Question about Sharp LC-26SB14U 26 in. LCD TV
Sharp LC-26SB14U 26 in. LCD TV Problems & Solutions I replaced a fuse 6.3 Amp 125 V and plugged in power cord. A capcitor near the fuse overheated (fried) and I quickly unplugged the cord. The fuse also blew again.
  • 1 more comment
  • Ray Johnson Dec 28, 2010
    Since the capacitor is fried, it obviously needs replacement. My concern is why it melted to begin with. If I replace it, it seems like it would just melt again when power is applied.
  • Ray Johnson Dec 29, 2010
    OK. I will try that. Thank you.
    You are right, I believe the capacitor burst. It is next in the circuit following the power fuse. The circuit diagram shows it as 275V 0.22 ECQUL.
    Top Expert:
  • Sharp Master
  • 75,424 Answers
Hello
There is some leaky mains rectifier diodes on the circuit. Before switching it on, replace all the four mains rectifier idiodes, or a rectifier stack, whatever it may be. Replace the mains filter capacitor that has bulged also' It may have got damaged. Check all the related components on the power regulator section and replace the suspected. Do these things, and inform me the progress. Feel free to contact me through Fixya. Ok.
Posted on Dec 29, 2010
  • The Knight
    The Knight Dec 29, 2010
    Hello
    You are disussing about the main filter capacitor I thinks. Or specify which capaictor does melts in your TV as you switched it ON. If it is main filter capacitor, it will be a little bulky one, which does not melt, it will burst off instead. Please speicy the position of that capacitor to me. Go to its circuit keenly, and try to find its poition on which it is fitted in the power regulator syste. Please give me more details as it will help me to asist you properly. OK
  • The Knight
    Hello
    It is [ 0.22Mfd 275VAC] capacitor, polyster or polystrene type, which will look like a small chocolate. It is rated to AC [Alternating Current], and not to DC [Direct Current}. When replacing it should be the same. The set will work well eventhough it is not there. It is used there as an external voltage surge protection, and as a voltage booster for the choke coil fitted next to it. Anyway replace it with same type. OK.
  • 2,386 Answers
Hello
The capacitor also need to be changed, hope it will solve the issue, if problem persists the move ahead for further diagnostic.
Good Luck
Posted on Dec 28, 2010
  • Computer Links Dec 29, 2010
    hello
    It is nor quite sure that the capacitor will melt again, because when capacitor gone weak then it give such kind of problem, it is more than 80% chances it will be ok after change of capacitor.
    good luck
  • Computer Links Dec 30, 2010
    Hello
    if the solution gives you help, then why you rejected it, not even the solution rating, at least appreciate my effort.
    Regards
Sharp tv modle no 21fl96 not powering up
try a different outlet to plug into. use ohmmeter or continuity tester for the integrity of the cord & plug. try to open & look for a blown fuse, should be near the power (as it enters the back of the tv) cord area.
Oct 03, 2015 | Sharp Televison & Video
How many amps is the fuse that is located on the back of the TV near the power cord. It says T5AL/125 or 250 v. f800
Something else is going on to cause the fuse to keep blowing. Sounds like you have an issue on your power supply in the unit. Also check the outlet that your plugging it in to. Good luck!
Jun 28, 2012 | Zenith E44W46LCD 44" Rear Projection...
I have a sharp aquos lc-c4677un its not turning on at all now. When I push the power botton on the tv, the power light turns on and about 2-3sec the power and opc light start to blink and thats about it.
How are the power and opc lights blinking? Do they blink simultaneously or does one blink then the other? How many time do they blink per second? Also have you had it fixed yet? and if so what was done? I had a similar problem with my set.
Aug 06, 2011 | Sharp AQUOS LC-C4654U 46" LCD TV
I have a Sharp TV model# LC-26SB14U. The left speaker no longer works. I have hooked up some external speakers, hoping that would solve the problem. It didn't. I began having problems with the speaker...
One thing we need to know is how is it connected and to what is it connected. If you are using HDMI from another source or what? This could be also be an issue with the sound board and chip.
Oct 15, 2017 | Sharp LC-26SB14U 26 in. LCD TV
TV red "on" light not coming on. Cannot get power to TV
The power supply board is dead.That the board where the power a/c plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power suply board for the replacement.
Jun 10, 2010 | Element Electronics 26 in. LCD TV
My Sharp LC-42-D62U won't power up. The power light blinks twice, then the power light and the OPC light blink together once. any fix to this problem?
Ur Tuner signal board have problems or dead.Ur power LED light indicator stable for a few mins before the power LED light,and the OPC LED light indicators flashes?After the POWER light and OPC light indicators flashes,just push the power button again for the power recycles again.Probally have to pushes the power button 3 or 4 for power light and opc light indicators flashes,the LCD backlght will lght up and work.Sharp tv have this problems alot,very common in Sharp LCD tvs.
Apr 17, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I have a Sharp AQUOS LC-19SB14U 19' LCD TV that won't power on
The main power transistor in the power supply appears to have failed. It has also blown the fuse. Not a job for the DIY'er unless you have serious electronics experience.
Mar 08, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp LC-37SH12U LCD TV is 20 months old and would not power on
Your power supply unit needs servicing on some part replacements. bad capacitors, voltage regulators, hi-watt resistors,....etc
Nov 03, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
RCA LCD TV 26 screen turns white, no sound no nothing
You have a blown fuse in the power supply. It does not look like a fuse.
It is near the top of the board and is labeled as 1.6 amp. It supplies 12
volts to the main board (via q422). A 2 amp fuse should be a fine
replacement.
Sep 04, 2009 | RCA L26WD26D 26 in. LCD TV
I need a diagram for lcd tv Sharp LC-26SB14U.
I have a sharp LCD (LC-26SB14U) which I purchased one year ago and today the sound stop working as I was watching the olympics. Any idea how to fix this problem as the warranty is only good for a year.
Thanks, Bob
Jun 24, 2009 | Sharp Televison & Video
Sharp LC-26SB14U 26 in. LCD TV Logo
350 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
