, 2011 | HP Compaq Presario SR2011WM PC Desktop
What do i need to do in order to format my Seagate Freeagent go 1tb hard drive?
if this is your primary hard drive with an operating system on it
you have to format your hard drive using a third party disc to erase everything on your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to
cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
???????????????????? hope this helps
Feb 01, 2011 | Seagate Freeagent Go 1 TB Hard Drive
System restore disc 1 erased & overwrote hard drive. Second disc won't start. All i get is a lengthy paragraph that boils down to : MEDIA TEST FAILURE, CHECK CABLE. PXE M0F: EXITING PXE ROM.\r\n ...
Your computer is using the network-connection to try to connect a "network boot server", to try to load a bootable image across the network.
The 'MEDIA TEST FAILURE, CHECK CABLE' is the error-message when no "network boot server" responds to a "network boot request".
The 'EXITING PXE ROM' message is the exit from the P(re) (e)X(ecution) E(nvironment) part of the R(ead) O(nly) M(emory) inside your computer, since the "network boot" did not proceed.
So, insert "Restore Disk #1" and restart your computer, and FORCE it to "boot" from the CD-ROM device -- not from the disk-drive. When prompted, insert "Restore Disk #2" to continue the reinstallation of Windows. When prompted, remove the disk from the CD-ROM device, and restart your computer.
Note that it's also possible that your disk-drive is "dying" -- any attempts to install Windows on it have FAILED. Thus, any time to "boot" from those "not-written" files will cause problems.
Dec 28, 2010 | Toshiba Satellite P205D-S8804 Laptop
Going to reset my computer. Where can I find the reset button?
If you're trying to restore the Computer to factory settings, then you can use the VAIO Recovery Center that is shipped with the Computer.
NOTES:
  1. Click the Start button, then click Help and Support . NOTE: If the Help and Support link is not available on the Start menu, re-enable the link in the Taskbar and Start Menu Properties window.
  2. In the Windows Help and Support window, click Backup & Recovery .
  3. Under Backup & Recovery , under VAIO Recovery Center , click Launch VAIO Recovery Center .
  4. In the VAIO Recovery Center window, under Choose a program , click to select the desired option: NOTES:
    • It is strongly recommended that recovery discs be created to help restore files if the operating system will not start. Recovery discs are bootable and can be used to perform a recovery on a properly functioning hard drive.
    • The Windows Backup and Restore option opens the Backup and Restore Center provided with the Windows Vista® operating system. This provides the ability to save information from the hard drive, such as personal data files, and restore previously backed up data.
    • Computer problems related to hardware can be diagnosed using the VAIO Hardware Diagnostics option.
    • One or more drivers or factory-installed applications may be reinstalled with the Reinstall Programs or Drivers option.
    • The entire (C:) drive can be restored to its original, factory-installed condition by selecting Restore C: Drive .
    • Choosing Restore Complete System will restore the entire (C:) drive, while removing or restoring the Recovery Drive partition. Modifying the size of the hard drive partitions is also an option with this type of recovery. This option requires you to insert Recovery DVDs created using the Create Recovery Discs option.
    • To remove all data from the hard drive, including the operating system, all programs and personal data, choose the Wipe and Erase Data option. This option is provided for the convenience of advanced users who want to install a different operating system, and who want to ensure all data has been removed from the hard drive first. All other users are strongly urged to avoid selecting this option.
May 17, 2010 | Sony VAIO® VGN-CR120E PC Notebook
Blackberry sw overwrote burning software on HP media center PC
Hi, Mark here sorry your having trouble. See if i can fix ya.
  1. Mouse to start, mouse to programs, mouse to accessories, mouse to system tools, mouse to system restore.
  2. Left click system restore.
  3. When menu opens select date prior to blackberry software installation.
  4. Follow prompts let system restore it will take a while it will reboot, let it be patient.
  5. Once you have your system back remove blackberry software from system.
Hope this Fixed ya! need more help comment back. Please rate. Good Luck!
Mar 27, 2009 | HP Media Center m1080n (PC099A#ABA) PC...
Toshiba Satellite P205D-S8804 Laptop Logo
44 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
