Looking for a manual for a phillips ccc190At32 tv combo.Can the upper channels above channel 13 be change over to cable channels?I will have the remote by next wednesday night.
    Brigadier General:
  • 8,909 Answers
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, and a list of Dealers for spare parts, as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Posted on Dec 28, 2010
We are connected to cable, but don't get most of the channels, we are not using a box for cable. is there a way to het the channels/
Some of the older units in the cable band will not receive channels abover about channel 46---if this is the case nothing can be done.
Jul 16, 2012 | Panasonic PV-C1320 13 in. TV/VCR Combo
Phillips dvdplayervideorecorder connect w/zinwell converter box
First off get the TV on the right channel. It will either be ch3 or ch4. If you are using a cable box the dvd/vcr combo will have to be on ch3 or ch4 as well. OK, Make sure the input connector on the combo is hooked to the output connector of the cable box and the output connector of the combo is hooked to the input connector of the tv. Deal with one part at a time. First hook the combo to the tv and get the tv on the right channel (ch3 or ch4) so that you can see a pre-recorded dvd or video play. Then you will know what channel the tv is supposed to be on. When you find it don't bother the tv channel any more. Stop the dvd or video and hook up the cable box and turn on the cable box and set the box to a known good channel. Now put the combo on ch3 or ch4 with the combo's channel selector buttons until you see the cable box playing on the tv (remember you already set up the tv channel). Change channels on the box but don't bother the channels on the tv or combo anymore. You can put the box on whatever channel you want. The box will be your channel selector. I certainly hope that this helps. I know it can be confusing but don't give up. Just remember that the tv and combo have to always be on ch3 or ch4 (which ever one you found before). Good luck and thanks.
Nov 01, 2009 | Televison & Video
We are receiving channels 1-13 only; don't know how to add more
make sure you have your tv set to cable, if you have a set top box unplug the box plug it back in reboot it, like i said make sure your tv is set to cable then do auto channel scan should work good luck!!
Apr 12, 2009 | Toshiba MD20Q41 20 in. TV/DVD Combo
MORE channels! for CHANNEL SET UP PHILLIPS pl9127 c101/ 27f 800 7583
I need more channels. I ONLY get 13 channels, 1-13. I know im supposed to have more... Phillips Consumer electronis: manufacture no# 3210t127a
Oct 28, 2008 | Philips TS2746C TV
Tv/vcr combo wrong cable channels
This could be one of two problems, either the TV tuner card is set up to accept the wrong type of signals (which normally can be changed in the menu of the television) or the card isn't capable of translating the signal (with most cable companies going over to digital signals with their boxes translating the signals over.) My suggestion is to check to make sure the proper signal type is set in your menu (if in fact this is even an option for this particular television) and if that doesn't work get a generic analog digital cable box.
Sep 12, 2008 | Philips 43PP9202 43" Rear Projection...
Only goes to channel 13
It probably has to do with a setting in your menu. Usually it is the antenna category. Change it to Cable or CATV.
Mar 18, 2008 | RCA T19408 19 in. TV/VCR Combo
Daewood input w/out remote
Change channels manually on front and go below channel #1 and then it should say "video" 1 or "Aux". Hope that helped you. Have a great day. Jay
Jan 30, 2008 | Daewoo DVQ13H1FC 13 in. Combo
Tv channels
Probably, at first you searched the programs in automatic way. And there were only 20 channels at that time. So, you only have 20 channels. You should try to search channel 21, 22, 23, etc, manually. If you can't set 21 on your program, then your tv set has only 20 programs.
Nov 11, 2007 | Samsung CXJ1352 13 in. TV/VCR Combo
13" Sansui TV and VCR combo
ok! you can auto search the TV to find all Cable channels! but first you have to set mode TV /CABLE set to cable then you auto search!
Oct 12, 2007 | Sansui COM312AD 13" TV/VCR Combo
I have the 13 inch and...
If you get channels 2 to 13 nice and clear but the rest are snowy, it means that the TV is set to the broadcast channels, which means that for the channels above 13 it is tuning in the old-fashioned UHF channels. If the TV is set to the cable mode then it tunes in cable channels above 13. To do this, enter the menu and navigate to the tuner settings, set the tuner to standard cable and then do the autoprogram, and the tuner's memory will be set for your cable system.
Aug 03, 2007 | Emerson EWC1903 19 in. TV/VCR Combo
Televison & Video Logo
83 people viewed this question
Top Televison & Video Experts
Electro Med Services...
