LUXOR V16LCDHD AFTER POWER FAILURE, STANDBY LIGHT CONTIUOUSLY FLASHING, NO DISPLAY, REMOTE HAS NO EFFECT, ON OFF BUTTON ON TV DOES NOT RESPOND.
  • 5,568 Answers
Since nearly all of our entertainment electronics is 'computerized' to some extent, unstable AC can cause lockups so when this occurs, the first thing to try is to pull the AC plug, overnight at best, and plug it back in the next day. If that doesn't work, the power supply has taken a hit and will likely need repair or replacement.
We like to call every power outage a 'surge' when sometimes it doesn't surge but drops out momentarily. Surges are mostly caused by lightning strikes that don't even have to be that local and may be miles away but send high voltage spikes down the lines before any mechanical breaker can interrupt the power. A cheap 'surge protector' will help for lesser events but if they are subjected to several hits, they start to lose their effectiveness and should be replaced. In a single family residence, a 'whole house surge protector' is good insurance and can be installed as a DIY project for under $200 US and even include insurance for 5-10 years against losses of powered equipment.
Posted on Dec 28, 2010
Hi my luxor tv won't come off standby and the red light flashes 35 times? Model number LUX0140001B/01
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty. 35 times flash can be considered as continuous.
Sep 21, 2017 | Luxor Televison & Video
Mum pressed some buttons on amp now the amp wont respond to the original remote or the universal remote. buttons wont work, batteries good and lights up. is there a button that blocks ir signal?
Looking at the user guide it appears that the amp has a standby mode.
See not below on turning standby on. Question can you see the standby light flashing.
I would also suggest using function on the amp to remove any possible issues with the remote.
One would expect the system to return to normal operation by pressing the power button again. If not what do you see on the display.
Note:
Press 1 to turn on the receiver.You can also turn on the receiver using 1 on the remote control. When you turn off the receiver, press 1 again. "STANDBY" flashes on the display panel. Do not disconnect the AC power cord (mains lead) while "STANDBY" is flashing. This may cause a malfunction.
Jul 08, 2017 | Sony Audio Players & Recorders
The standby light on our Luxor Combi is flashing pink and the tv will not turn on either via the remote or on the tv. The standby light is normally steady blue when in standby. Steady red when in operation...
Flashing of standby light are fault indication, and is called blinking codes. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the number of blinks carefully for at least 3 times switch ON / OFF. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window. Blinking codes details to many popular brand TVs are given in detail.
Oct 28, 2013 | Televison & Video
Luxor tv will not power up and red light just keep flashing
I just pull out the mains plug for a few seconds then put it back in. The red light keeps flasing for a while (be patient) then stays solid red. When I then switch on again with the remote it is fine. I often have to do this.
Jul 27, 2012 | Televison & Video
My TV standby light keeps flashing for 10minutes then TV will not switch on. Does not respond to remote or the buttons on the TV panel. Please Help
If the standby light flashes but the set does not trigger or come ON, then it is confirmed that this is an error to signal there is a failure of the main section- drivers to the display.
Now the processor is working as it displays the flashing but the feedback error shows that the circuits is not powered due to this protection.
So disconnect the main power+B and check for short in each individual power circuits.
Check for faults on the driver IC or look for suspected capacitors , leaked or top blown.
Also finally check for dry solder joints, solder all suspected joints.
Apr 08, 2011 | Televison & Video
My KDL sony tv turns on briefly(displays menu) then shuts down, and standby led flashes 6 times then pauses then continues, does not respond to the on/off button or the remote
6 times blinking standby light indicates problem with Audio Section in tv
Check AU 15V output of G2 (power supply) board then check AU board as it has sound processor and sound output ICs.
If you are not familiar with electronics stuff repair then call local tv repairman to repair it for you.
Thanks.
Oct 29, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Flashing light - video going out
When you push Power Button on remote, TV goes to Standby state i.e its power light (LED) lit but no picture / no sound. Power button on remote has symbol looks like.. ( ! )
Aug 14, 2008 | Sony KP-53HS10 TV
Televison & Video Logo
403 people viewed this question
Top Televison & Video Experts
