The circuit board is exploded so that i need anther circuit board to this machine
  • 57 Answers
What is the model #?
Posted on Dec 28, 2010
The treadmill have dcmd67 control board I need to know what value resistor R 19 have
I can't help you (directly) with the resistor value, but be aware that if it exploded, there is probably another bad component (such as a capacitor, transistor, and/or an SCR). Replacing only the resistor may result in the same problem, or may not even work at all due to another bad component. If you do find out the value, try putting in a resistor of the same value, but with a higher wattage rating. I once had a washing machine in which the model had a known problem with circuit boards blowing. I solved it by replacing a bad transistor and installing a higher wattage resistor that had blown up like yours. It never failed again. The way I found the value of the blown resistor is, I looked up a replacement board online, then magnified the photo, and looked at the color code on that same resistor in the photo. How I found the bad transistor is too complicated to explain in few words, but you can google the procedure. (You'll need a multi-meter at the very least; preferably _with_ a built in transistor checker. However, a _totally_ blown transistor can be found with only the resistance settings on a regular multi-meter).
Best of luck...
Apr 05, 2016 | Exercise & Fitness
Somebody exploded an egg in Kitchenaid Microwave combo oven, and circuitboard went bad. Power but no heat. Coincidence?
The circuit board is in a separate section so the motherboard can't come into contact with the exploded egg. Was any liquid cleaning solution sprayed inside to clean up the mess? There might be some crevices where cleaning solution spray could work its way into the circuit board section since it's very close by. Always use a damp cloth instead of saturating the oven with cleaner.
Apr 24, 2014 | GE XL1800 1100 Watts Microwave Oven
Cimbali m3 problem with mainboard
Marion boards are expensive so before grabbing anther it's best to check every aspect of the machine and board. Water damage, steam leaks caused shorts, loose plugs, Rodent damage, etc. Way to many things to go bad before a board replacement. Always do a PROM reset to go back to basic settings. Pulling board also replica all connections. You take a chance of burning out 2nd board. The display goes bad as it's always near water and steam. Do a visual inspection of board foe burns, cracks, water stains, coffee trails. Check programming to see if you can manually activated each item. Boards do go out but usually with a bang. Keep looking. Mark
Mar 09, 2014 | Espresso RMI La Cimbali Espresso Machine
Wiring diagram and board lay out for jvc lt42x579 tv
I have the copy of JVC LT-42X579 service manual that covers the following :
precaution
specific service instructions
disassembly
adjustment
troubleshooting
wiring diagram
block diagram
circuit diagrams
pattern diagrams
voltage charts
waveforms
using p.w. board & remote control unit
exploded view parts list
exploded views
printed wiring board parts list
remote control unit parts list (rm-c2050-1c)
packing
packing parts list
If you want the copy click it HERE.
Jdvillanueva
Sep 29, 2011 | JVC LT-42X579 42 in. LCD TV
I have a HLR5656W Samsung. This question was asked before, but I never saw an answer. I have the same issue. "I have tried two different devices on the hdmi input and neither work. I am trying to...
you need the service manual and you need to look at the exploded view to identify the board next
go to the parts list if the part number isn't in the exploded view.
Feb 05, 2011 | Samsung HCM5525W 55" Rear Projection...
LG front load washer WD-8074FHB the circuit board exploded into little bits during a cycle. I bought a new board but when I connected it up there is no power or display on the new circuit board. What else...
if the curc bord exploded i would blame either power overload. or water in the curc the lg- wd units have both internal p.c.b bord fuses as well as in line fuses try checking them
Jul 07, 2010 | LG Washing Machines
F1 code on oasis washer, machine will not work
HI. This code is in reference to a failed Machine/Motor Control & Water Pressure Transducer module. This is the main initiator of the unit. The F1 is and indication of a failed component, or circuit board structure.
This module must be replaced, asap. The part number will be
W10189966. Click here to view an exploded diagram of the control sector. This module will be located just under the control sector panel housing. The affected part will be labeled number 1
Jan 04, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Hotpoint DW440 flashiing lights
I have just seen the same problem on a neighbours WD440G. I have tracked down the problem to the main circuit board at the back, bottom of the machine. Transistor/FET Q9 has exploded. There was water at the bottom of the machine and the wiring in the vicinity of the nearby connector was wet.
This neighbour is in no financial position to be able to buy a new board, or get an official Hotpoint engineer to confirm what we already know. Anyone know where I can get a schematic diagram for the board?
Dec 10, 2008 | Hotpoint Aquarius WD63 Front Load...
Sony kp 51hw40 real projection tv
Below is exploded view of your Sony KP-51HW40 TV rear side which shows board names and location.
You need to check D Board for convergence ICs and these are marked as IC8001 & IC8002 on circuit board.
Nov 23, 2008 | Sony KP-51HW40 51" Rear Projection...
CIRCUIT BOARD
If your replacing it yourself The clock is under $100 if you have a service company replace it it may cost alot more.
May 15, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
