Question about Protron Televison & Video
My protron 19" tv works
    Brigadier General:
  • 8,909 Answers
I suspect the Sync is on the blue colour and the tv is expecting that, if it is S-Video. The device supplying the picture is not set up to supply that. Check what system the tv requires and set the video source accordingly.
Posted on Dec 28, 2010
My tv remote has sync with the dvd and I cant make it go back to the tv???
use the remote av button to scroll to an av section that reconnects the tv
probably have av 1, av 2, av 3 etc and one is for the dvd, another for the play station connection another for the cd player etc
Sep 06, 2015 | Toshiba Televison & Video
Dvd hookup
It sounds that you are connected the TV with DVD player Via AV cable. In this case, no RF channels won't go. You have to select its AV option. Check it. Refer the user manual for TV.
Aug 12, 2013 | RCA F19251GY 19" TV
What channel should the tv be on when hooking up my dvd player?
Hello
Hook the TV to DVD player with AV cable. Select AV from the TVs menu. This is the pciutr of the AV cable. It will have three wires, and you should connect it with your DVD and TV according to its instructions. OK.
Dec 18, 2011 | Protron PD-007 DVD Player
Trying to connect a PS3 to my hotel room tv. I have 3 color AV cords, and I´m putting each accordingly on yellow, white and red, but can´t seem to see or hear anything on AV source. What am I...
did you set to AV 1, 2, 3 or DVD input, it is depend to where it connected to..whether you connect to the AV input front panel, or rear. if not sure you can connect it to the front panel and sequentially sets the AV source, if still the same. you can connect the cable to the DVD input should be the type of cable TV .. PS 3 is like this:
Connect red, green blue Plug/jack accordingly to each colour on DVD INPUT the TV. set AV Source to DVD.. please Try and if the same result , you have to replace the AV cable of PS3.
Oct 20, 2010 | Protron PLTV-32 Television
Okay i have a digital labs 19" LCD HDTV/DVD and it works fine until you hook it up to an antenna cable, then it wont give channels when i auto scan. what should i do? buy a new cable or is it the tv
I have the same problem. Seemed to work fine with digital cable, but after switching to Dish Network, no luck. If I plug the AV cables (red/white/yellow) directly into the dish receiver, it works fine. The problem happens when I use it as a second TV connected via the RF cable wire. My only guess is that the dish receiver transmits the signal to the second TV via NTSC ... and the Digital Labs TV only supports ATSC and QAM. Hoping someone can confirm?
Jan 05, 2010 | eVision Televison & Video
On a Daytek 46 in LCD TV, no AV Digital Cable Signal, but HDMI OK
Had the same problem.
Fixed by unplugging everything from the power source, leaving for 2 minutes then plugging back in.
Works fine now.
Aug 11, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Need to hook up to tv
use the colored lead (RC) cables to connect from dvd player to your tv, it is color coded so you cant go wrong, then select av on the tv to watch dvd, if it can connect to tv with rc cable then you will need an adapter to connect dvd through antenna jack ok
Jun 29, 2009 | Protron PD-007 DVD Player
No sound when using coax...
Do you use AV inputs for your Cable box? If so, try swapping the audio inputs in the TV, that is, interchange the AV inputs for your DVD and cable box. If sound is audible in a different input, then the Audio input (for Cable) on your TV is faulty. One simple suggestion, Why don't you route your Cable signal through the Tuner of your VCR?
Aug 08, 2006 | Zenith C19A21D 19" TV
Televison & Video Logo
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
